Question about Toro Lawn Mower With Toro Power Tools
Replacing traction cable
Need to know how to replace the traction cable
  • pondking
    pondking May 11, 2010
    please provide model number
  • 138 Answers
Go to toro.com then customer care then manuals and parts type in model then find owners manual to download.
Posted on Apr 06, 2009
2 Suggested Answers
  • 24 Answers
SOURCE: cable traction needs adjusted
To adjust the self propel cable, loosen the cable
clamp, pull the cable downward to remove all the slack
then push the cable jacket up 1/8”
and secure with the cable clamp
good luck
Posted on Feb 05, 2009
How do l replace traction control cable on cub cadet 826 SWE
The following link shows how to replace your cable. The link shows a craftsman model , it will be the same procedure as your cub cadet. You can refer to your owner manual for adjustment procedures
Snowblower Won Move How To Replace The Drive Clutch Cable On Craftsman Or...
Download manual
Jan 25, 2016 | Cub Cadet Garden
Abs light, traction fault light on, radio does not operate
THE 1ST THING TO CHECK I BOTH SPEED CONTROL SENSORS LOCATED ON THE BACK SIDE OF YOUR WHEEL HUB...SOMETIMES THEY CAN BE CLEANED..TRUN WHEEL HARD RIGHT FOR RIGHT CABLE HARD LEFT FOR LEFT CABLE...PULL PIN OUT THEN CABLE VERY EASY TO REPLACE
Apr 12, 2014 | 2000 Jaguar S-Type
Does my master cylinder have traction or no?
Plymouth master cylinders had traction or not based on the model, year and engine type. Input that information into the search tool at AutoPartsWarehouse dot com (or any parts site, really,) and it'll tell you what you need. Also, if you try RetailMeNot.com, there's often a coupon code so you can get a small discount on your part. Good luck!
Aug 31, 2012 | Plymouth Voyager Cars & Trucks
How do you replace a drive cable on a toro recycler 6.5 hp.
Its a bit of a pain - but with ordinary tools, it can be done. Get the replacement cable first. You can see how the bottom spring wraps around the cable with a universal joint sort of arrangement. Remove the belt protector (three screws from the top deck; if you have a battery compartment, that will temporarily need to go. Release the old cable from the top and middle attachment points, then unhook the spring from the traction lever. You might need to destroy the old cable lock to the mower deck to remove the old cable. Remove the plastic cup next to the cable where it exits the mower deck. Replace parts in this order: New spring/cable to the traction lever, snap in plastic interface to mower deck, small plastic cup top cable attachment, then middle attachment. You might need to move the middle attachment after you give it a test run. Replace belt cover and battery compartment if necessary. A lot of steps but, except for a difficult fit to get the spring hooked up, nothing is really difficult. I paid about $30 for the replacement cable from a local dealer; Overpriced, but I wanted to get the job done today.
Oct 15, 2010 | Toro Lawn Mower With Toro Power Tools
Can a traction clutch cable on an Ariens 520 be repaired/replaced as a do it yourself? IF so, how do you repair it?
Yes, it can be replaced. Normally, cables are attached to the handles and then to the engagement bar for traction near the belts. You may need to tip the unit on it's nose to remove access panel to expose mechanisms. Also the inspection cover over the belts in front of the engine may help identify the cable routing
Dec 21, 2009 | Ariens Garden
Parking Brake Release Cable has snapped
This should help...http://www.autozone.com/autozone/catalog/parts/partsShelf.jsp?categoryDisplayName=Brakes+%26+Traction+Control&fromType=parts&fromString=search&parentId
Aug 15, 2009 | 2004 Chevrolet Tahoe
03 Yukon Denali Traction Control/ ABS Problems
my 2000 yukon has the traction control light on and the abs light on any anwsers?
Jul 31, 2009 | 2003 GMC Yukon Denali
1996 oldsmobile lose power atfer it reach 25mph the low traction
Per your description, it sounds as though there may be a wheel speed sensor problem or a tire that is low on air pressure.
The traction control system on your vehicle relies on four wheel speeds to determine if the vehicle is in a skid or not. If the traction control system sees one of the wheel speeds lower or higher than the rest, it thinks your in a spin or skid and will reduce power to compensate and straighten the vehicle.
So, first thing to do is check all four tires and make sure they are at the same inflation rate some where between 28 and 32 lbs.
Next, disconnect the negative battery cable for 5 minutes, this will clear the module and let you start fresh.
Try that first before any parts are replaced.
Good luck and let me know.
Regards,
May 06, 2009 | 1996 Oldsmobile Cutlass Ciera
Cable traction needs adjusted
good luck
Jan 26, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
1,591 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Dwain Pippen
Are you a Toro Garden Expert? Answer questions, earn points and help others
