Question about Kenmore 5.1 cu. ft. Chest Freezer - White
Kenmore model 19502 chest freezer green light blinking
    New Friend:
My Kenmore chest freezer just went dead today. It ruined my Ribeye steaks, my shrimps and other meats. I will not buy a Kenmore again.
Posted on Sep 15, 2016
bobotfel
  • 236 Answers
SOURCE: kenmore chest freezer power problem
Try to unplug the the unit power supply to reset the error. But if the error persist you have to call for a qualified technician,
Posted on Dec 28, 2007
hotuna
  • 288 Answers
SOURCE: Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Posted on Feb 19, 2008
dauphine
  • 207 Answers
SOURCE: Kenmore Chest Freezer
It might be freezing normally but that doesn't mean that compressor's motor isn't overheating due to lack of freon or mechanical problems on motor itself. Better not risk a fire and let someone experienced check the compressor's motor. Overheating is never a good sign.
Posted on Apr 20, 2008
  • 3 Answers
SOURCE: Chest freezer - hose adaptor?
That would depend on the size of the freezer. If it's a compact 5-7 cubic feet, then its not necessarily needed, but if it is a large freezer I would recommend buying the hose adapter. The basic function for the hose adapter is draining the water after defrosting the freezer.
So if it's a large freezer that will not be moved, then YES by all means, you need the adapter.
Posted on Nov 21, 2008
  • 68 Answers
SOURCE: my kenmore freezer does not turn on at all
u either need a new thermostat or your compressor is dead
Posted on May 02, 2009
Green light
Try unplugging the freezer for 10 minutes to reset the cycle.
Oct 17, 2013 | Danby 3.6 cu. ft. / 102 liter Chest...
Kenmore 6.9 cu. ft. chest freezer stopped working
It looks like a bad ignition switch or capacitor. This is not that expensive. Probably not the compressor. Unfortunately, one small part stops the whole show.have a friend who is a tech look at it.
Jan 24, 2013 | Freezers
My kenmore model 19502 freezer is not freezing
Have the same freezer bought the warrenty glad I did services tech said that he knew the porblem before he came to fix it compressor locked up at 7.9 amps he said this is an issues with 99.9 percent of this model. Light was on flashing but food would not freeze. Sears will replace for me they are giving me a diffrent model number. I had no power surge or nothing of that manner. Faulty appliance. A recall has'nt been issued... but it should
Oct 13, 2012 | Kenmore 5 cu. ft. / 142 liter Chest...
I have a kenmore chest freezer model 19502/19702. I had it unpluged for 5 months. When I plugede it back in the power light flickers. Tryed other outlet. Other then that it seems to be working
We purchased this same Kenmore chest freezer model 19502/19702 in 2010. In less than 2 years the compressor quit. If you do a search on this model you will see dozens of complaints. Don't waste your time or money on this freezer.
Apr 16, 2012 | Kenmore Freezers
We have an ancient Kenmore Chest freezer. I don't know what the orange, green & red lights mean. Also which is "ON" 0 or -
the light tell you if the door is closed properly or not . Close the door tightly and check the lights. Then open it and check them again this will tell you the positiopn of the door for each colour
Oct 06, 2010 | Kenmore Chest Freezer 16082
Light blinking
Hi. the neon light is weak . replace the light & It will be ok
Dec 23, 2008 | Freezers
Green light on the front
Your problem is more than likely in the light itself. The green light is the indicator that the temperature is in acceptable range.
May 15, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Chest Freezer Wiring
hi mel,
green with yellow are ground wires and usually are from compressor to system chassis from your 3 prong plug use the green wire and just find a point on the chassis to pin to if you can get model number you can find on kenmore website
May 01, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Kenmore chest freezer power problem
Dec 26, 2007 | Kenmore 8.8 cu. ft. / 249 liter Chest...
Kenmore 5.1 cu. ft. Chest Freezer - White Logo
289 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
