Question about Wilmar W5739 Quik Line Laser Level
How does one use the quik line laser level - Wilmar W5739 Quik Line Laser Level
How do I check if my dewalt spinning laser is accurate?
Set it up and shoot 4 level points around the laser . Like at 12 -3-6and 9 o clock. Move the laser 15 or 20 ft from where it is now and re-shoot those 4 points again .if they don't read level then your laser needs calibrated
Jan 07, 2015 | Dewalt Self-Leveling Line Laser...
Bizhub c253
Quik fuse but not 800mA if 80mA!!!You can use every rapid(quick fuse 50-80mA.
Mar 23, 2014 | Konica Minolta bizhub C250 All-In-One...
Black and decker crosshair laser level
The really fine wire is soldered from the RED terminal on left to the RED terminal on the top left (underneath the board). See below in the images.
Jun 11, 2012 | Black & Decker BDL400S Bullseye Crosshair...
What name brand and type of strut (gas vs. oil) would be best to replace old ones in a 1999 Honda CRV? Does Nappa make any really good ones?
whether you have a 91 Geo or a 99 Honda you should look around for a QUIK STRUT. this includes a new upper strut bearing and a new coil spring, both of which are also due on a car that age. the labor to install a quik strut will be lower as the old ones are simply discarded. NAPA sells parts that other companies make, it does not make its own line of parts even if it says NAPA on the box. You can find a monroe quik strut on eBay cheaper than through a NAPA dealer.
Mar 04, 2011 | 1991 Geo Metro
How do you know when the strait line laser level and stud finder is on a stud
Hello. The instructions can vary from model to model, but most have a green indicator light that lights up when the unit detects a stud. There is a section in the manual (for most models) that will show/inform of the unit's individual method. Here is a link to the company's product manual support page. Click on your specific model to download the manual.
http://www.irwin.com/support-services/product-manuals
If this answer has helped, please rate it a four-thumbs up. Thank You.
Jun 18, 2010 | Strait-Line Intersect Laser Level With...
I need to find a manual for a strait-line laser level 120
I think that this is the one that you are after:
http://www.irwin.com/irwin/resources/STRAIT-LINE_X3_Instruction_Manual.pdf
If it helps, please leave feedback. If not, let me know and I'll try and help som more!
Jan 28, 2010 | Strait-Line Laser Level 120 360 Degree...
Wilmar W5739 Quik Line Laser Level Logo
136 people viewed this question
Top Wilmar Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Wilmar Measuring Tool and Sensor Expert? Answer questions, earn points and help others
