Question about RCA HD61LPW42 61" Rear Projection HDTV
Color is wrong after color wheel replacement
I had a "screeching" color wheel in my RCA HD50LPW175 DLP HDTV. It had reached the point where the TV would shut down in a few seconds after attempted start-up - no video. After replacing the color wheel, the set turned on just fine, video and audio were working, and the screeching noise was gone. Only one problem, the colors are wrong. It almost looks like a polarized image. I suspect red and blue have somehow been reversed. Any suggestions?
    Novelist:
    Scholar:
  • 67 Answers
You probably replaced a bearing colorwheel, and it was replaced with a bearingless. If you look inside the TV on the back of the light engine (the silver box in front of and to the left of the color wheel), there should be a jumper (that connects two wires coming out) toward the bottom of it in a recessed little hole. That jumper should be removed if the color wheel was replaced with the air bearing type. Just grasp it gently with a pair of needle nose pliers, and pull it out slowly.
This should restore a normal color operation, but there might be some other adjustments that need to be made if it doesn't clear it up completely.
I hope this helps you...
Posted on Jan 22, 2009
    Problem Solver:
  • 6 Answers
I am not sure about your model but i do know on some samsung dlps there is a dip switch that has to be changed if you have the backwards color after changing the color wheel.I hope this helps.
Chris
I have a DLP HD50LPW175. I replaced the color wheel but now the faces of people are blue.
Bad light engine/optical assy Call UED 1-800-648-6657 or try Encompass Parts Distribution 1-800-638-3328
May 26, 2010 | RCA HD50LPW42 50" Rear Projection HDTV
62" RCA dlp loses color
If you hear any winding, whirling or screeching noise (Color Wheel symptoms)
If there is any vibrations in the TV (Color Wheel symptoms) you would need to change the color wheel.
Apr 15, 2010 | RCA HD61LPW165 61" Projection HDTV
I have a 50 inch RCA Real Projection TV (DLP or HDTV). I just replaced the lamp and everything worked fine. One night it made a big sound and shut off. Now when you turn it on, nothing appears, a few...
you could have a color wheel problem or a power supply problem
one questions did you reinstal the door at the rear
you might want to remove the lamp module and try a reinstal and see if condition changes
as to costs if you can get the color wheel 150.00 or so
there ae several things that could cause this a dmd module a color wheel and power supply or digital board the lamp cover when installed it closes a saftey switch there thats why i ask if you has installed door
Oct 22, 2009 | RCA HD50LPW175 50" HDTV
TV worksfine for one hour, colors fade in and out, flickers
Color Wheel, Go website Encmpass Parts Distr Look up the part # if they do not have it in stock then go to E-Bay look under Electronic 1-800-638-3328
Oct 07, 2009 | RCA HD50LPW175 50" HDTV
My picture is gone crazy
Call a good TV Tech and have him replace the color wheel assembly.
Jul 29, 2009 | RCA HD50LPW175 50" HDTV
RCA HDLP 50W151 scenium color wheel
They make two different color wheels for the Rca DLP are you positive you got the right one. As usually its a straight forward install no adjusting needed. Post the chassis number off the back of your set and I will try to help you out with it.
Apr 07, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
RCA HD50LPW175
Sounds like the color wheel is failing.
Dec 18, 2007 | RCA HD50LPW175 50" HDTV
RCA HD61LPW42 61" Rear Projection HDTV Logo
364 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
