Question about Refrigerators
Low voltage to ice maker - Refrigerators
  • jomoberg Mar 09, 2009
    voltage to the ice maker is low, but the refrigerator and freezer work fine, was the repair man just trying to sell me a new one? He said that the ice maker was the right one, just the voltage was not high enough to make it work.
Have have the same problem with our ice maker
95 volts it is a kenmore coldspot side by side
let me know what you find out garnd@bellsouth.net
Posted on May 06, 2010
2 Suggested Answers
peyton32034
  • 410 Answers
SOURCE: Ice maker not working
the icemaker will run at 120v ac +- 10% so 108 v is within range altho marginally. since you have the icemaker removed. remove the front cover and check to see if the drive gear is broken or if the 2 center pins that hold the gear in place are twisted or broken. this is most likely the problem. the motor module can be replace very easily part # is 8201515
the normal home position for this icemaker is at the 2:00 position facing the front of the icemaker. if it is any other position the motor module is almost always the culprit..
Posted on Dec 18, 2007
Ice maker not filling
Is power cut on to it? If it has wire arm, it should be down. Is it getting water? If not, a determination will have to be made as to whether the ice maker is sending voltage to valve during harvest cycle. If valve is getting voltage, replace valve. If not, replace ice maker. If Ice Maker is getting water but not dumping it, replace maker.
Oct 19, 2017 | Refrigerators
No power to the inline valve for ice maker. what is the voltage?
Only should get voltage when it is actually calling for water. Voltage would be 120 volts.
Jun 06, 2015 | Frigidaire 20.6 cu. ft. Top Freezer...
Ice keeps getting stuck in ice maker # fsc23r505b2
Most icemakers have a low voltage defrosting element wrapped around the ice shute to prevent the ice from freezing and jamming up. Carefully have a look for any disconnected wires or damage to the heating element. If the ice is getting "glued" together in the ice box itself, its likely that the water tray is overfilling and causing water to run down into the ice box. When it freezes, it freezes all the ice blocks together. In this case, you may need a new ice maker tray or ice maker water valve.
Oct 20, 2013 | Frigidaire Refrigerators
Kenmore side by side makes no ice
the water line coming into the freezer may be iced up. or the motor that spins the ice "ejector" arm may be stuck. try spinning it manually (just dont force it).
May 29, 2009 | Kenmore 44103 Side by Side Refrigerator
Ice maker for Kenmore model 532343 not working
Does your water have minerals?
Faulty Water Valve
Your ice maker is designed to fill with water for 6 to 8 seconds. Check to see that the ice maker is not sending power to the water inlet valve for a period longer than what you unit is designed for. Does your water have minerals?
Also check to see if the water inlet valve is closing too slowly. The power to the valve is being shut off in the correct amount of time, but due to wear and tear in the valve, it is closing too slow.
Check the timing on the value. Put a volt meter across the leads of the water inlet valve. Set the voltage range to cover the 120v voltage. Cycle the ice maker and watch the meter. When the ice maker begins to fill with water the meter will read voltage coming from the ice maker. Time the difference between when the voltage is cut from the valve and when the water quits filling the ice maker.
If the water shuts off immediately when the voltage is removed, the valve is probably good. Since it was off 10 days the particle build-up on the valve may be the problem since it could solidify. You could try working the valve back and forth or replace it.
If the valve closed quickly then the problem is the valve was opened too long.
If that is the case then you have an ice maker control problem. In that case see if the timing can be adjusted.
Mar 24, 2009 | Kenmore Refrigerators
TAYLOR 632-33 ICE CREAM MAKER
If you are wiring a Taylor machine to three phase power and you have a "wild leg" or "high leg" you must place the high voltage leg on L3. This will keep the higher voltage out of the control circuits of the machine. To clarify what a high leg is, it is created in three phase applications where a certain type of transformer is used. It creates two normal power legs, 110-120 and one leg that is only useful with another leg of power. If measured to nuetral or ground a wild leg will measure considerebly higher than the other legs. Hope this is helpful
Aug 06, 2008 | Taylor 632-33 Ice Cream Maker
Polar Ice Maker Portable
there is a little sensor inside on the top right, it is a little wire if there is anything on it it will not work, i took at small pair of pliers and gently cleaned it
Jun 21, 2008 | Polar PIM15W Ice Cream Maker
Jenn Air JCD2389GES ice dispenser problem
You could have a layer of solid ice at the bottom of your icetray. Remove icetray. Remove any ice in bottom. Reinstall. Be careful there is a connection on the rear of the icetray, you may have to turn it to get it to mesh correctly. Fill with ice and it should work fine. Good Luck.
Feb 24, 2008 | Jenn-Air JCD2295K Stainless Steel Side by...
Refrigerators Logo
121 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
