Question about Canon PowerShot A75 Digital Camera
Screen gray When you turn camera on lcd screen is grey no images. when you click shutter no pic taken.
  • Anonymous Dec 27, 2007
    i already reformat but still no effect, please help............
  • Anonymous Jul 31, 2008
    My screen is gray.I took the camera to a repair center and they want $139.00 to replace the ccd and problem solved or exchange my camera for another one the same but with the ccd replace already, in other words even exchange and no money to pay.What do yo think I should do?
  • 3 Answers
Service Notice: CCD Image Sensor Advisory::::
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=9828&keycode=2112&id=48264
They will repair for free, free shipping too..
Posted on Nov 03, 2008
THE PROBLEM IS THE CCD
Posted on Jul 06, 2007
SOURCE:
CAnnon Powershot A630 LCD screen will not light up when trying to take a pic. I can, however view old pics that I've already taken.
First press the DISP or DISPLAY button to see if that corrects the problem. If not, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 09, 2011 | Canon PowerShot A630 Digital Camera
--cannot view anything to take a picture of--the view screen is black but I can see al menu items and can display settings. Flash works. I can see cannon signal clearly when camera is turned on. I am...
The A6XX series is prone to stuck shutter problems, particularly if the camera isn't used very often. Lens lubricating grease can coagulate on the shutter, immobilizing it. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 29, 2011 | Canon PowerShot A630 Digital Camera
The view finder or screen are black. The lens moves out when the camera is powered on, I can hear the shutter click when pushed; the telephoto is moving; I have all the settings show on the screen when...
I know it may sound like the shutter is moving, but you're going to have to actually look down the lens barrel to confirm it's actually moving, and not just producing a sound effect from the camera. Also keep in mind Canon's SX IS series cameras are notorious for the following problem (fantastic cameras otherwise).
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 31, 2010 | Canon PowerShot S3 IS Digital Camera
Cannot take a pic. No image in the LCD while pointing at an object or person.The LCD remains gray/black. Even if I snap a pic, no image.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 18, 2010 | Canon PowerShot SX100 IS Digital Camera
I have a powershot s3 is and when I turn it on I have no pic. It just started doing this and last time I hit the display button and the pic came up. It will show images of pics that I have already taken....
Nov 08, 2009 | Canon Cameras
Black screen. Can view previous pics even see icons via viewfinder or LCD but will not take a picture.
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 09, 2009 | Canon PowerShot S3 IS Digital Camera
My i85 camera's lcd no longer displays what you are looking at. Just a black screen. All the menu items are there and working. The battery is charged. The power button is working as well as the lens open,...
My i85 camera's lcd no longer displays what you are looking at. Just a black screen. All the menu items are there and working. The battery is charged. The power button is working as well as the lens open, but no image is available just a black screen. When I I try to take pic is showed very low light but doen't show image of pic taken when I check. Please advise. This a brand new camera and was taken excellent pic as of this friday. Groove_us@yahoo.com Mr.Tracy Johnson
Apr 26, 2009 | Samsung i85 Digital Camera
Shutter won't open when turned on. Screen is gray & alarm sounds
It sounds as if when the camera was dropped it impacted the image processing chip inside of the camera thus why the LCD screen appears gray in color. You may want to call Olympus and discuss repair options. Their telephone number is 800-622-6372 option 2 and then option 3.
Nov 19, 2008 | Olympus Stylus 1010 Digital Camera
Show only black when trying to take pic/video
This problem is caused by a stuck shutter assembly. Normally the shutter is open which allows light to enter the image sensor and show you the live preview you see on the screen. When you take a picture the shutter closes which allows the image sensor to record what was seen at the exact moment the shutter closed. The shutter is stuck closed, causing the image sensor to always be in the dark. These shutter assemblies are extremely small and delicate. The miniature parts can become jammed with just the slightest bit of oil or contaminant, or the slightest misalignment of components. The problem can sometimes be fixed by gentle tapping of the camera on a solid surface. If you are going to try this be VERY careful, and do not tap the camera on the buttons, lens, or battery door. If this does not solve your problem then the camera is going to have to be taken apart and the shutter cleaned and reset to allow free movement. This repair costs $125 to $145.
Jun 13, 2007 | Nikon Coolpix 3200 Digital Camera
Canon PowerShot A75 Digital Camera Logo
159 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
