Question about Fisher and Paykel Washing Machines
Leaking fisher & paykel smart drive 501
Water gushing out underneath leaking. Seems like hose off. Can't see how to take top off to check.
  • Fisher and P... Expert
  • 555 Answers
Check your hot and cold hoses at the back for leaks,
these are just crimped on plastic ends and can crack and leak..
Posted on Dec 14, 2013
  • 96 Answers
SOURCE: fisher & paykel smart drive washing machine leaking water
If your washer is still under warranty, I would call the company and have them send someone down. If the leak is from either the drum itself or a seal then I don't think you could handle it yourself. But, first make absolutely sure that it's not from any hose connection. Tighten all the connections, especially those to the drain pump. And check the pump itself for any leaks.
Posted on Mar 02, 2008
IFIXALL
  • 868 Answers
SOURCE: Fisher & Paykel smart drive
Turn machine OFF on the front panel. Hold down the Water Temp Down button and press the POWER button. Release buttons. You are in Diagnostic mode.With your service sheet ,Diagnostic chart will explain where the error lights pattern and the path to your solution are.My advice is this....there is a known problem with the wire harness connectors,and the contact that is made at the point of connection.One at a time remove each connector starting at your main control board ,some where there is a loose connection.
Posted on Jun 08, 2008
  • 409 Answers
SOURCE: Fisher and Paykel Washer leaking water
hi there,
the leak underneath could be from the pump or the drain hose. some washers have a tub to pump boot that sometimes springs a leak.
for a 4-month-old washer, i would certainly hope you pay nothing. F&P appliances come with at least a 2 year warranty. check your user & care guide for warranty information.
Posted on Oct 03, 2008
  • 155 Answers
SOURCE: Fisher and Paykel Smart Drive 015 won't fill with
if you have replaced water valves and still not working you need to check if power is supplied to valves also does the machine do any other functions like draining or spinning if you advance it if not possible fault is lid switch if the machine stop starts continually possibly out of balance switch faulty if none of the above control board may be faulty hope this helps
Posted on Nov 05, 2009
  • 713 Answers
SOURCE: it dose not go to spin
Hi just read your posting.Now just a couple of questions.Does your machine drain the water If it does not drain the water remove most of the water by hand so you can tip the machine back so you can look underneath .Now you will see a pump to the front right of the machine.It will have a red or black fan attached to it.Turn the fan a few times to loosen the pump if it is tight .If it loosens when you turn the fan put it back on its feet and select a spin cycle and push the start button.Hopefully it starts to drain.If it drains it should spin. Please reply with additional information or if it starts to drain.Good luck.
Posted on Jun 15, 2010
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Water underneath unit
Check your water hoses may be leaking behind the machine or at the tap.If the hose is leaking turn all taps off. the alloy crimp needs to be cut off & put a hose clamp on the hose.turn all taps off when machine has finished the wash.
Feb 01, 2013 | Fisher and Paykel GWL11 Top Load Washer
Water underneath unit?
Fisher and paykel kelvinator II smart drive 501 washing machine stops washing mid wash
Check the out of balance switch under the blue motor controller
for corrosion replace if corroded.
Sep 27, 2012 | Fisher and Paykel GWL11 Top Load Washer
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Jul 03, 2012 | Fisher and Paykel Washing Machines
Fisher & paykel 501 smart drive washing machine
It does not seem like a problem of the unit. It might be a loose connection of supply code. Keep the supply code pressed to the unit in different directions and see if the unit takes power. If so, replace the supply code. It's not that expensive.
Jul 05, 2010 | Washing Machines
hi there,
Oct 03, 2008 | Washing Machines
Fisher & paykel smart drive washing machine leaking water
Mar 02, 2008 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
71 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
