Question about Salomon Winter Sports
How do I wash my linings? - Salomon Winter Sports
My washing machine LG WD-SR1408B, if i add detergent in the dispenser drawer,, the machine doesn't take it to washing!! Wat can i do!
Check you cold water supply line. Turned off? Kinked? Or the filter in line where hose attaches at the back of the washer is blocked.
Feb 14, 2017 | LG Washing Machines
4h and 6h delay lights on. Door not opening
Call the manufacture tech support line or Google it on line and see what info comes up put in the model make of washing machine
Sep 01, 2015 | Washing Machines
How to do a cold wash on this machine?
If you intend to always use cold water go to any hardware store and get yourself a "Y" splitter for a standard water faucet. Connect this splitter to the cold water faucet on the water connection and connect both lines from the washing machine to the "Y" side of the splitter. Now you will only get cold water to both sides of you washing machine's supply lines.
Oct 18, 2014 | Whirlpool Washing Machines
Clean filter washing macine
With any washing machine the filter is located at the bottom front and under flap unscrew plug.Beware water will come out.
Sep 27, 2014 | Amana Washing Machines
GE Washing Machine won't drain or complete cycle model # WBCH6240F0GG
The power line might flick. That's why not complete cycle.
Before do any repair, samply plug a alarm clock to the outlet that
the washer plug to. Leave there for a while about 1 day. If it blink that mean there a flicker on that line or may be some other line as well.
If power line is flickering. Fix the line (Do not fix the Washer!)
Mai Lor
Feb 25, 2013 | Washing Machines
Im not getting enough water when washing clothes. sometimes if im washing heavy clothes, like sweatshirts, they come out and I can see dry spots on the clothes where water hasnt saturated them. also, when...
Hello
The problem may be the drain line.Unplug washer and remove drain line.Inspect line for any debri or lint.Check drain line screen for anyhting cloging it.
Be sure to tiighten all clamps when putting drainline back on.
Check incoming water screens.These are on washer where water hoses connect,clean if needed.
Last,try a self clean of machine.This sounds like a high eff washer which should have a cleaning mode.
Sep 23, 2011 | Washing Machines
I have a Fisher & Paykel Smart Drive 601 washing machine. It will do a cold wash with no problem, however when i try to do a warm or hot wash, after about a minute of trying to draw water into the...
Check your fill lines going into the washer, my guess is the hot line is filled with junk. They have screens inside the end of the fill lines that get loaded with gunk, clean off the screen & your good to go
Nov 08, 2010 | Fisher and Paykel Washing Machines
This is the second time...there is sand in the washing machine after a wash (and sand in the sheets)
There is no other way that sand could have come in unless through the inlet water line or sand previously lodged into the tub into the clothing. To check this out remove inlet line and check for damage in filter.If not check inside your tub for traces of sand.Remove drain hose/drain valve and clean external tub to wash away all dirt using a jet wash.
hope this helps
Aug 29, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Indesit Prestige Line 822
i have this! 4 is a normal wash cycle 7 is a spin 5 an 6 seem to be quick washes an never tried 1 2 or 3!!! hope this helps!!
Jul 20, 2008 | Washing Machines
Washing Machine
turn down water pressure going to the machine and see
Nov 11, 2007 | Kenmore Elite 45986 Front Load Washer
Winter Sports Logo
63 people viewed this question
Top Salomon Winter Sports Experts
Arnie Burke
Arnie Burke
vtrktrmn
Are you a Salomon Winter Sport Expert? Answer questions, earn points and help others
