Washing machine does not spin or agitate
My washing machine does not spin or agitate but it still rinses can someone tell me what the problem could be?
  • Dan Harris
    Dan Harris May 11, 2010
    What type of washing machine do you have? Is it a top loader or a front loader?
    Novelist:
  • 101 Answers
It most likely is the coupler. It is located between the motor and the transmission. It is an easy repair and only costs around 20 dollars. To change it out simply unplug the washer and tip it back so you can work under it. The first thing you will see is the pump. Take off the two clamps with a flat head screw driver and move it to the side. Do not take off the hoses unless you want water everywhere. Next you will see the motor. The motor is held up by two clamps. The clamps have 2 screws in each one. Remove the screws and with your flat head pop off the clamps. Make sure you hold the motor cause when you take off that first clamp the motor will drop. The motor coupling will come off with it. Put your new one on, (it only goes on one way) and put everything back together again. You will be up and running good as new in no time again. Let me know if you have any other questions and let me know if this was helpful. Good luck and glad to help.
Posted on Jan 22, 2009
Why does not agitate on rinse cycle
It shouldn't agitate on rinse cycle. ''Quick wash'' is the last type of ''cycle'' you can select that the machine will ''agitate.'' On ''rinse'' cycle, it will fill with water and then simply drain & spin.
May 18, 2015 | Washing Machines
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Hi, our simpson enduro 701 washing machine does not spin back and forward in the deep rinse cycle. but operates ok and spins in spin cycle. thankyou Tina.
Hi Tina just read your posting. From the information in your posting the machine fills, then when the machine is full of water the agitator moves clockwise then anticlockwise until it gets to the rinse cycle then drains the water ,then it fills for the rinse cycle but does not move the agitator in the rinse cycle.Then it drains and spins the clothes dry .Is this assessment of your posting correct.If it is not 100% correct please reply to tell me what the machine is doing or not doing.If it is correct then the problem with your machine is the control board.Is your model the electronic one with the push buttons?Looking forward to your reply.
Jun 26, 2010 | Washing Machines
Agitator wil not move makes a growling sound but all spin cycles still work
Either the transmission is bad, or more likely the agitator dogs are broken. If you pull the top pieces from the agitator you can see the agitator dogs and tell if they are intact or broken. If they are good, the transmission might be bad. The only other thing will depend on if the machine goes through the wash cycle to the rinse and spin without ever agitating, or if you have to manually move it. If you have to manually move it, your timer is probably bad.
Sep 06, 2009 | Washing Machines
GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
Tell me more Is there voltage to motor? The transmission makes it agitate .
May 28, 2009 | GE WBSR3140DW Top Load Washer
Machine now only agitates and no spinning and rinsing
Check the lid switch for failure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 26, 2009 | Kenmore Washing Machines
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
Washing machine will fill,agitate,but not rinse or spin
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore Washing Machines
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
