Question about HP Compaq Presario C500t Notebook
Dumping memory on compaq c500 laptop
My laptop will run a few task and then go into safe mode and dump all memory
  • Anonymous Jan 30, 2009
    lol... i wish mine would dump all the memory...does anyone know how to dump ALL memory?
    Problem Solver:
  • 14 Answers
Run a memory test and hdd self test from the bios ....it should be listed under diagnostic in bios and if you get error hp would fix it for free if you are in wty
Posted on Mar 17, 2009
Memory dump error
Kindly start windows in safe mode by pressing F8 key while powering up, Goto device manager and uninstall any new installed drivers or device.
Regards,
Kaushik Patel
Sep 13, 2013 | Dell PowerEdge Computers & Internet
Show memory dumping and resart
It would help if you mentioned the OS version. Blue screen/memory dump is usually some driver or hardware error. First, make sure you run windows update to get windows up to date. Second, get all the driver updates from the hp/compaq site. Third, run the system file checker. You will need the Windows CD unless your system has a recovery partition. To run thew system file checker:
Start>Run>type in sfc /scannow <enter>
Note the space between the sfc and the forward slash. Also, note the two n's in scannow.
Oct 31, 2012 | HP 413670-001 - HP Compaq nc6320, nx6310,...
Blue screen appears & keep restarting
It is possible that the malware is to blame, in which case a computer technician will need to sort it out.
I think it may be a bad memory module or loose memory module connection.
Take care!
damnor01
Apr 28, 2012 | Acer Extensa Computers & Internet
When turning on it will only go to a blue screen says go to safe mode or get tech support but even in safe mode it will only go back to blue screen. Can't download anything or do anything. At the...
Try uninstalling a few unnecessary programs
Just run fewer programs or buy additional RAM click start right click on my computer select properties you will see all imformation about your computer including installed ram
or processor upgrades. Your computer is running past its specified limits. But remember that in this case the blue screen of death should happen extremely infrequently. If you see the physical memory dump blue screen much more often then the issue is clearly
click start right click on my computer,properties advanced scroll down to system and recovery open settings write and debugging information the drop down button select none
ideally, it should already be the default debugger for your system.
The Dr. Watson debugger program logs all information related to failed processes to the Drwtsn32.log file. In addition to this, the debugger program can be configured to create memory dump files related to the failed processes. You can refer these dump files to analyze the reason behind a process failure.
Perform the following steps to configure Dr. Watson as the default debugger program to record user-mode program errors:
  1. Open Start menu, select Run, type Drwtsn32.exe -I and then press Enter. This command sets Dr. Watson as the default debugger.
  2. Next, run the Drwtsn32.exe command.
  3. In the Dr. Watson for Windows dialog box, select the following check boxes:
    • Append to Existing Log File
    • Visual Notification
    • Create Crash Dump File
  4. Now, when your computer restarts after the STOP 0xC000021A error is generated, run the Dr. Watson command.
  5. Here, view the paths to the Dr. Watson and User.dmp logs.
  6. Open Windows Explorer, navigate to the log files and then open them.
  7. Here, check the cause behind the STOP 0xC000021A error.
also you might download and use this registry cleaner it is 100%totally free to use
http://download.cnet.com/ccleaner/
hope this helps you
Jul 24, 2011 | Computers & Internet
Physical memory dumped
to fix this problem, try the below steps. 1. as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key. one you reach the dektop..run a system restore if this as started happening recently. you can run system restore which will bring the computer back to an earlier time lets say few days back with the help of selecting the date in the calender in the system restore tool. To go into system restore tool click on start select accessories and the system tools and then system restore. Select restore my computer to an earlier time and click the date in the calender box once highlighted hit next and wait till the process completes once completed it will restart the system automatically and will give you a message your computer was restored successfully in case it says not restored then you can select another Bold date i mean a previous date to retry again.
2. boot to safe mode and folow the below steps: Edit the registry: Start then Run and type "regedit" Go to HKEY_LOCAL_MACHINE \ SYSTEM \ CurrentControlSet \ Control \ Session Manager \ Memory *Management and double click the DisablePagingExecutive value and enter value 1. Go to HKEY_LOCAL_MACHINE \ SYSTEM \ CurrentControlSet \ Control \ Session Manager\ Memory Management, double click on the Largesystemcache value and enter 1 as value to increase the size of the hard disk cache
please let me know if this helps. else we need to repair the os and will let u know the steps if this does not work.
Mar 23, 2009 | HP 285527-001 - Compaq Presario...
Dell Dimension 4600 Blue Screen
Usually this blue screen appears due a hardware issue or drivers conflict.
1) Try to boot in safe mode (hit F8 after starting up) and select "Safe mode"
If you don't get access try doing this:
2) Run the OS CD and use the option Recover Console (R)
This will fix the problem.
3) If the problem continues, you will need to install the OS again.
Oct 07, 2008 | Computers & Internet
My computer shut down windows to prevent damage from my computer
Try tapping the F5 or F8 key (could be either one) right after you power up. This should take you to a short text message with a couple of choices to continue; you'll find the Safe Mode option there.
Sep 27, 2008 | Compaq Armada E500 Notebook
Blue Screen of Death
Just use ORIGINAL OS CD and repair OS everything will work fine!
Dec 27, 2007 | Computers & Internet
Computers & Internet Logo
64 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
