Question about Refrigerators
How does the Corby trouser press hinge at bottom?
Something dropped inside the trouser press and now the bottom 'hinge' is detached. How can I fit it together again?
2 Suggested Answers
alicantecoli
  • 22326 Answers
SOURCE: I have an LG side by side with the freezer on the
Not sure exactly what you mean here as all the ones i have done have two screws for the door hinges ,now these prongs you refer to must be a newer version that i havent seen as yet so providing the casing hasnt corroded away and the plastic housing that these prongs go into has fallen away ,so they cannot push into anything ,i suggest you pull the freezer out and have a close look if need be pull turn it sideways and have a look up from underneath and if it has corroded then put a plate at the back and drill a hole straight through with a nut and bolt .cannot beat a good repair that will last for ever
Posted on Aug 26, 2011
How do I remove the door of Chevrolet spark
This is a TWO person job!
-Open the window all the way. This will give you something to use as a handle.
-Open the door and disconnect the wiring loom connector.
-Unbolt the door check strap bar between the hinges.
-Support the weight of the door and locate the hinge bolt on the door.
-Loosen, but do not remove, on both hinges.
-Get your helper to support the door as it might drop suddenly.
-Remove the BOTTOM hinge bolts first. Then remove the UPPER hinge bolts.
-The door should drop out of position.
REINSTALLING.
-Support the door in the open position.
-Fit the top bolt in the top hinge until finger tight.
-Repeat this for the bottom hinge. It will take some of the weight of the door.
-Refit the lower bolts for both hinges until finger tight.
-GENTLY swing the door closed to check it is not positioned badly.
-Reopen the door and tighten the hinge bolts as follows.
Top hinge, top bolt.
Bottom hinge, top bolt.
Top hinge, bottom bolt.
Bottom hinge, bottom bolt.
-Tighten until tight BUT do NOT overtighten.
-Refit the door check strap.
-Reconnect the wiring loom connector.
-Close the door to check fit.
Jan 23, 2018 | Chevrolet Cars & Trucks
So how do replace the foam pad in my Corby 2200 trouser press
here is corby's website. contact them directly and they will guide you.
http://www.john-corby.com/
Oct 31, 2017 | The Office Equipment & Supplies
How do I replace a low battery in motion detector for my Honeywell wireless alarm system?
Look on the bottom of the sensor, there is a tab/button press it in and pull outwards from the bottom of the sensor, it will hinge upwards and detach.
Inside you will see the battery which is easy to change..
Replace the battery - refit the sensor top first and push in at the base, Job Done.
Jan 23, 2017 | Honeywell Home Security
Heating pad is wrinkled so clothes come out wrinkled
I thought my old one was faulty so I bought a new one and still experience the same wrinkling problem!
Dec 22, 2013 | Corby Trouser Press 7700
I have a Corby 7700 pants press that does not press the pants
Here are the instructions for this product:
http://www.corbyofwindsor.com/store/uk/info/292/TrouserPressInstructions
Feb 14, 2013 | Corby Trouser Press 7700
Corby 7700 will not heat up enough to press pants
Here are the operating instructions for this product: http://www.corbyofwindsor.com/store/uk/info/292/TrouserPressInstructions#Operating_Instructions
How do I remove outer door hinge housing to replace with new one?
there are four screws holding the hinge on to the machine. two are visible in the hinge from the front but there are two inside the machine on the left side .turn off the power and water supplies drag the machine out from its place tilt machine back to allow a gap between the drum and cabinet then using a star shaped driver also called a Torx driver remove the two screw from the hinge and remove it.when refitting a magnetic driver is a great help to prevent dropping the screws into the machine a torch is advisable to see what you are doing I hope this helps
Sep 19, 2009 | Dyson Memory CRO1 Front Load Washer
Frigidaire gallery microwave door sags
Repairing the loose, detached hinge is simple.
First buy a pop rivet tool and 1/8'' or 3mm rivets for about $16 at lowes
Second remove the door. There is a little plastic pop tab on the inside top corner of the door by the hinge that keeps the door from lifting off of the hinge pins. Use a 1 inch putty knife or maybe a butter knife and pry from the bottom crack. Once tab is off the entire door can be lifted off.
Third, line up the little holes in the bracket with the little holes in the microwave face. Insert a pop rivet in the hole and squeeze the tool till it pops off. I put one 3mm rivet on the top hinge and one on the bottom.
No drilling needed on my Fridgidaire PLMV169DCd microwave. I guess u could drill a 1/8'' hole thru the microwave face and the hinge bracket if there isn't one on your model.
Mar 10, 2009 | Frigidaire GLMV169D Microwave Oven
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
