Question about Toshiba 36A50 36" TV
Toshiba 36A50 - No Picture - Just Bright Line
So I acquired a 36A50 for a deal - free (or was it?) It was working well for about a week and then the shadow like lines began at the bottom of the screen - this didn't bother me being this TV cost me nothing at this point. Then the screen (V-hold) began to mess up and the image was retained on the top 1/2 to 3/4 of the viewing area. Lastly it's gone to that bright white line of death across the center of the tube. I know it's a circuit or solder issue because when you smack it it used to come back on and work fine, now it'll just tease you and make you think it's gonna come back and it doesn't. So I want to know what to replace - I am fairly able to fix things, just need details on what and where to replace. Thanks! You're friendly trash scavenger.
  • Anonymous Nov 12, 2007
    Just a bright line across the middle of the picture
  • rnrkly5 May 10, 2008
    Toshiba 36A50 - No Picture - Just Bright Line problem, smack in the middle of set. sound is fine. please help
THE PROBLEM IS IN VERTICAL OUTPUT CIRCUIT MAYBE DAMAGE SOLDER CRACKS
Posted on Jul 06, 2007
Toshiba, 36A50 picture is a thin white line. Can this be repaired?
Yes...this TV may be repaired. The line you describe is in the center and is horizontal across the TV. You will need to resolder the vertical IC pins. This vertical IC is mounted on a large heatsink. Under the board you will see there are 5 or 7 pins that will have rings around them. Resolder these. And you should replace two or three capacitors that are next to this IC. A bad cap will overheat an IC and separate the solder grounds. If you can find my expertise page on this website, you will see the repair in more detail. Thanks for asking and show a few hands of support.
Dec 12, 2010 | Toshiba 36A50 36" TV
Toshiba TV (about 7 years old)
You had parts in the vertical deflection circuit failing, most common are the vertical output IC and possibly several capacitors also in the same circuit.
Sep 11, 2009 | Toshiba 36A50 36" TV
Toshiba 36A50 sound, light line horizonally on black screen
It is my guess that you have some intermitent solder connections in the Vertical output circuit.
Hope this helps,
Skyassoc
Jun 23, 2009 | Toshiba 36A40 36" TV
No picture only sound, Toshiba 36A 36" TV tube type
my friend if you open the tv carefully look to see if the tube itself has light, or if you have high voltage i coulbe many different things.wish luck!!
caypianan@yahoo.com
Aug 10, 2008 | Toshiba 36A50 36" TV
36" 36a50 tv won't turn on
My 36A50 suddenly shuts off losing audio and video. The red light on the on/off switch continues flashing until the set is unplugged.
Jul 16, 2008 | Toshiba 36A50 36" TV
Green picture
Your red and blue cables are unplugged from either the source or at the tv.
Component video uses a red green and blue signal. If the red and blue are pulled you will onle see the green. If the green is pulled you will see nothing.
Check your cables 9 out of 10 times its a loose connection or bad interconnect cables.
Jul 03, 2008 | Sony KP-51HW40 51" Rear Projection...
Vertical size of picture
You have a number of bad capacitors in the vertical circuit. If you can solder, you should be able to repair this yourself. I'll look up your model to get the parts needed.
Dan
Jun 02, 2008 | Toshiba 36A50 36" TV
Toshiba 36A50 Horizontal Line in the middle
  • the problem is most common & simple to repair at your home only at minimum cost by skilled technician.
  • as per problem is concern it is due to electrolytic capacitor failure in vertical output stage.
  • hope this will help
  • good luck.
Oct 21, 2007 | Toshiba 36A50 36" TV
Toshiba 36A50 problem with horizontal lines at the bottom of TV...
you'll need to replace bad capacitors on the vertical circuit stage , no expensive but you need the basic knowledge, and the tools to do it your self , if not . you need a tech depend on the tech 60 to 80 dls a shop 125
Jun 10, 2007 | Toshiba 36A50 36" TV
Toshiba 36A50 36" TV Logo
141 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
