Question about Frigidaire GLEQ2152ES Electric Dryer
HAD TO CHANGE FROM 4 PRONG TO 3 PRONG AND NOW DRYER RUNS FOR A
DYER RUNS FOR ABOUT 10-15 MIN AND SHUTS OFF AND IS NOT HEATING UP.
  • 1 more comment
  • steman Jan 22, 2009
    we purchased the dryer 13 years ago and just moved from a home that had 4 prong outlet to a home with a 3 prong outlet so i changed the cord last night to a 3 prong cord and now the dyer is not heating up and my wife says it is running for about 15 minutes and then stops and the lights start flashing.
    yes, i made sure of that but i will check again when i get home tonight just to make sure.
  • Mark Egan May 11, 2010
    Is this a new or used dryer?
    If used, did it ever work that you are aware?
    The timer function is separate from the heating function, and switching from 4 prong (leg 1, leg 2, neutral, ground) to 3 prong (leg1, leg 2, neutral) would not have any impact on operation. The timer motor will not speed up if incorrectly wired, only burn-up (with reference to the 15 minute comment.).
    President:
  • 1,214 Answers
When you connected the new cord, did you make certain to connect the line 1/2 wires to the Line1/2 input's, and the Neutral to Neutral inside the wiring compartment?
Not heating up almost sounds like the heating elements are not getting their full 220 VAC, but then if you had something wired wrong in back, a breaker should trip. Make sure you've connected the new power cord correctly at the input power point. I am guessing this problem occurred between the time that you had it at the old house, and the new house, with the power cord changeover.
Posted on Jan 22, 2009
I have a 3 prong wall mount outlet for my dyer and want to put in a 4 prong. how do I do it?
Veronica,
If you are talking about the outlet you plug your dryer into, that would require an certified electrician to make the change since that is covered by electrical codes. If you are talking about changing the pigtail on the dryer, you could do that yourself. Just remember to take the brass strip off that goes from the middle of power cord block to the ground. You have to separate the neutral from the ground in a four wire situation. Hope this helps!
Mar 06, 2015 | Dryers
GE electric dryer 1 year old
The heating element could be failing, causing automatic shutdown.
Oct 17, 2017 | Dryers
Why doesn't the timer count down? The dryer runs & heats but the Timer doesn't move. I replaced the Timer block but nothing changed. Is this related to a bad sensor?
go bak to 4 prong. why did u change it out? souns lik this isa 220 unit and not a 110? chk the book that came with the unit. lol.
Jul 22, 2014 | Maytag Dryers
Install power cord dryer
Before you change wiring check and see if its a proper cord for a 220 hook up. most three prong are for a 110 hook up. Ask an electrician for advice so you don't have a fire or kill yourself. Most Dryers are 220
Feb 25, 2014 | Dryers
Change Maytag dryer 4 prong plug to a 3 prong plug
The cover on the back should only be held on by screws and are usually easy to get off. Have you checked for these?
May 04, 2012 | Dryers
Need to change power cord on maytag dryer from 3 prong to 4
Always disconnect electricity before beginning this process.
All the 4 wire cords I have seen are color-coded. The white wire goes to the middle terminal, the green wire goes to any screw you can reach that goes into the metal case of the dyer. The red and black go to the outside terminals of the block and while it doesn't matter which color goes to which terminal I usually follow the color code of the interior dryer wiring that already exists. Good Luck.
Oct 04, 2009 | Maytag SDE3606A Electric Dryer
Dryer rune for a bit then shuts off - won't start
clean link from bottom of dyer and exhaust vent
Aug 07, 2009 | Kenmore 63942 Dryer
Frigidaire GLEQ2152ES Dryer Won't Power UP
IF you find that you have only a 3 wire feed for this dryer (and the reason for the 3 prong receptacle)...then you can not properly install a 4 prong dryer cord to it. You now have 2 choices....either rewire (assuming that it is a 3 wire supply) the entire run from the dryer breaker to the outlet location with 4 wire (typically a run of 8/3 with ground having a black, red, white and bare ground)and install a 4 prong dryer receptacle to match the configuration of the new dryers cord.....OR - you can remove the 4 wire cord and replace it with a 3 wire cord....re-using the ground strap - IF it is still in place.
Jul 11, 2009 | Frigidaire Dryers
How do you install a 3 prong power supply cord to a GE Dryer?
DO NOT CHANGE THE POWER SUPPLY CORD.
you can't change the power supply cord.
the cord came with the dryer is 240v. the three prong is 120v. the dryer will burn up. if you change the power cord without changing the regulator , motor, and the heating element.
you need to get a electrician to run a 240v double breaker from the panel to the dryer.
Apr 23, 2009 | GE DVLR223 Dryers
Changing cord from 3 prong to 4 prong on frigidaire dryer
The following link explains how to convert your appliance from a 3-prong to a 4-prong power cord:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
I hope this helps you. Let me know if you still have questions.
Nov 11, 2008 | Frigidaire GLER331A Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
179 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
