How do I play my vinyl through my pioneer vsx-527
Tried record deck phono leads into av but no output
4 Suggested Answers
SOURCE: Pioneer Surround Sound AV Receivers
I received the help I requested from the Pioneer Electronics Technical Staff which called me, and reviewed the differences, and gave me their suggestions.
Thank you,
Texjoh
Posted on Nov 08, 2008
  • 4234 Answers
SOURCE: play phono - vinyl records
You need to purchase a phono preamp (about $20) and then the output of the preamp can be connected to any line level input on the receiver (tape, CD, DVD etc.)
Dan
Posted on Feb 25, 2009
  • 506 Answers
SOURCE: output stage scheme for pioneer vsx-d1 channel floating negative.
It should be a push pull. The fact that you have negative voltage almost certainly means push pull. One side will be constructed using NPN transistors ran off the positive DC rail and the other side will be constructed using PNP transistors ran off the negative rail. I don't know the age of your amp but I know pioneer now uses integrated amp modules instead of discrete transistors.
http://pdf1.alldatasheet.com/datasheet-pdf/view/82968/SANYO/STK412-020.html
example of integrated amp module (sorry for the chinese)
Posted on Feb 11, 2010
I have a Kenwood KR V6090 tuner amp. Can anyone please tell me if I need a record deck with or without a pre amp fitted.
Hi. Some amplifiers provide power for a record deck (or you mean a vinyl record player). Some vinyl record player have their one amplification system, some don't. Those with the amplification system work fine on older amplifiers but others require a back-up power, like a transformer to provide power for the record player. You need to enquire with the store person on the type of record deck or record player you can use directly with the V6090. I had an early Pioneer Amplifier and a matching record player so that I could play the vinyl disc and LP's on full volume. Later I switched to digital Pioneer 7 channel. This couldn't accept the record player because it did not have a power substitute like the older Pioneer. So, when the record player plays, no signal is being sent to the amplifier and therefore, no music is heard, except from the needle.
Dec 12, 2014 | Kenwood Audio Players & Recorders
I have just purchased a belt drive turntable and want to play vinyl through the s-302. I've connected the phono leads to the aux3 connection but the sond is not loud enough. Can you advise whether I n
Yes you need a RIAA preamplifier for magnetic phonograph cartridges. It connects between the turntable outputs and the AUX (or any other) input of your AV receiver. The only other way to make it work properly is to get a receiver or amplifier with a Phono input.
Dec 07, 2013 | Denon S-302 Theater System
Sound cuts out on one channel while playing LP records VSX-1022
you have a short in the rca cable from phono to reciver. try a new cable. if problem is still there i would say your record player is shorted inside.
Mar 13, 2013 | Pioneer Vsx-1022-K 7.1 Home Theater...
WE are trying to use the pioneer reciever vsx 453 for our computer speakers. Any idea where we might plug in our input cable from the computer?
Hi you will use the 1/8" mini output on the back of your computer and plug it into any input EXCEPT phono on the receiver.
I usually use one that is easy to remember such as the CD or Video 1.
you will need a cable that has a 1/8" mini stereo plug on 1 side and a pair of male RCA jacks on the other they are available on ebay for about $6 shipped or at radio shack.
Jan 07, 2010 | Pioneer Audio Players & Recorders
I hooked up my T.52x turntable to my pioneer vsx-d711 receiver through the RCA input...nothing fancy. I have to turn my receiver volume all the way up in order to hear the records. All the digital media...
The signal produced by a phono cartridge is much smaller than a standard Line Level component produces. That is why the clas of equipment called PREamplifiers existed. Besides PREamplifying it to a level the rest of the circuitry can use it also modifies the frequency curve according to the RIAA standard to produce a sonically flat output. Without either process applied you will have weak, tinny sound from a turntable.
The Pioneer VSX-D711, like most modern AV receivers, is not equipped with a Phono Preamp. If the connector doesn't SAY Phono is won't do Phono.
Dec 28, 2009 | Stanton T.50 Turntable
Play phono - vinyl records
Dan
Feb 25, 2009 | Denon AVR-1602 Receiver
Connected record player
If this reciever dosen't a phono inpur you need a phono pre-amp you can get one on e-bay for about 15.00
Dec 07, 2008 | Pioneer VSX-D412 Receiver
No Phono setting?
Hi dtrain
Phono preamps are are considered to be a thing of the past by most main stream manufacturers, so they leave them out of modern amps... supposedly saving some expense in manufacture also. -the i generation mostly dont even know what vinyl is ... poor souls. The good news is you can get decent "bolt on" preamps to listen to your favourite records. It plugs in line with your turntable and aux input on your amp, and generally uses an external power source. you can go to here and get one online starting at around $30 plus delivery.
good luck, happy turntabling:)
regards
Graeme
Mar 09, 2008 | Pioneer VSX-D511 Receiver
Pioneer vsa e06
depends what audio outputs you have on the sky box,analogue (two phono usually red for right channel and white left channel)in which case just use phono leads to the phono inputs,Optical(toslink),connect an optical cable from the output to the optical input on the dvd channel of the pioneer,coaxial (spdif)connect to spdif input on the laser disk input of the pioneer,dont connect to the attenuated spdif.In the unlikeley event of the sky box not having any audio outputs,just use the outputs from the tv to the pioneer.The optical digital input gives the best quality on the vsa eo6
Jan 24, 2008 | Pioneer VSX-1015 Receiver
Pioneer turntable Pl-560 and Pioneer Receiver VSX-D409
No phono inputs?? You will need a phono to line level preamp to use aux input.
Nov 03, 2007 | Audio Players & Recorders
176 people viewed this question
 Grubhead
Grubhead
