Question about RCA L50000 50" Rear Projection Television
Rca m50wh725 rear projection tv.
I turn tv on and hear sound and then sound stops the on button blinks 5 times and ther shuts off. this happens with remote or tv button.
  • 3 more comments
  • Anonymous Dec 28, 2007
    TV will power on but no picture. Indicator light will blink 5 times then shut down. RCA 50WH725
  • fayf01 Mar 31, 2008
    I have RCA M50WH725. I bought it June 2007. It has sound but NO picture. Yes, the power light blinks. THe service center said the lamp is out. I couldn't believe it, a new TV and the lamp is bad. Because I no longer have my receipt, they said I have to buy the lamp at $186.06. I am furious. Walmart refuses to give me a copy of my receipt from June 15, 2007.
    This is obviously a defected part and this issue must be widespread since the lamp (part 3 270414) is on back order.
    I sent an email (via online contact) to Walmart and RCA.
    Fay
  • Evil E Apr 21, 2008
    Same problem mfg. date 8-2006 only I purchased a new lamp, when I pulled the old lamp it looked as good as the new one. I intalled the new lamp TV came on and ran fine until I turned it off, pulled new lamp and reinstalled it, TV came on and ran for about an hour, turned itself off. Do the same ritual just to get the same result, but will not start up any other way....,Please Help
  • Anonymous Oct 26, 2008
    I have the same problem I pull the bulb and put it back the tv works fine for a while then stops again.So i do the same and it comes back.any one
    know the problem?
  • superman35 Nov 14, 2008
    I have the same problem, my RCA manual said if it blinked 5 times the bulb may be bad. It also said the balast(thing that holds the lamp) might be bad also, so remember that when you go to purchase a bulb. My tv comes on clear as a bell then cuts off within 15 secs. then the light blinks 5 times and it cuts back on, the sound works the whole time. The usual methods of checking to see if a regular light bulb is bad doesn't apply to these bulbs I guess, because mine looks brand new. Who buys broke TVs?(ha ha) really not that funny. I did exceed the lifespan of the bulb by leaving it on all the time or having the screen to bright. Seems alot of trouble to keep this thing working, for life.
Blinking 5 times means the lamp is dead.
Posted on Jun 22, 2008
    Problem Solver:
  • 9 Answers
Pull the Lamp out. Is it shattered?
Posted on Nov 30, 2007
  • 432 Answers
It has gone into protection mode. This is caused when a short circuit is detected by the power management system inside the tv. Try a hard reset: Unplug the power cord for a full 4 hours; then try it again and see if it will clear the protection fault and reset it. If the reset does not help you will need to have a tech look at the set and take voltage measurements inside to determine which section of the tv has failed and what components will need replacement. The cost of repair is always over $200 and could be much more, depending on the specific parts that need replacing. If the ICs have burned out the repair is around $400. The flashing of the standby light may mean something, but I do not know the diagnostic code RCA is using; most RCA models do not have any diagnostic blink codes in the set. Hope this helps. Let me know if I can help further.
Posted on Jul 06, 2007
SOURCE:
65" projection tv will turn on and shut off before picture comes
the service light is blinking because you in fact need a new bulb also is why u have no picture
Oct 06, 2009 | Sony KP-53V75 53" Rear Projection...
Tv just cuts off and the power button blinks 5 times and stops
According to the service manual the lamp needs to be replaced.
Hope this helps,
Skyassoc
Jul 18, 2009 | RCA Scenium D40W20 40" Rear Projection...
No picture (fan& bulb do not come on) but there is sound
I have a RCA 52inch D52w136D, the power button blinks three times, but nothing happens no picture or sound
Nov 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
HD50PLW164 Blue LED blink 10 times fast 1 time slow , TV restarts
For clarification of code/blinks significance you should check at mfg web site .
Sep 15, 2017 | RCA HD50LPW164 50" Rear Projection HDTV
Tv repair
Does the power indicator blink? If so let me know how many blinks it blinks. Respond to this post so I have a way of keeping your symptoms and model number available for furture responses.
Jun 23, 2008 | RCA D61W20 61" Rear Projection Television
No picture no sound
Probably, the selftest fails while turning on. If this is the case, press input&menu buttons at the same time for 5 seconds, then the green led will start to blink. Let me know how many times the led blinks.
Regards
Mar 01, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Rca 61 inch projection tv model D61W20
Steve,
I have the exact same problem with my tv. same model. If you happen to find a solution, could you please forward it to me. I will be very appreciative. email me at [email protected] . I'll do the same for you if I find a solution.
Jan 20, 2008 | RCA D61W20 61" Rear Projection Television
52 RCA DLP 1080P Television with NO picture and buttons flash
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Dec 30, 2007 | RCA HD61LPW175 61" Rear Projection HDTV
RCA L50000 50" Rear Projection Television Logo
934 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
