Question about Freezers
LOAD CLICKING SOUND WHEN PLUGED IN TO ELECTRIC
WHEN I PLUG IN GE FREEZER (7 CU. FT. #FH7DXAWH) I GET A LOAD CLICKING SOUND FROM COMPRESSOR AREA
  • 1 more comment
  • sdb5299 Jan 22, 2009
    I didn't leave it plug in because it was so loud.
    If compressor is locked up, does that mean it's damaged?
  • Mark Egan May 11, 2010
    Does the unit then go ahead and cool/freeze? If not, the click is probably the start relay, and the compressor is likely locked up.
    President:
  • 1,214 Answers
Loud is ambigous when it comes to sound.
Is the noise a clicking sound, or is it more of a popping sound? Does a circuit breaker trip or fuse blow when you plug the unit in?
If not, does the sound occur every time you plug it in?
If the compressor is locked up, then that does mean its damaged. If the freezer is less than 5 years old, it may have a warranty, although you will have to pay labor and for any materials used to replace it.
Posted on Jan 22, 2009
  • 410 Answers
Did you just get the freezer or move it recently? this unit doesnt have any fans so I'm thinking the compressor is somehow out of place and when you plug it in the compressor is hitting its steel shell from the inside. remove the compartment cover on the side then plug the freezer in and see if the compressor is making the noise..
Why My haier model hcm070la Chest freezer the compressor is not kick on
check thermostat, or relay on one side or back cclose to the compressor area there is a removable lid. removed and look for a thermostat disconect the 2 wires and bridge them then plug the the freezer on if runs replace the temp thermostat for a new one should be freezer thermostat
Nov 07, 2016 | Haier 7 cu. ft. / 198 liter Chest Freezer...
GE Freezer stopped working
Obviously, the compressor is not running. Confirm the presence of power to the compressor itself. If it is getting power and unit does not run, you have an open motor winding OR if you have a start capacitor the latter could be defective. Let's hope that you have the capacitor because they go bad and are a lot cheaper to replace than the compressor!
Jan 19, 2014 | GE 7 cu. ft. Chest Freezer FCM7DR
Haier 5.3 Cu ft Chest freezer. power is on but compressor doesn't run. There is click sound but nothing happens after.
The click sound is the compressor starter relay closing but if nothing further happens it is likely that there has been a compressor failure
Apr 11, 2013 | Haier 5.3 cu. ft. Chest Freezer HNCM053E
THE COMPRESSOR IS HOT. CHEST FREEZER NOT FREEZING.
Sounds like you have a bad compressor. If you can check the amp draw.
Jan 18, 2011 | GE 14.8 cu. ft. General Electric Chest...
Yesterday, my dad brought me a working GE upright freezer from his house, transport time about 45 minutes. The freezer was working fine before he left his house, he did tip it little bit to load, unload...
You should try to un-plug the freezer and let it stand up-right over night to re-settle the freon back down inside of the compressor.
The compressor should normally get hot if it is doing it's job right, and there is a starter for the compressor motor (usually it looks like a large capacitor) that could have failed, or the defrost timer (if it has one) could be stuck, and you should be able to see the small dial on the defrost timer slowly turning, and if it does not turn, then replace the defrost timer.
Jun 07, 2010 | GE 13.7 cu. ft. General Electric Upright...
Won't turn on
To determine which component has failed please do the following.
Unplug the freezer wait 5 minutes and plug back in. Listen closely for any sounds by the compressor. If you hear a click or hum followed by a click the problem is the compressor and would cost about $400.00 to repair.
If you do not hear any sounds the problem is most likely the cold control or sometimes called the thermostat. The part number is WR09X10053 and is about $25.00
Apr 25, 2010 | GE 5 cu. ft. / 142 liter Chest Freezer...
My Ge upright freezer hums and then clicks,could it be my compressor.?
not necessarily. It could be the start components for the compressor. should test them out. Also, check compressor for grounded windings.
Feb 23, 2010 | GE 13.7 cu. ft. General Electric Upright...
Have a arctic air f22cwf freezer that will not freeze right
There is a starter relay on the compressor. It sounds like it needs replacing. If you listen for awhile when it trys to start the compressor there will be a clicking sound but then nothing will happen. That is the most likely cause.
May 05, 2009 | Arctic Air 22 cu. ft. Commercial Freezer...
Freezers Logo
199 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
