Internal problem an electrical short cut fries the component c516, r524 and r525, with the resistent i am fine i can make it work but the c516 is a capacitor and not look like any one else what is it they value??
    Sergeant:
    Champion:
  • 346 Answers
But you did not give the model number nor did you give the chassis number
Posted on Jan 26, 2009
Where to find the capacitor c515 c516 and ic ic206 for a sony tv. kp-fx 532m91
C515,C516, IC206 - you specify here are only the part numbers, and not represent the real value of the component. It is designated as the part position on the circuit board. The real values should be printed on each part. google.com/+GopakumarGopalan
Nov 25, 2013 | Televison & Video
I recently revisited my car after a few weeks out of my hands, and seconds after turning the key and the unit powering up, the sound of popping and shrapnel in the amp was heard and the smell of smoke...
What has probably happened is a short somewhere in the amplifier. Here are some possible scenarios:
1. When the new capacitors were installed, make sure that no solder shorted any pads on the circuit board to anywhere else.
2. There is probably a resistor upstream of the capacitors that has shorted but still appears to be fine. Look at the circuit board & follow the traces that connect to the 2 terminals of each capacitor and follow them to other components. Examine them very carefully. Pull on the wire terminals of upstream & downstream components to ensure they are solid. Check each side of the component with an ohm meter. If a zero resistance is given, or no (open) resistance is given the component could be in question. To properly check it out, one side of the resistor must be pulled up from the board, then check the resistance again. If out of spec, it would need replaced & then it would properly voltage limit the capacitors, keeping them from going up in smoke.
3. This can be a very tricky problem without a schematic. See if you can get your hands on one, it makes circuit tracing much much easier
Mar 17, 2011 | Kenwood KAC-9104D Car Audio Amplifier
My Kenwood KAC-9105D amp quit working in the middle of a song. The music was loud, but I have had it louder before and it was fine. All the fuses on the amp and in the power cable are fine. The...
protection mode engages when there is either a crossed/shorted speaker wire, an incompatible speaker or a blown speaker with fried voice coils.
check your wires for shorts and/or loose strands of wire, your speaker ohmage (should be single coil, 4 ohm) and your speaker's operation. if you push the speaker in about an inch or 2 and there is some resistance, like its sort of scratchy when it moves, then the speakers voice coils are fried. speakers should push in and out freely, with no scratchiness or resistance, until they bottom out at 1 to 2 1/2 inches.
if it is not the speaker or the wiring, then the amp is damaged.
Nov 06, 2010 | Kenwood KAC9105D Car Amp
ALL FEATURES WORK FINE; HOWEVER, LAST NIGHT THE IT STOPPED HEATING THANKS, DAN
first if no power check the internal ceramic safety fuse, then check the H.V. diode for front to back resistance(hi one way-low in the opposite direction),then check your H.V. capacitor for being open(if its shorted it will blow the internal fuse), starts with some resistance on up to no resistance(carefully discharge the cap before doing any of these checks),these are your most likely suspect components if you have some power,but no cooking
Feb 23, 2010 | Maytag MMV4205 Microwave Oven
Can a malfunctioning capacitor suppressor in an angle grinder blow a fuse
yes .. the capacitor is across the line to reduce EMI ... (electrical noise ) if its shorted then it will blow a fuse .. its easy to check with an ohm meter once at least one end is disconnected .. it should read open ... if its bad it will read low resistance .. you can run the tool for a short time without the capacitor to see if something else is wrong .. your problem could also be a shorted line cord..
Oct 16, 2009 | Saws
Microwave goes on but does not heat
  • Magnetron is fried. Resistance between the magnetron terminals should be less than 3 ohms. Resistance from the magnetron terminal to ground should be infinite.
  • Fried HV capacitor. Use your ohm meter to test it.
  • Fried control board. If power is going to the board but not going off to the other components, the board is bad and needs to either be replaced or track down the bad connection (GE/Hotpoints).
  • HV Rectifier is shorted or open. Test forward and reverse bias with a megohmmeter. If continuity in both directions, rectifier is shorted, replace. If no continuity in either direction, rectifier is open, replace.
  • More help on testing specific components inside your microwave oven in this handy chart.
Aug 14, 2009 | Oster 4877 / 4878 / 6209 Toaster Oven with...
Stoped heating and had a smell like somthing electrical was burning? Fix it or buy a new one?
HI, normally, when you smell the burning electrical wires and board components, this will confirm a major capacitor malfunction. in this case, all electronic component will be fried or destroyed. these parts are the running diode,magnetron tube,cut-off fuse,noise filter and control board as well. all these parts will be costly to replaced, and it will be more cost effective to just cut your loss and purchase a new unit. the newer unit will be cheaper than the actual repair bill in this case.
Aug 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
SONY KDP65XBR2
Those are capacitors, probably on the "D" board or "G" board. What is/ was wrong with your TV?
michtech
Feb 16, 2009 | Sony Grand WEGA KDP-65XBR2 65" Rear...
10yr old bryant 90 series
Something is shorted out somewhere in the system.
You will have to trace down each component to find the short if it can't be found with a visual inspection.
Does the board have a low voltage fuse on it?
Dec 17, 2008 | Kitchen Appliances - Others
Prima cr-20sb72 tv
start with products to specs or contact support.
http://www.primaamerica.com/support.asp
Apr 03, 2008 | Prima C2012 TV
Televison & Video Logo
Top Televison & Video Experts
