Question about Radio Communications
I have just aquired two maxtrac d37mqa5g2bak but I do not know what freq range it operates. can you help?
  • Radio Commun... Master
  • 1,654 Answers
The Maxtrac radio beginning with D37 is a 900 MHz model.
Posted on Jan 23, 2009
Want to use astatic d104 mic for motorola maxtrac two way radio not a cb radio
With using a D-104 on a Maxtrac, you will probably need an audio amplifier.
Tom
Feb 13, 2014 | Radio Communications
Tk-3200 displaying unlock, which component is faulty?
It may be that the freq entered or programmed into it is beyond the expected range of that radio. Need more specific details. Usually probs of this nature involve a voltage controlled oscillator whos voltage varies according to the freq. It needs to be within a certain voltage range between the lowest and highest programmed freqs....if not the unlock message appears. Look up the radio on the net and determine if you have programmed it with the freqs it was designed to operate on.... first. Is it UHF or VHF?
Dec 03, 2013 | Kenwood Kpg-88d V1.32 Programming Software...
Scanner not picking up local police-Fire freq
Do you still receive NOAA weather frequencies? Sounds like your local agencies have switched from simplex/standard frequency operation to trunking. I suggest you visit www.RadioReference.com to view the latest on active frequencies and systems in your area.
Bill B
May 17, 2010 | Radio Shack Pro-94 Scanner
Rick to maxtrac, is it the same a radius
Yes, if you have the 16 pin connector. (The 5-pin connector is not a compatible version.)
Feb 02, 2010 | Motorola Radio Communications
Bands covered by Furuno FS-1502
It doesn't appear to cover the ham bands, only maritime. This radio is also not type approved for operation on ham bands either.
You can find the freq. range in the manual at the link below:
http://www.furunousa.com/Furuno/Doc/0/AHHEA1GA2ITKN04R23GBMOTKF1/FS1502%20Operator%5C%27s%20Manual%20Vu.pdf
Nice Radio though.
Sep 12, 2009 | Furuno FS1503 (199 Channels) 2-Way Radio
Programing scanner
Hi tina33, I have an 860 scanner,and this is how I do it. If there is no freq's in there yet, start on channel 1 and punch in the freq- hit E and it will enter it into the first channel. Hit manual to go to ch 2 and repeat. If you need freq's for your area, go here and search out your state and county and it'll give you a list of freq's for your county.You do not have to add the weather channels as their in there already, just hit the weather button. I use an external antenna on mine as it extends the range and allows me to pick up the cars as well.
http://www.radioreference.com/apps/db/
If you need a book for your scanner, you can get one here, just print it out.
http://www.uniden.com/pdf/BC860XLTom.pdf
Hope this helps,, Mechanic
Jan 22, 2008 | Uniden BC248CLT Base Scanner
What's the channel frequencies for a common 22 channel motorola 2 way vhf radio?
Not sure what you want.....VHF band ius approximatly 130mhz to 175 mhz..... in that VHF band there is a commercial VHF band aprox. 155 mhz to 175...... the amateur radio vhf band is aprox. 135 to 150mhz.
With amateur radio, any freq in that range can be used...... with commercial radio the FCC cangive a company any freq. in that range also.
If you are looking for FRS/GMRS frequencies they are UHF freqs not VHF.
So I'm not sure exactly what you want......sounds like you might want to program in FRS freqs into an Icom amateur radio. If thats  the case you will need an Icom that will do UHF freqs.
Oct 12, 2007 | Unwired UFR650 (14 Channels) 2-Way Radio
Radio Communications Logo
60 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
