Question about Sony FD Trinitron WEGA KV-32FQ70 32" TV
Power The television keeps powering off with the LED flashing constantly
This equipment have a problem with the power supply in some cases are two transistors one fuse and check the horizontal output transistor
Posted on Jul 06, 2007
Tv is coming on for brief period and shutting down also constant flashing of green led light on front of tv
I have a plasma that does the same thing. I don't know but have been told it is probably the power supply.
Jan 11, 2013 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I had water damage in my wall an my power strip got wet. Now my Tv shuts itself off after I turn it on before the unit ever comes on. Then the blue led power indicator light flashes.... U hope this is a...
Does it flash in a pattern or does it constantly flash - like 7 flashes then pause then 7 flashes? Or is it constant without pauses? Are you using a new power strip? It could be two things 1. Power supply or 2. Main board. is my initial thoughts. Have you opened it up to check the fuses, caps etc? If the power suply voltages look good its probably the main board.
Thanks,
michael
Feb 06, 2011 | JVC LT-52X579 52 in. LCD TV
Aquos lc40le821e. LED is blinking constantly at a rate of 1 blink / 2 secs. Cant get the tv on. Any ideas? Thanks.
Sharp LCD tv tend to have trouble with power LED light and OPC light flashes together?That what u having?Yes,this tv is having trouble with it tv Tuner signal board itself.This tv is still useable.By pushing the power button again and wait for awhile than the backlight will come on and work,Sometime Power and OPC LED lights flashes quit awhile.Just have to push power button and wait have to do this 3 or 4 times,before tv backlight to come to work.I have a Sharp Aquo my self 46' do this most of the times.
Jan 01, 2011 | Sharp Televison & Video
Timer light flashing constantly despite reset
Failed caps on the DM and the Power boards the V26 Chassis DM/Power repair kit from www.tvrepairworld.com comes with instructions and the cas and will usually fix the blinking led.
Sep 22, 2010 | Mitsubishi WD-62725 62" Rear Projection...
Panasonic TX-32LXD60 won't switch on. Red standby light flashes quickly and then becomes constant. TV Clicks and slight flicker then nothing. Can anyone help please ?
U have sound at all?Yes,than ur LCD INVERTER backlight board it dead.If power LED light keep flashing nothing on,sound or picture.Than the power supply board is dead.Must replaced the power supply board.Tries Websites Shopjimmy.com,Ebay.com to buy these refurbish boards.
Feb 26, 2010 | Panasonic TX32LXD60 32 in. LCD TV
I can't get Jabra BT 2050 bluetooth into pairing mode. I follow the instructions but never get the solid light. What can I do?
Booklet instructions for how to pair it with a new device are wrong. It tells you holding the power button will put it into pairing mode but it does not.
Pairing mode is done by turning off the ear piece, then holding both power and answer/hangup at the same time. The LED should flash fast 3 or 4 times and then stay on solid. You might need to hold just power till the very first flash THEN begin holding answer/hangup as well as power till the LED goes constant. I’ve also had luck when frustrated by just holding all 4 buttons at once.
Oct 10, 2009 | Jabra BT2050 Bluetooth Headset
Green led keeps flashing no power on
Please read the solution on this thread; I keep repeating myself :-(
Bad power supply
Sep 06, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
TV switched off and lamp is flashing red
you need to buy a new lamp you can order them on line or order from like a Bestbuy,no way around it
May 12, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
No POWER
How many times does the POWER led flash per second? (Dont worry about the OPC).
1x (steady constant blink) = Lamps or inverters
2x = Power Supply
3x = Main Unit
If i am reading it correctly, looks like the POWER led is flashing 2x, which means it is a power supply failure. Either way, your TV needs to have a board replaced, there isn't anything you can do to fix it yourself. Try locating your local sharp authorized service center to repair your TV (1-800-237-4277)
Mar 13, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
Sony FD Trinitron WEGA KV-32FQ70 32" TV Logo
95 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
