Question about Polaris Pb460 Polaris Booster Pump Replacement O - Ring
Seals are leaking on my PB4-60 pump
I have removed the volute and am looking for the best way to remove imperller in order to change the seals
  • 547 Answers
O.k. we will call impeller front ok ? take back cover off look at end of shaft slot for screw driver? put screw driver in slot turn impeller off .
Posted on Feb 11, 2009
I have a leak from the bottom of the pump
Also, check for the actual mechanical shaft seal, they leak, and appears as if it's coming off of the wet end. Making it look like the drain plug could be leaking, or the area between the volute which is the pump housing, and the cover, this would normally be a failed gasket or O-ring, depending on the brand. Sometimes just tightening the cover to the pump housing correct this issue.
Jun 08, 2015 | Pool & Spa
Want to replace the seal on a water way SD-10-2N11CC
open up the pump volute/housing body, unthread the impeller from the motor shaft. then remove the seal & replace it. NOTE*** ensure that the round doughnut part, dark color, of the seal half (with the spring looking thing) touches the white part of the other half. Most people when changing the seal, believe that the rubber parts of both halves need to touch. that is WRONG. Reinstall and assemble everything back in reverse.
Jan 04, 2013 | Aqua Flo External Pump
Jacuzzi pump motor leaks at the seal
This means that your pump seals are bad. They are an inexpensive part to replace luckily, but removing the impeller can be tough. There are a number of different Jacuzzi motor/pumps so be sure to get the right seal kit.
Briefly:
The trick is to stop the shaft from spinning while you loosen the impeller. FYI they don't usually come off easily, the older the pump the harder it is to remove the impeller.
On the rear of the motor there is a slot where you can put a flat screw driver into the back of the shaft to stop it from spinning. Once the impeller is off you can remove the volute (rear housing) and change the seal.
Let me know if you need more help.
Feb 29, 2012 | Home
My husband removed our AO Smith pool motor from the pot/collection basket and now he is having trouble getting the clamp assembly-volute back on. This is the clamp on the outside of the seal plate and the...
Use a synthetic lubricant like magic lube and lay a bead all the way around in the groove the o-ring sits in. Press the o-ring into place causing excess lube to ooze out. Wipe your finger around the whole mess to coat the whole o-ring and then be sure to lube the o-ring on the diffuser.
Once everything is coated the large o-ring should stay in place and the pump half should insert fully into the volute so you can install the band.
John
Aug 30, 2010 | Pool & Spa
My kitchenaid fills with water just fine and drains just fine; however when I run it it makes this horrible buzzing/grinding sound. Could it be the food grinder or the pump? How do I clear the grinder to...
You need to remove the lower spray arm, then the water volute that runs up the back needs to get disconnected by removing it from its rear clip (center of tub almost behind upper rack, next twist volute connector clockwise until you can pull the connector and upper supply volute tube apart. Remove connector from top of pump and then remove 5? torx screws to remove top of pump (filter plate) then look inside front section of pump sump area and locate two more torx screws to remove (on right) first sump inlet cover. The screw on the left is for the macerator (grinder assembly) cover. Pull straight up on the cover to expose the chopper assembly. Try not to disturb the chopper screen from it's location as it connects to the pump impellar shaft and is difficult to re-install. Clean any and all debris from the now open areas and re- assemble the pump.
Jun 12, 2010 | KitchenAid KUDR01TJ Dishwasher
How do i replace the gasket 2hp
better to just replace whole pump motor will start to squeal soon after
Jun 02, 2010 | Waterway 5 Hp 230 Volt 2 Speed Side...
How do I remove the Inlet and Outlet PVC pipes attached to the Volute? They may be sealed with a sealant or glue and am not sure if I need to remove the Volute bolts first.
You just have to cut the pipes in a place where you can glue them back together with a coupeling. If you overheated the pump though you may have warped the pipes and will need to go back far enough to get to good pipe and replace it all the way up to the pump. They just screw into the pump and you can seal the new ones with silicone or teflon stick or tape. Don't use pipe dope as it is not good for plastic.
Nov 02, 2009 | Polaris Pb4-60 Volute Polaris Booster Pump...
I have a Polaris PB4-60 Booster Pump with a leaking seal. I have removed the Volute and removed the 4 bolts that hold the bracket to the motor. How do I remove the impeller? At the store they told me it...
You need to lock the other end of the motor shaft and then spin off the impeller. If you would like a quote on the replacement seal, contact us at www.arrowpools.net
Jul 11, 2009 | Polaris Pb460 Polaris Booster Pump...
Removal and installation of diffuser and impeller kit
All jucuzzi pumps are some of the most difficult to repair.Pump front should seperate from body(volute) of pump by means of screws, or some kind of band. Diffuser should have ss screws, or
be held in plsce by notches or both. Impellor spins counter clockwise to come off. Can only remove impellor with impellor wrench, or very strong hand. Rear of motor must be held in place with normally a 7-16 wrench, allen head wrench or screwdriver. Depends on manufacturer of motor. Then impellor can be removed!
Should replace shaft seal under impellor. Can seperate body of pump from motor by turning four outer bolts on back of motor. Must mark rear cover of motor so lines up exact for reassebly. Ussually 1/4 inch socket wrench.Seal can be pushed out from back to front with the corrrect size socket and a very light hammer.
Try to factory Jacuzzi seal, they are better than aftermarket.
Coat rubber on seal with light silicone, and press back into place without touching or marring seal face. Best way is use other half of seal (spring piece) to gently but firmly reseat seal. Examine body from rear to make sure seal seats. Reassemble as taken apart, or just take to a qualified service tech at a well established pool/spa place. Kirk
Feb 13, 2009 | Jacuzzi Diffuser, 1 1/2 - 3 Hp...
Polaris Pb460 Polaris Booster Pump Replacement O - Ring Logo
450 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
