Question about Acer TravelMate TM2480-2705 Notebook
Can't find dc power jack
I have a acer travelmate 4003LCi and I can't seem to find a replacement for my broken dc power jack.  Even Acer Netherlands does not have it.  It has been temporarily repaired but a need a new one because it's a littel loose.  Can somebody give me an article number since I can't seem to find it via it's model.
    Genius:
  • Acer Master
  • 1,102 Answers
Take your laptop to a small pc repair store
i am sure it can be replaced.
I called around in my area and the major outlets can't replace it but when i called smaller pc outlets they all seemed to be confident in a replacement
Posted on Jan 22, 2009
How to replace the DC Power jack of my acer aspire 7735Z
Replacing a DC Power jack in any computer is no easy task. However, it can be done by any novice. First, get on ebay and see what jack you need. Search for you jack by entering Acer Aspire 7735z jack. Most of the new ones have the cable attached to the jack instead of the old fashion solder.
Next, Google this question and check out the YouTube videos regarding Acer DC Jack replacement. It will give you an idea as to what you need to do. You may want to take a video camera and record what steps you take when you take it apart so you can review how to put it back together. Also, get a sewing box or something so you can put the screws in a separate container for the order you removed them; ie: bottom screws; hard drive screws, DVD mount screw... etc..
You always have to start with the bottom and work your way to the top. You will have to remove the palm rest, keyboard, heat shields and any other piece of hardware to get to it.
YouTube is your friend...
Aug 12, 2014 | Acer Laptop DC Power Jack for Acer...
Acer 4320 won't power up
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test your acer travelmate 4320 ac adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Dec 12, 2012 | Acer TravelMate 4320 Notebook
My Acer Travelmate 7530 does not want to start up. Switch on button lights up green
Here below is possible cause and troubleshooting steps of laptop that can power on, hope it may help:Possible cause:
AC adapter failure.
Power jack failure.
Possible troubleshooting steps and repair solution:
Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
If you are sure that your laptop charger is malfuction, just get a new adapter from chargerbuy.com:
http://www.chargerbuy.com/replacement-acer-travelmate-7530g-ac-adapter-19v-90watt.html
Oct 28, 2012 | Acer TravelMate 7530 Laptop Charger...
Ard jack which iss it
If you can find a jack for that model then you can just see which hole on the board the center pin connects to. Positive is usually the biggest pin underneath in the center of the socket. The rest of the holes are usually
-ve / ground. Just paste this in Ebay search box.
acer travelmate 220 dc socket
Feb 14, 2012 | Acer Computers & Internet
Acer travelmate 5520 will not switch on when powered by battery or ac
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Sep 22, 2010 | Acer TravelMate 5520 Notebook
My travelmate3260 DC POWER JAck pin is pulled from
The power socket needs to be replaced, but it requires the laptop to be completely dismantled to get access to the power socket on the motherboard. I suggest you get a quote for this repair.
Sep 29, 2009 | Acer TravelMate 3260-4853 Notebook
Broken DC jack on Acer notebook
There is a site on the internet that gives a step by step on how to remove the covers and locate the broken part. Type in repair Acer. Also there are labs the will repair this most common problem...Is the jack broken or is the adapeter broken...
Apr 23, 2009 | Acer TravelMate 2480 Notebook
Acer 4003Lci laptop
where can i download driver for my acer travetmate 4003lci
Jun 09, 2008 | Acer TravelMate 2300 Notebook
Travelmate 4003LCi
try hooking it to another monitor.
Jan 26, 2008 | Acer TravelMate 2300 Notebook
Acer TravelMate TM2480-2705 Notebook Logo
96 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
