I recently bought a primare a20 amp. I've connnected it to a Denon 1550-ar cd-player. When i turn on the amp, i get this buzzing noise from my speakers. I've tried to ground the amp to the cd-player, doesn't work, same noise. Any solutions out there?
SOURCE: One speaker buzz when cold
It works fine for a couple of minutes the starts to hum. If you turn up the volume it masks the noise but is till audible, also the video switching cuts out. after examining the components I have seen some heat discoloration in the power suply area and believe it to be power for the video board. disconecting the ribbon cable form the video board the hum goes away, and so does any video wich does'nt matter for me because my monitor1.gif does all the HD video1.gif switching. hope this may help with some noise problems.
Posted on Feb 06, 2008
slasher2428
  • 48 Answers
SOURCE: No Sound From a Denon AV Amp
maybe your speaker are busted tyr to check it...the connection of the speakerwire sometime may be lose...or try check the wire to speaker by the tester, if had a rading continuity
Posted on Feb 29, 2008
SOURCE: Keep blowing out bass on speakers Denon 75rd
Thank you for responding. I called in an audio specialist to look at the whole system--he believes there is a problem with the amplifier. Will post what he finds out when he looks inside.
Posted on May 02, 2009
cjackHD
  • 71 Answers
SOURCE: Noise coming out of speakers connected to Denon AVR 1908
Check for nearby wireless devices and move them away. -If the audio output from the source device (i.e. DVD, CD player) is digital (i.e. PCM, DTS or Dolby Digital) you're on your own. I'd be willing to bet the output is analog (red and white RCA), because the "beeps" and "exploding sounds" you describe seem like it could be caused by interference. Try replacing the cables. Otherwise the issue is probably with your receiver.
Posted on Aug 11, 2009
Dvd whirring noise
All the disks I've tried have, although it's only been 3 or 4 (both home-made and original). It sounds like the motor and/or the head moving around. Next week I'll go to the store I got it from and bring a DVD is particularly noisey in the drive, and try it in their floor model to see if it's this particular unit or the model in general.
Parts Of BMW.
May 30, 2012 | Denon Televison & Video
Samsung makes buzzing noise, gets louder when volume is higher
you may be hearing a buzz from inside the set---it is not rare for a transformer or other part to vibrate hard enough to produce this kind of sound.
Another common cause is the surface the set is sitting on===if hard and not fully supporting the set evenly this can cause this problem also.
On a set like the one listed here it is likely coming from the power supply but can be from other areas as well.
May 25, 2012 | Televison & Video
Denon DCM-370/270 - issue playing CD's. A CD will
I would replace the audio cable from the CD player to the Denon amp, a long shot, if you have other devices hooked to the amp and plays fine, the problem will be in the CD player. However! if all sound sources have the same problem, the issue is with the Denon unit.
Mar 09, 2012 | Denon Audio Players & Recorders
Power amp 2 channel connection to Denon a/v amp
You don't mention which AR amp we're talking about.
I think you're trying to say you want to know where to extract the front channels from the Denon to feed the AR amp. Right?
That would be an output on the Denon to an input on the AR.
Basically, take an RCA cable pair from the Denon's Pre Out F & L and connect them to the (presumed) L & R inputs on the unnamed amp.
Set the AR amp at a reasonably high volume (if it has a volume knob) and leave it alone. Run through the speaker level adjustments on the Denon to match the Front to everything else and it will control the volume going forward.
May 28, 2010 | Denon AVR-3300 Receiver
I am trying to connect a Kenwood CD Player to the Denon amp. I am using normal av cable and connecting the output from the CD player to the ''CD'' jack of the Denon amp (no 2). I am not able to get the...
I agree with this answer:try to connect the CD Player output to the working input on the Denon Amp( say tuner remove it temporarily).
try if it works, then you have a good CD player
if not check if there is volume available on CD player , turn it a little bit higher, using remote control
check if the CD is reading the disk
check also the connector you are using
check if there is a known working CD audio inside the player
if still having problems state the model of your CD player
hope this helps, thanks for using Fixya!
Aug 22, 2009 | Kenwood Audio Players & Recorders
I have recently acquired a old Denon AVR3801 Home cinema Receiver. I have plugged it all up and switched it on, but although the system seems to work quite nicely, the amp itself makes a buzzing/humming...
The solution of leaving the thing on all the time would certainly work, but most of the time a buzzing sound inside a relatively robust audio amplifier is being caused by the huge transformer coil in the thing. Or wires that are in close proximity thereto.
In some ways, you're blessed that the buzzing is coming from the unit itself, and not through the loudspeakers.
Mar 06, 2009 | Denon AVR-3801 Receiver
53 people viewed this question
 Grubhead
Grubhead
