Question about GE 25952 Cordless Phone
Phone beeps & says Unavailable when I press talk to make a call
One handset has been doing this for a while. Now the other has started also whick leave me with no phone working. Help!!
  • vandy002 Jan 26, 2009
    Thanks for your input. I tried your suggestion and it didn't help. I did call customer service for help. They told me to dsconnect the power source first, then the phone line, then take the batteries out of both handsets and wait ten minutes. They said then to reconnect everything in reverse order. That helped the handset that just stopped working but not the one that hasn't been working for awhile.
    Thanks again!
I have this same system, and could like it if it didn't make people who call sound so far away and hard to hear. I'm thinking of getting rid of them.
But for your problem. The phones in the chargers often "loose contact with the base", for whatever reason it happens. Take them from their charger and place them in the charger for the answering machine main base for about 30 seconds. Then they will "reconnect themselves to the main base". Then put them back to their own chargers and they should be back to their normal use unless their batteries are getting weak.
They can not work without contact to the main base, you have to have the main base plugged in and hooked to the phone line.
Posted on Jan 26, 2009
My Uniden 1560-3 has out of range on all handsets but one. I only have a dial tone on one handset. Please advise how I can correct this problem
Reset the hand sets that are out of range by doing the following:
1) Press and hold END and # for at least five seconds.
2) Move the cursor to select Base Unavailable and then press Menu/Select.
3) Select the base which you want to de-register from, and then press Menu/Select. Base Unavailable appears.
4) Move the cursor to select Yes, and then press Menu/Select. You hear a confirmation tone,
(For DCX150 handsets)
5) Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
6) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
If the display shows Registration failed, repeat the process again.
(For DCX200 or DCX300 handsets)
5)Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding
find until the charge LED starts to blink.
6)When charged, registered handsets display a handset ID number. Handsets that have not been registered display:
7) On the handset, press and hold # until the handset beeps and displays Handset Registering.
8) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
User Manual Available Here
Jun 16, 2011 | Uniden Cordless Phone
Handset 2 show unavailable
hello
there is some battery problem with your phone please service it asap.
Jun 21, 2009 | GE 25841GE3 5.8 GHz Twin Cordless...
Ge 27831 Cordless dual phone 2nd handset doesn't work
Another user (thank yoiu but I'm sorry I forgot his/her name) had the answer. It was ihe instructions but I missed it. Needed to set the 2nd handset into the main base for 20 seconds so that it could align itself.
Mar 21, 2009 | GE 27831 Cordless Phone
Sync a new handset to kx-tg5632 phone
This works on MY panasonic; May work on yours too!
Registering a handset
The included handset and base unit are
preregistered. If for some reason the
handset is not registered to the base
unit, register the handset.
1 Handset:
{MENU} i {0}{0}{1}
2 Base unit:
Press and hold {LOCATOR/
INTERCOM} until the IN USE
indicator flashes.
LAfter the IN USE indicator starts
flashing, the rest of the procedure
must be completed within 1
minute.
3 Handset:
Press {OK}, then wait until a beep
sounds.
4 {OFF}
Registering an additional handset
See page 5 for information on the
available model.
Start from step 2.
Dec 29, 2008 | Panasonic KX-TG5632 Phone
Model 25922 5.8 GHZ Cordless phone with one main phone and two extras
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ge Telephone Solutions
Handset can not link.
• If any handsets become inoperable, place it on the main base cradle for 20 seconds to re-register.
No dial tone
• Check or repeat installation steps
• Make sure the base power cord is connected to a working electrical outlet.
• Make sure the telephone line cord is connected to the base unit and the modular phone jack?
• Disconnect the base from the wall phone jack and connect another phone to the same jack. If there is no dial tone on the second phone, the problem might be your wiring or local service.
• The handset might be out of range of the base. Move closer to the base.
• Make sure the battery is properly charged (for 16 hours).
• Ensure the battery pack is installed correctly.
• Did the handset beep when you pressed the TALK/CALL BACK button? Did the in use indicator come on? The battery may need to be charged.
http://www.home-electronics.net/ge/pc/IB/25922GE2_IB.pdf
Sep 02, 2008 | GE 26998GE1 Cordless Phone
"Unavailable"
you put it on the handset with the answering machine for a few seconds and that is how you register it.
Jun 27, 2008 | Uniden Cordless Phone
Phone Not Working
I have had the same problem before and now again for the last week...I finally remembered what I did last time to solve it!
I put my "unavailable" Handset into the main cradle and left it there for a slow count of 20. That has reset the unavailable handset and returned the dial tone etc.
Maddening isnt' it!
May 06, 2008 | GE 25932 Twin Cordless Phone
Tru9466 base and tru9465-2 handset
Same manual as lethean provided on a similar post but Page 24 if the previously used Base is Unavailable and your phone shows "Deregistration" in the Menu.
Base Unavailable (Handset Only)
To clear the base registration data in the handset, please follow these steps:
Press and hold [] and [#] for more than 5 seconds. Select the BASE UNAVAILABLE submenu.
BASE UNAVAILABLE appears. Move the cursor to select YES, and then press the OK soft key.
ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
Mar 10, 2008 | Uniden TCX905 Cordless Accessory Handset...
Motorola 580 handset not working
My handset does not connect to the base station. It flashes momentarily, but does not find the base. The base station has a humming noise when the phone line is disconnected and the talk button is depressed. Hum is also present when the phone line is reconnected. The problem was resolved by replacing the 9VDC power supply. The hum disappeared and the handset immediately connected to the base.
Oct 31, 2007 | Motorola Mobility MA580 (612572111116)...
GE 25952 Cordless Phone Logo
170 people viewed this question
Top GE Lands Phones Experts
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
