Question about Lexmark Color JetPrinter Z52 InkJet
My Lexmark X1290 is not printing clearly. Print has blank lines through black. Color is not printing yellow, red is light, blue appears to be OK I have the same problem. I thought the yellow might be empty in the color cartridge, so I installed a new cartridge. No change. Still red and blue, little/no yellow.
    Genius:
  • 2,120 Answers
Replace all ink cartridges.
Posted on Jan 23, 2009
My printer goes through the motion of printing but the paper comes out blank. I've an hp deskjet d2360 and there is ink in it
Possibility cartridge print head dry.
Solution 1:
Do a clean process
cartridge automatically. Press START - Control Panel - Printers and Faxes - HP Deskjet d2360 right click and select Printing Preferences - Select the Color tab - select Printer Services - select Clean cartridge, wait for the cleaning process is completed - Perform Test print. If the print test results, has good graphics, press Finish. If the graph is not clear or drop out, repeat the cleaning process once again.
Solution 2:
1. Open the cover printer, cartridges will move to the middle position.
2. Remove the cartridge (be careful, do not touch the element cartridges or print head by hand), then stick the tip cartridge (print head) to clean water
3. Then, attach the print head to a tissue paper. If there is a tissue paper used in ink (black cartridges, black block lines, and color cartridges, three color red yellow blue lines), means the flow of ink to the print head is normal. If the
tissue paper no trace of ink, attach back into the water, repeat the above process.
4. After process is complete no.3, clean the cartridges with a tissue paper (careful, do not touch the element cartridges or print head by hand, because it will damage the cartridge). After cartridge clear of the water, insert the cartridges into printer.
Sep 24, 2011 | Office Equipment & Supplies
Making Only megenta color copies no other color
When the blue color ink is finished it may print magenta instead of blue. And it is clear that black,yellow,red colors are there.
Jun 18, 2010 | Ricoh Aficio CL3500N Laser Printer
Lexmark z705 printing blank envelopes soft ware ok
The problem that you are experiencing is caused by the way the text is formatted in most word processing documents. By default envelopes are printed not in black, but a dark gray. This confuses the printer and causes it to use the color cartridge to process gray instead of using the black cartridge.
You can fix this problem with one of two ways:
1. Click on "Start", "Control Panel" and click on "Printers and Faxes." Right click on the "Lexmark Printer" icon and select "Properties." Click on "Printing Preferences." Go to "Quality/Copies" tab and select the option "Print color images in black and white."
2. You can also change the color of you text to a true black in your word processor. This will require you to resort to the word processor's documentation and help files.
Both of these settings will cause your printer to use the black cartridge instead of the color. If either one of these solutions solves your problem, it means your color cartridge needs to be cleaned or replaced. If you feel that the color cartridge should not be out of ink, please follow the steps given below:
Clean Nozzle Procedure:
1. Go to the "Solution Center" and click on the "Maintenance" tab.
2. Select "Clean to fix horizontal strips."
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzles" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
“Wicking” Procedure:
1. Select "Install color/black cartridge" and remove the cartridge from the printer.
2. Get a damp paper towel.
3. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
4. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
5. Next dab the cartridge on the towel to make sure that the ink is flowing.
6. Snap the cartridge back into the printer.
7. On your computer, select "Old Cartridge installed."
8. Repeat the "Clean to fix horizontal strips" procedure listed above.
If this procedure does not help, please let us know so that we can continue with technical support.
Oct 01, 2009 | Lexmark Z705 Inkjet Printer
Can print the color I want. Only prints red.
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Aug 24, 2009 | Lexmark X2350 All-In-One InkJet Printer
Wont print out document in blue print
Sorry your having this issue. Because Blue is a lite shade of Black, or a combination of red yellow and green ???? Point is even if you have only a black ink cartridge, or only color cartridge. Blue should be visiable and able to print.
Good luck, jasahasch
Aug 13, 2009 | Lexmark X1270 All-In-One InkJet Printer
Lexmark Z715 will not print but computer says it is printing
The Z715 needs a #50 black ink cartridge and a working color cartridge to print. To check if there ios ink coming out of your black or color cartridge touch the bottom of it to a paper towel and if you see a solid black blob or 3 blobs of Yellow, blue and red for the color then your problem is else where. If U are printing stuff from the internet sometimes the printer will try to use the color cartridge to print this so even though the black is working it comes out blank if the color is dry
Jan 16, 2018 | Lexmark X4650 InkJet Printer
Lexmark X1100 printer will not print black
I came up with a work around for printing black.
I changed the black cartridge with the color cartridge.
Then when I have a letter to print, I change change (or write) the letter text to yellow, red or blue.
Then I can print out a letter.
By printing the text as yellow, red or blue the cartridge will try to print with only 1 color, but will print out black.
If you do not use one of these primary printing colors the out put will be unusable.
I can not of course print out pictures.
Oct 04, 2008 | Office Equipment & Supplies
Lexmark Color JetPrinter Z52 InkJet Logo
266 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
