Question about Singer Featherweight II 117
Needle will not pick up bobbin thread - Singer Featherweight II 117
    New Friend:
  • 186 Answers
Make sure the needle is not in backwards, the flat side goes to the rear. If that doesn't help it may be out of time and needs to go to the shop.
good luck!
Posted on Jan 30, 2009
My upper thread wont pick up the bobbin thread suddenly. How do I fix that problem?
Install a brand new needle. A bent/dull/damaged needle sometimes will not pick up bobbin thread.
Check that the needle is installed facing the correct direction.
Also check that the bobbin is wound smoothly, the bobbin is turning the correct direction in the bobbin case, and the bobbin tension is threaded correctly.
If it still will not pick up the bobbin thread, there is most likely a timing issue, ie the needle is arriving at the wrong time to intercept the bobbin thread. Search the internet for sewing machine timing discussions or take it for service.
Nov 03, 2016 | Sewing Machines
Needle will not pick up bottom thread
Try a brand new needle. Verify it is installed correctly.
Remove the bobbin. Check that the bobbin is turning the correct direction and the thread is threaded correctly in the bobbin case. Reinstall the bobbin case and make sure that it latches.
Retest your machine. Manually turn the handwheel and watch the needle descend and see if the thread picks up the bobbin thread. If not, then the machine may have a timing issue. Take it for service.
Nov 01, 2016 | Sewing Machines
My Ruby Viking will not pick up bobbin thread
Install a brand new needle. A bent/damaged needle sometimes will not pick up the bobbin thread.
Verify the machine is threaded correctly.
If it still will not pick up the bobbin thread, most likely it is a needle/hook timing issues. There are many web sites and videos online explaining sewing machine timing. Or take it for service.
Aug 19, 2016 | Sewing Machines
When thread cotton. Cotton don't pick up bobbin cotton please help bernette65
Be sure to use a brand new needle. A bent/damaged needle may have difficulty picking up the bobbin thread.
Verify that both upper and bobbin threads are threaded correctly. If so, and it still fails to pick up the bobbin thread, most likely there is needle/hook timing issue. Take it for service.
The needle is not picking up the lower thread, I have cleaned the machine but the bobbin is not being picked up
Doesn't pick up bobbin thread
1. The bobbin may be in backwards.
2. The bobbin thread & top thread need to be pulled to the back before starting the stitching
3. You need a ballpoint rather than universal needle to sew on t-shirt knits.
4. the needle is in the machine backwards
5. Make sure the needle is the correct one for the fabric being sewed
6. Needle inserted wrong in the needle holder
7. Warped needle
8. Warped bobbin
9. Also could be a timing problem
Feb 10, 2016 | Sewing Machines
I am having problems with the bobbin its not picking up the bobbin thread through the needle
thread the upper part and the needle put presser foot down hold loose end of thread with felt hand and turn the wheel with right . the needle goes down shuttle wraps the bobbin thread around the upper and when needle comes up the bobbin thread will be with it . OR have yo MOMMA SHOW U HOW
Feb 18, 2015 | Sewing Machines
Needle thread will not pick up bobbin thread
Needle may need to be changed. Be sure it is the correct needle for the machine.
Feb 18, 2009 | Singer 7462 Mechanical Sewing Machine
Needle will not pick up the bobbin thread
www.whitesewing.com try there web site
Feb 18, 2007 | White Sewing White 3032
Singer Featherweight II 117 Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
