Question about Ryobi 18-inch Electric Chainsaw Chain Saws
My 18 V ryobi chain saw doesn't activate
I bought my chainsaw about 6 months ago, successfully used it about 3 times and stored it away. I tried to use it today and when I sqeeze the yellow trigger nothing happens. I charged the battery and charger light shows green. I cleaned out the chain area (there were some twigs and leaves that I removed). There's a little rubber bubble-like button on the top of the saw that when pushed there is the slightest sound of a motor, but really very, very slight and no motion.
    Problem Solver:
  • 15 Answers
Batteries need to be stored fully charged and recharged every month or so while in storage. Batteries need to be kept cool. Try another battery to see if the battery is bad or if the saw is out of order. Contact Ryobi @ 800 -525-2579 The full extent of your message did not appear on my screen. So I am not sure this helped you.
Posted on Jan 28, 2009
What oil does the ryobi use
all oil tanks on chain saws take Bar/chain oil this can be bought same place u buy 2 cycle engine oil most times , this bar chain oil most times is a 30W oil , if you change weights of oil then oil pump is not gonna add proper amount of oil to saw in use ,this will cause u problems !
Jan 18, 2014 | Ryobi 18-inch Electric Chainsaw Chain Saws
What oil does a ryobi cs216 electric chainsaw use ?
if you are talking about the bar chain oil (?) --- then all you need is just that ' bar/chain oil ' ,, you can get it from any hardware store that sells chainsaws.
now out here in the middle of nowhere Alaska where I am,, we just use used motor oil from our generators as a bar chain lube and it works just fine, ( not my ideal thing to use , but that is what the boss says to use and after 3 years here and using it -- I have not had any issues with our 4 saws that get over 3000 hours of use every year ).
I say -- use only good,clean and new bar chain oil.
c...
Jan 18, 2011 | Ryobi 18-inch Electric Chainsaw Chain Saws
Bought a Ryobi cs214 at a pawn shop. There is no oil in the holder for smooth running of the machine. Would like to know what kind of oil does the Ryobi CS214 takes.
Just fill the tank with regular bar/chain oil available at home centers, hardware stores, and saw dealers. Don't use old used motor oil or similar. Hope this helps!
Dec 21, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
I have only used my saw a handful of times and it has always done this since i bought it new at lowes. It wont lube the chain with oil and gets vry hot at the clutch it will go through a tank of gas to a...
I have the exact same saw. I bought it new 6 months ago also from lowes. It has the exact Same problems you are describing. It does not appear to be oiling the chain enough, the Chain is visibly dry,very hot , and dulls quickly. It uses a half tank of oil to a tank of gas. I am Also in search of an answer.
Oct 20, 2010 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
I bought a ryobi 14 inch electric chainsaw. Is
Use regular bar/chain oil available from home centers, hardware stores, and saw shops. Always keep the chain properly sharpened and tensioned so that you don't have to force the chain into the cut which causes motor overheating. If you need to make an 'under' cut, do so with the top of the bar--don't run the saw upside down. Good luck!
Jul 30, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
What size file do i use for a Ryobi chainsaw model PCN4545 to sharpen the chain
The standard chain file should fit it. It is about 3/16 dia. I found the dremel to work 10 times better, they have a little stone bit just for chains. Eventually, you have to take it in for sharpening, it will set all the teeth the same.
Feb 24, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
What is the gas to oil ratio for the Ryobi 10532 18 inch chain saw?
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Oct 18, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Ryobi 18" petrol chainsaw won't start
my guess is that you have a crack or a hole in one of your fuel lines. this is very common in chainsaws and weed eaters because they are used very little and sit for a long time. try checking this and repair if necessary. let me know if this works.
Mar 08, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Ryobi 18-inch Electric Chainsaw Chain Saws Logo
153 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
