Question about Hampton Bay Dryers
Installing hampton bay laminate flooring
Maraba Hickory
Buffalo12980
  • 625 Answers
SOURCE: Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Posted on Aug 22, 2007
Buffalo12980
  • 625 Answers
SOURCE: I need the default code for a hampton bay fan
I checked the hampton bay site and unfortunately whatever dip switch setting on the fan is, the remote needs to be matched to it. better get out the ladder!
Posted on Sep 12, 2007
SOURCE: Hampton Bay Remote
Hampton Bay Almeida 52" Ceiling Fan 52101916 ... Had fan installed remote fan would not go on ... nothing not even light ... changed batteries electrician that installed it said take it back to the store he would install another fan .. just bought fan last year HELP
Posted on Aug 04, 2008
  • 157 Answers
SOURCE: hampton bay fan, wall mount remote control
Hello burrow31. There maybe a switch located on the fan stating 'remote/manual'. Check your manual. Remove the battiers in your remote and short out the battery contact terminals. Reinstall the battiers, start the fan and after fan has reached set speed press & hold fan speed button for one second. Still no speed change contact the Mgfr. with model & serial #.
Posted on Oct 13, 2008
  • 26 Answers
SOURCE: Hampton Bay 52 In. Clarington. How do I reverse the fan?
Try these two: 1) look for a small switch up near the light area on the dark-colored area of the fan. If a switch is there, then simply flip the switch to the other position; 2) if you have a remote control for the fan, the reverse mode may appear on the remote control. Hope this helps.
Posted on May 19, 2009
Is Pergo the same as laminate?
Pergo is the name of a specific manufacturer of laminate flooring
make sure you follow all the instructions in the package when installing a laminate floor. They all have slightly different methods for success.
Jun 29, 2014 | Dream Home - Ispiri 12mm Americas Mission...
Laminate Flooring
Need more information.
Read our guide on laminate floors
Jan 23, 2014 | Hampton Bay Building Materials
Sealing laminate flooring
for determining that more information is needed, especially what type, brand/manufacturer, what thickness, base and chemical base of it...
in most cases sealing laminate (especially printed laminate!) is bad idea. if this laminate is with wood overlay at the top, with thickness of at least 1.5mm (1/16") and not chamfered edges (for skilled craftsman - floor installer, even 1mm) , then you can use any type of floor paint on the top,
you will need to wear chemical mask if you use poly or any solvent based paint, mask will not be necessary if you use water based paint. during sealer process - you can keep windows open, but not during painting... open windows will cause ripple effect on the paint!
prepare floor in following method:
sand very lightly (matt only indeed) firstly whole area with #120 or even #150 mesh and then with scourer of #180 or #240, if possible use rotary, do not forget to do edges of the rooms! and especially corners...
if this is "bare" wood then:
1. use universal sealer, use good quality paintbrush (50mm - 2") on the edges and corners of the floor and use good quality long hair roller on broad area, sealer will dry up within half hour to 1hr, depending on temperature and humidity, after seal dry,
2. paint directly over prepared floor with appropriate paint, suitable to the sealer and your requirements.
3. after 24hrs, scour area again in method as above and then
4. strain the paint and paint final coat.
5. wait at least 24hrs before you step on the floor,
6. wait at least 5 to 7 days before moving furniture in, especially haevy items!
7. wait at least 30 days before you put rugs or mats on the floor
if this is pre-painted laminate and no damage to it, you skip point 1 and follow from point 2.
it is labour intensive process and albeit cut can be made in several days, paint must be done in single go! better if you have some assistance, one person doing the edges and one person rolling the paint. i do this sometime alone but usually one of the ta's will assist me... paint need to be applied rather thick in even motions no puddles and no bare bits left on the floor!
if you think about skipping cutting stage - DONT! - paint will start flaking and peeling away sometimes in few days or weeks, sometime after a year or so...
Longview pecan reviews
always use laminate flooring cleaner or even windex will work in an occaisional bind. (Vinaigrette belongs in your salad.) Vinegar and water build up over time.
Jan 12, 2014 | Hampton Bay Laminate Samples: Longview...
Dogs and hampton bay laminate flooring
Yes, you can count on that. But if you leave urine uncleaned constantly.... flooring should be the last of your problems.
Apr 03, 2013 | Hampton Bay Laminate Tile & Stone...
What are the advantages of laminate flooring over hardwood flooring?
First, you can get the exact visual design that you wanted and it will cost you considerably less. Second, laminate flooring can be installed above and below the grade unlike hardwood flooring. Moreover, the laminate flooring is installed without using any nails or glue which make it much easier to it yourself. Furthermore, laminate flooring is extremely durable, easy to maintain and can be replaced easily.
Feb 06, 2013 | Building Materials
How much laminated floor should I get?
You get an idea on how much laminated floor you will need by measuring the length and the width of the rooms that you plan on installing laminated floor, multiply the length by the width and add 10 percent for installing errors and variation in floor design.
Light kit has light bulb size that I cannot find bulbs for
Melanie, you must have gotten a bad batch of bulbs. I have installed over 100 Hampton Bay ceiling fans and I have dropped them from up the ladder and have them bounce across the floor with no damage. I think they must have allowed a substandard batch to go out.
Home Depot is where I buy my replacement bulbs. Hampton Bay make fans exclusively for HD.
You can easily change lighting bases, as the wiring is the same for all Hampton Bay. You may even appeal to Hampton Bay on the internet and they might send you the kits. But I don't think you'd have success in a store.
If you try replacing them with bulbs from another Home Depot you may find them much hardier. I wish you the best of luck, and if you need additional help please write back.
Sirwriter
May 25, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Hampton Bay Remote
You must use the switch on the fan itself.
Aug 01, 2008 | Hampton Bay 52 In. White Redington...
Dryers Logo
547 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
