Question about Kenmore 64952 Electric Dryer
No heat My dryer is only about a year and a half old, and yesterday my clothes wouldn't get dry, so there is no heat coming from the dryer. If this is a fuse problem, how do I tell which ones need replacing, and where are they? Thanks.
  • tarheelbred May 06, 2008
    I have a Kenmore Elite dryer that stopped drying yesterday. The clothes still turn but cold air comes out instead of hot air. Is this a heating element problem or a fuse problem? Where are the fuses located on the dryer?
I had this same exact problem and it was a fuse on the back of the dryer itself.It was a $25.00 part I purchased at serv-all and easily put on myself in about 15 mins.Its worth a shot.If you have a serv-all near you they are great and will tell you how to do it.
Posted on Mar 29, 2008
Hello, How are you? If your house has older wiring, you probably have two separate fuses for your dryer. One operates the electric motor that turns the drum, and the other is for the heating element. You would have to locate your fuse box, open the front cover, and PRAY that there is a diagram stating what each fuse is for. (If not you will have to go through them one at a time until you find the one that is shot. Look at the diagram and locate the two separate dryer fuses, and slowly turn the counter-clockwise to remove them, then stand under a light and look through the glass part of the fuses top, if you see a complete wire running through the inside of the fuse, then it probably isn't blown, but you can just go and buy two new (30 AMP???) fuses and replace them anyway. I imagine you can get a pack of two for under 3 or 4 dollars. If you have replaced both fuses and the dryer still does not heat up, then I would suggest calling an electrician as it may be a sign of an electrical fault. When in doubt...Call a professional. Be safe, hope I helped. Kyle Mc slipdunk2@hotmail.com
Posted on Jul 06, 2007
5 Suggested Answers
  • 80 Answers
SOURCE: my electric dryer heats up but doesnt dry the clothes
If your vent hose is more than about ten feet long, your dryer may not have enough pressure to keep the air moving sufficiently to dry the clothes. Is it possible you are simply over loading your dryer?
Posted on Jan 25, 2010
hunter19_46m
  • 7482 Answers
SOURCE: Hi There, My Roper dryer stopped drying clothes
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For further instructions on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Oct 05, 2010
hunter19_46m
  • 7482 Answers
SOURCE: Dryer was not drying clothes. Replaced thrml-fuse,
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape and running the dryer to check to see if the element is red or not,
or with an ohm meter check the two terminals of the thermostat/thermister
after you have removed the wires, the thermostat/thermistor should have/show continuity across the terminals.
If the coil heats up, or the thermostat/thermistor shows an open circut
then replace the thermostat/thermistor as it is defective.
If it overheats the dryer will not operate properly.
You can test it with an Ohm meter/continuity checker, if no continuity,
replace it)
For video and pictures on how to replace the an element go to the following website, it will give you an idea what you are in for:
Posted on Jan 05, 2011
mc1bean
  • 3053 Answers
SOURCE: Kenmore Elite Dryer, front half
Hello, slhawes I was trying to helpyou out here. I am not sure if this well help you, but here is a link to abouteverything you want to know about your dryer, from repair to trouble shootingit. If you go to this link and click around, I am sure you will find out so muchabout your dryer, you will know more that the company that made it. Here Is thelink for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helpedyou at all, if you can find the time to rate my help and some kind wordswritten would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Posted on Oct 26, 2011
Dryer is not heating.
you need to return it from the seller
Mar 27, 2012 | Dryers
Yesterday i was drying clothes and then all of a sudden it is running but not putting heat out...when it finishes the clothes are not wet not really damp but not dry
Heating element needs to be replace. It made by several sections to produce heat. some section are bad so heating didn't come on with its full capacity.
Apr 24, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I have LG DLE2101W just installed yesterday. It
I found your manual and learned yours is a GAS dryer... the FIRST check is to be SURE the gas valve to your dryer is OPEN.
There is a Troubleshooting section, but NOTHING about no heat?
Know that LOW gas pressure CAN be a issue too!
I did find this:
"If the dryer no longer heats then the heating element may have failed, but it is not the most common cause. The most common cause for a dryer to stop heating is a blown thermal fuse."
The SECOND Link will be VERY helpful...
More help?
Cause 1 Thermal Fuse
Cause 2 Gas Valve Solenoid
Cause 3 Igniter
LG DLE2101W Support Manuals Warranty More LG
LG Dryer Not Heating
Thermostat
IGNITER
Dec 24, 2017 | LG Dryers
Dryer does not heat up/ dry clothes
sound like heater or stat call them out.
Sep 28, 2009 | LG DLE7177 Dryer
Take too long time to get cloth dried
how much are you putting in ? Is it a 220 volt dryer? May have a dead line (electris) to heating coils, or thermaostat is not functioning and letting the dryer coils get to operating temperature. Your heat setting control may be faulty. I wouls look at heat control first.
Jul 02, 2009 | Frigidaire GLER341A Electric Dryer
Dryer no longer has heat to dry clothes
The element gets brittle and breaks. The element is in the rear of the dryer under the dustcover.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 06, 2009 | Kenmore Dryers
Hello: I have a Maytag, do not know model # as I inherited the 5 year old model when I purchased a condo and it is now 7 years old. The front of it states Maytag - Dependable Use, Heavy Dtuty - Large...
I ALWAYS START WITH VENTING WHEN CALLED WITH LONG DRYING TIMES BUT I HAVE SEEN WHERE ONLY HALF OF THE HEATING ELEMENT IS WORKING, WHICH IS PRETTY RARE. A NORMAL LOAD WOULD BE WHATEVER THE WASHER HAD IN IT WHICH WOULD BE LOOSLY FILLED TO THE TOP ROW OF HOLES IN THE WASHER TUB. THE ONLY OTHER QUESTION I WOULD ASK IS IF THE WASHER SEEMS TO BE SPINNING OUT PROPERLY AND IF THE CLOTHES ARE GOING INTO THE DRYER TOO WET.
Jan 10, 2009 | Maytag LSE7806A Top Load Stacked...
Dryer not drying
Check your lint filter. Put it under running water to see if the water goes through it. Chances are it is clogged up. Wash it and put it back. Should do the trick.
SGt 48
Jun 18, 2008 | Roper Dryers
LG DLG 5988 Gas Dryer Does not heat and does not dry
Same problem after 1 year of use. In the past couple of months, the Sensor and Cooling mode light stay on and unit does not dry.
Oct 08, 2007 | LG DLG5988 Gas Dryer
Kenmore 64952 Electric Dryer Logo
95 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
