Question about Ricoh Aficio CL7200 Laser Printer
Manual color registration in Service Mode on CL7200 printer
How can I manually adjust color registration in service mode on my CL7200 printer. Auto color registration keeps failing and the factory test pattern bars show registration out approximately 1mm.
    New Friend:
  • 23 Answers
Watch this video to see how to color registration adjustment
https://www.youtube.com/watch?v=Zo1Ckvo6hg0
Posted on Feb 07, 2017
    Problem Solver:
  • 8 Answers
Ok turn the thing on and then open it up and bingo jumbalio!!!
Posted on Jan 24, 2009
Error sc551. Replaced the fuser, but still have the error. Need to know how to clear the error code. I have found reset methods for other models online, but they do not apply to the CL7200.
try this press clear mode button then press 107 then hold stop button for 5 seconds. should go into service mode. select 5 mode then 810 follow instruction and then turn copier off then back on .
May 07, 2015 | Ricoh Aficio CL7200 Laser Printer
Tip
ERVICE MODE AND POWER SUPPLY CIRCUIT
SERVICE MODE AND POWER SUPPLY CIRCUIT
Purpose: To bring the color adjustment of each component into standard alignment.
Symptom of Misadjustment: If this adjustment is incorrect, component signals do not reproduce the corresponding color.
1. Input 1080i 100% Color Bar signal.
2. Enter the service mode.
3. To enter the Auto Calibration adjustment mode, press [6] button on service the remote control unit.
4. To start auto adjustment, press [1] button on the service remote control unit.
- In the auto adjustment mode, "Please wait" appears on the screen.
- Upon completion, "OK" appears on the screen.
TO KNOW MORE CHECK THE LINK BELLOW
http://electro-medical.blogspot.in/
google.com/+AjinGopakumar
on Feb 18, 2015 | Emerson Used Original LC195EM82 Remote...
Color calibrate registration cl7200
Never ever do a memory clear all on a color unit. As you discovered it changes all the color registration values. This is a very, very complicated adjustment and very time consuming. I am a color expert and have been for 25 years now. Unless youre a trained tech youll never figure it out. spend 120 bucks and call a technician sorry..
Nov 22, 2013 | Ricoh Aficio CL7200 Laser Printer
Color registration off
on the control panel, select "additional functions", then press "2" and "8" at the same time, and then press "additional functions" again. You should see a white screen with the words, copier, feeder, etc. Press "additional fuctions" and then press the "2" key. This will take you into level 2 of service mode. On the screen, select "copier", then "function", then "clear", and then select "reg clear", and then press "ok" in the lower left of the touchscreen. Press "reset" multiple times to get back out of service mode. Turn the machine off, and then back on. Press additional functions and go to "adjustment and maintenance". Select "auto gradation" and perform a "quick" adjust, and then a "full" adjust. This should bring your registration back. If you keep experiencing the problem, the secondary transfer roller located just before the fixing assy/fuser unit on the left side drawer that pulls out could have build-up in the bushings, or the transfer belt and drive rollers could be causing the problem too. Hope this helps.
Apr 12, 2011 | Canon imageRUNNER iR C4080 Color Copier
Ho do I get in to service mode on Ricoh CL7200 Thanks
Hold down up and down keys for 5 secounds then press enter key.
Sep 10, 2010 | Ricoh Aficio CL7200 Laser Printer
My Ricoh 7300 is printing but all the color are not lining up
Try running auto color registration adj from user tools/menu(try it a couple times)
If this doesnt clear it up you will need to have a transfer belt and or transfer belt assy replaced
--Drew
Dec 11, 2009 | Ricoh Aficio AP3800C Laser Printer
Ricoh service mode to reset
This is the solution from Ricoh website:
Please press Menu. Then scroll to Maintenance and press Enter. Scroll to Color Regist and press Enter. Scroll to Color Regist Auto Adjust and then press Enter to Auto adjust. If after completing the procedure the error persists, please contact your service representative for support.
I'm told this works as well...
On the main board put dip switch 101-1 on and then off and then enter 97 and press the aps key. Then power cycle the printer.
Jul 09, 2008 | Ricoh Aficio CL3500N Laser Printer
Color adjust error
problematic machine. transfer belt damaged(white spots ) for temp fix try manual registration from menu
May 09, 2008 | Ricoh Aficio AP3800C Laser Printer
ImageRunner c3200 Color Registraton
With my experience, it's not the registration nor calibration problem, it's either transfer belt is bad or inside the transfer belt is dirty or dusty as well as transfer rollers. here is what I do first
take the transfer belt unit out of the machine, take transfer belt out from the unit, clean inside of transfer belt with damp cloth and rubbing alch. clean all rollers and reinstall.
What it is if the transfer belt and transfer rollers are dirty and dusty, it slips and make it like it's not align. I think most of time it fix the problem with my exp. if not replace new transfer belt
Jan 15, 2008 | Canon imageRUNNER C3200 Copier
Ricoh Aficio CL7200 Laser Printer Logo
1,223 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
