Question about NEC MultiSync XV17 17" CRT Monitor
Vertical pinch on left hand side of crt
Have a frogger console with 19" CRT - RCA 19VMNP22. Picture is pinched in on both the bottom and top only on the left hand side of the crt. Right hand side is normal. Any suggestions or adjustments?
  • 286 Answers
You mean the picture on the left side is curved out? Or is it restricted to the very top and very bottom?
If you have the curve problem, look in the menu and see if there is a pincushion control and a pin cushion balance. Adjust the balance until both sides curve the same, then adjust the pin cushion control to remove the curve.
If you are only having the problem in the corners, look in the menu for a corner correction control and play around with it to see if it corrects your problem. If the monitor has no OSD (on-screen-display), then it may be too old to have these controls. You may have to open the unit and see if there are any physical adjustments (little potientiometers). You might want to leave this to someone who knows what they are doing since the high voltage circuit can have 25-35 kV. Considering the price of CRT monitors, you might be able to find a new one for under $50.
Posted on Jan 22, 2009
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
My RCA F36648 36" TV has only the bottom half of my picture working. The top half has horizontal lines that distorte the picture. It looks like when you pull a rake through the sand the lines that are left...
You have vertical output problems.There is distortion at the top because of a faulty vert. output i.c. or a faulty electrolytic capacitor.It's possible there may be a problem at your yoke also.It needs a professional repair.
Sep 29, 2009 | RCA F36648 36" TV
My tv doesnt show the complete screen and i need help on how to fix it
If this has a format or spicture size button the remote, adjust to format 2. If not , discribe the picture, if it is cut off top & bottom , you have a vertical problem, if it side to side,then you have a horizontal problem.
Sep 06, 2009 | RCA 36V430T 36" TV
The picture is drawn in from the sides
this problem we cal vertical fault..cause by capasitor is not in good condition at vertical area or loose solder at the vertical ic
Dec 08, 2008 | RCA F35673MB 35" TV
1/2 of picture is ok; the other one only lines. What is?
If it's the top half that's lines and the bottom is ok, it's a problem in the vertical deflection circuit. Probably a dried out electrolytic capacitor.
If it's left to right, that gets more complicated. Please provide more info.
Sep 04, 2008 | RCA 20F511T TV
Horizontal/Vertical Adjustment
Your XBox's User Manual should have details on this Settings & if you can't find it, you'll have to contact Customer Care.
May 12, 2008 | RCA 35V432T 35" TV
The screen picture bulges inwardly on the right and the left
you have defective horizontal linearity! replace the capacitor at the hot side mostly 160uf 180V or 160uf 160V.
Oct 02, 2007 | Recoton Advent Advent Q2035A 20" TV
Screen not centerd
If it is a RCA F27649 then it has what they call a bonded yoke, meaning the only adjustments to shift the picture horizontal or vertical are electronic adjustments via the service menu.
Feb 11, 2007 | RCA F27649 27" TV
RCA 27" F27189ET HOME THEATRE - No picture
Is unlikely the picture tube is bad,the description of the problem tells me you have a straight line from top to bottom that is an indication of a horizontal deflection problem and is correctable and inexpensive,just in case the line you mention goes from side to side the problem will be in the vertical circuit and is also repairable.To make things easier tap the set on the side just to see if it reacts,don't over do it ,if it does the should be a lot less expensive because it might just be loose conections.Be safe and call for assistance.
Sep 29, 2006 | RCA F27667 27" TV
Picture deterioration
Your whole problem my freind is dryed up capacitors. You should go, if you have the technical ability to replace these capacitors, to http://servicemanuals.net, download the schematic diagram, and start replacing the waveshaper capacitors in the vertical drive circuit.
Sep 23, 2006 | Sony KV-35V35 TV
NEC MultiSync XV17 17" CRT Monitor Logo
178 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
