Question about Dell W5001C 50 in. Plasma HDTV
Dell W5001C screen is green
While watching, the screen goes to solid green, no picture but sound. Picture comes back and then green after a few seconds. Green screen says longer then the picutre
headstrong
  • 233 Answers
SOURCE: Dell W3201C: No picture, No sound
Have the same model and same problem
probably It is a bad inverter board, in my case one of the 16 transformers is burnt out on the inverter board. still trying to find a replacement component. if not replacing the board is the only option or getting the inverter board repaired.
by the way, this TV has a Samsung panel: model LTA320W2-L03. so it needs parts for a Samsong not a DELL.
DELL does not manufacture or fix them becuase they don't make them
Posted on Dec 28, 2007
SOURCE: dell w3000
I BOUGHT A NEW TV.
Posted on Mar 22, 2008
SOURCE: Plasma no picture, fades to black from startup logo
UPDATE:
I finally isolated the problem, the problem has to do with the Y SUSTAINER BOARD not receiving enough/necessary voltage when turned on, while initially thinking it was just the yboard was the problem, i replaced the Y sus board with no success, with only further diagnosis, i discovered the board voltages coming from the powersupply, there are 5 voltages that relate to the Y sustainer board, VA, VSC, VS, VE, VSET. they all supply a certain voltages that all have to be supply the correct voltage in order for the y sustainer board to be working, well guess what, the VA line, which for my set needs 70volts, which upon startup quickly drops from 75volts to a jumpy 8.5-9.5 volts, which of course is nowhere near the 70 volts needed, so this quick drop in voltage is directly related to the screen fade upon startup, i found the problem now the real problem is finding a replacement power supply. hope this helps anyone with similar issues.
Posted on Mar 25, 2008
  • 3 Answers
SOURCE: dell w4201c hdtv plasma tv BLACK SCREEN, LOGO FADES OUT, SOUND REMIANS, HELPPPPPPP
the problem was the y-sus board, i had a local tv repair shop diagnos that much for me. although, he couldn't fix it i did some research and found a company in california, itritek.com, who could. you send him the y-sus board and the two buffer boards and he not only repairs them but he upgrades them. apparently the y-sus board gets too much heat and eventually goes out, sometimes the buffer boards are affected too. itritek.com replaces the components on the y-sus board with better parts which are more heat resistent. i believe this will help you with your problem. let me know...good luck.
Posted on Jan 21, 2009
SOURCE: no picture or sound but it is on
i have a 50in plasma that just went out the other day the tv comes on but without pic and sound how can i fix it
Posted on Jan 13, 2010
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
No picture
If you look very close at your screen (might need flashlight here), do you see the picture as a black screen? If so, your backlight may have died on the panel. Replacing the inverter board will fix that right up unless the tube (lightbulb) has burnt out instead of the board. Both are replaceable.. Check it out.
Aug 17, 2014 | Dell 221-9495 W5001C 50 INCH PLASMA TV...
I was watching my Dell W5001C and the picture just went out like the power was turned off excpet the sound was still on. In a dark room there is not a glow, so the picture is definetly out. I want to get...
THAT'S EXACTLY WHAT MINE DID. IF YOU HAVE SOLDERING SKILLS YOU CAN LAY IT FACE DOWN ON A FLAT SURFACE . TAKE OUT ALL 50 MILLION SCREWS AND REMOVE THE BACK. CHECK ALL THE CAPS THEY HAVE AN X CUT INTO THE TOP IF ANY ARE BULGING OUT THEIR BAD AND NEED REPLACING. REMOVE THAT BOARD AND UNSOLDER THAT PART OR PARTS AND REPLACE THEM WITH ONES THAT HAVE A N EQUAL OR PREFERABLY HIGHER VOLTAGE RATING. THEN HAVE FUN PUTTING IT ALL BACK TOGETHER.
Sep 10, 2010 | Dell W5001C 50 in. Plasma HDTV
No picture or sound but it is on
Jan 24, 2009 | Dell W5001C 50 in. Plasma HDTV
Black on bottom of screen
do me a fovor, i need your firmware version? to do this, press Input 619. in the center of the bottom of the screen, is three digits 5?.? please provide me with these numbers. you may just need firmware updates.
Sep 28, 2008 | Dell W5001C 50 in. Plasma HDTV
42 in dell plasma, no picture, sound works fine
if i tell you how i fixed it can i charge you?
Sep 22, 2008 | Dell W5001C 50 in. Plasma HDTV
Same problem: picture goes out
Sounds like you need to replace the lamp. The owners manual should show you how to replace the lamp. You can order the lamp through Sony on their website. Good Luck
Jan 24, 2008 | Sony KDF-E55A20 55 in. LCD Television
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Dell W5001C 50 in. Plasma HDTV Logo
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
