Question about EuroCave Comfort 260 Collector's Package Wine Cellar - Black
Eurocave digital thermometer
The digital temperature readout has quit working. I think this might have happened once before. Any ideas on how to fix it?
The digital temperature display on the EuroCave has a small lithium battery that can be replaced by removing the bezel around the display. This was all that was needed to solve the problem.
Posted on Jan 23, 2009
Keep gettinG LO thermometer when taking my son's temp. but quite Ok with others
The actual temperature may be below the calibrated range of the thermometer.
Sep 22, 2016 | Braun Irt 4520 Thermoscan Ear Thermometer
Beechams forehead thermometer instructions
Why not check out a non-contact digital thermometer? I think that would be easy for you to measure someone's temperature.
Catherine J. Davis
Non Contact Digital Thermometer
Aug 28, 2014 | Home
I have Marquis hot tub, Leisure Series, The Spirit, Model ESLS30X, serial # 0890608. My in-laws gave it to us. It's about ten years old but still works reasonably well. The one issue is water...
If you found a solution to this problem, can you tell me what it was? I have the same thing. Its a Marquis Spririt and it just doesn't get hot enough. There must be a way to "trick" the thermostat into letting the heater run longer
Dec 10, 2010 | Heating & Cooling
When plugged in, the compressor doesn't activate. When you press the test button, the compressor turns on. After doing that about fivetimes, the compressor won't even flip on? This is a Eurocave Model...
if you keep starting it it will quit any way . but this sounds like a start relay or a bad or run cap / but you could have a bad compressor also . and if running on a long ext cord it cause this problem so ck these / hope this has helped mm feed back pls ..
Nov 25, 2010 | EuroCave S256T Wine Cooler
In "Heat" mode, the displayed
You have something else going on. The tstat is probably sensing a remote temp. Is it hanging on the wall next to the furnace? Maybe warm air is coming from the furnace closet and fooling the tstat? Or an appliance or TV located too close to is, and heating it? If its quickly increasing the temp during unit operation only, it may be sensing air through the hole in the wall, directly being the tstat, where the wires come though to connect to the tstat. Try plugging that hole and test it. Or possibly the ceiling register that supplies air is facing the tstat, warming it by blowing hot air directly at it. If that's it, remove the grille and face it away. Not sure what else it may be. Hope this helps!
Mar 25, 2017 | EdgeStar Portable Air Conditioner ...
Frigididaire uprite freezer How does one figure the appropriate temperature setting
If you have a digital readout then set it for 0F...if you do not have the temperature read out then place a thermometer inside and adjust the thermostat till you get to the 0F mark..
heatman101
Sep 16, 2010 | Frigidaire Freezers
The unit woorks but there is no digital readout
there is a battery in the display - carefully pull the display out open, the battery compartment and replace with a new battery.
Jul 09, 2010 | EuroCave Performance 59 Undercounter Wine...
Incorrect temperature
under the oven knob is the screw that adjusts the temp. remove the knob and with a small blade screwdriver adjust the temp according to your wife's oven thermometer CW+hotter CCW=cooler
then on the back of the knob is a screw to adjust the position of the knob with respect to the marker
Apr 20, 2009 | Viking 30" Professional Select Built-in...
I have a Sunbeam digital meat probe thermometer used once. Now the display for thermo/temp comes up H instead of the temperature of the meat. What is wrong? Sunbeam digital meat probe thermometer has quit...
I left mine in a hot tub for well over an hour. It started reading room temp at about 125 degrees. It worked for me to put the thermometer in the freezer until the readings were correct. hope this works for you.
Feb 22, 2009 | Sunbeam 2370 MixMaster Series Stand Mixer
EuroCave Comfort 260 Collector's Package Wine Cellar - Black Logo
1,000 people viewed this question
Top EuroCave Furniture Experts
mike cooper
Jim London
Jim London
Are you an EuroCave Furniture Expert? Answer questions, earn points and help others
