Question about Euro-Pro Shark GI490 Iron
Fix shark flat iron G1462 will not stay on, keeps turning off
SOURCE: Shark Euro Pro Iron turns
I was having the exact same problem. It happened infrequently, then over time it got worse. I would jiggle the cable to get it to turn back on again, and that worked for about six months. Eventually the iron was unusable, I had to hold the cable in one spot and it would go on for about 30 seconds, then die out.
I decided to go on a little adventure inside the iron to see what the problem was. I was convinced the cable was frayed on the inside from rotating so much. After unscrewing the bottom, I found there was plenty of rust inside the iron, which had gotten all over the contact points from the AC cable from the wall connects to the heating element. If I moved the cable back and forth, I could hear it sparking and get a good connection.
It doesn't appear that the rust was from water leakage inside the iron, but rather steam produced while ironing. After cutting the wires and soldering the connection, the iron works fine again. It took about 1/2 hour to do from start to finish.
I would recommend getting a different brand, it only took mine a year from purchase date to fail.
Posted on Oct 02, 2008
rockitman187
  • 2559 Answers
SOURCE: It shuts itself off
The SHARK ELECTRONIC Iron is equipped with an electronic auto-off. The electronic auto-off switches the iron off if it has been left standing unmoved in any position (sideways, flat or upright) for approximately 7-9 minutes. A red light on the LED display panel will flash when the iron switches itself off. (Fig. 7) To switch the iron back on, just shake the iron side-to-side several times.
Posted on Jul 31, 2009
SOURCE: my shark steam iron is leaking when ironing
It is quite possible that this is a defect in the shark G1490F... I had the same problem and it was a crack in the water holding tank caused by tightening the two front screws (hidden) that hold the tank to the base... It seemed fine at first but after a full heating it developed a crack where it had been weakened when it was assembled... I suggest returning it or if warranty is up , throw it away and get something else..
Posted on May 26, 2010
miket756
  • 2702 Answers
SOURCE: shark iron wont turn on
take it back to were you got it from i think the regulator has just packed up
Posted on Jun 20, 2010
heatman101
  • 43501 Answers
SOURCE: iron shuts off
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
Shark iron g1462
the lights you witness are correct. once the iron has reached tempreture.
ensure the iron is stored in an upright position between ironing items if left laying down the iron may switch off as an anti-burn or fire safety feature as if left unattended. with the iron placed on its back plate with its point facing upwards the iron should stay on.
I hope this was useful.
May 14, 2014 | Irons
Shark g1468 auto shut off (iron won't come/stay on)
First let me say I HATE AUTO SHUT OFF!!! It sounds like it has wore out. the computer part that tells it when to shut off it not working. It would be cheaper to buy a new one vs fixing yours. If I were you, find an older iron that has LOTS of steam vents and NO AUTO SHUTOFF at your local goodwill, thrift store or garage sale.
Jan 06, 2014 | Shark Euro Pro GI468-FS Rapido...
Shark iron wont turn on
Jun 20, 2010 | Euro-Pro Shark GI490 Iron
My shark steam iron is leaking when ironing
May 23, 2010 | Euro-Pro Shark GI490 Iron
Iron shuts off
heatman101
May 15, 2010 | Euro-Pro Shark GI490 Iron
My Shark Iron leaks....
fill with water turn iron on max keep turning steam dial all the way to the right until you get to self clean hold iron horizontal and make sure you have a towel or something to catch water drips and debris coming out of iron let iron steam and spit water out until it stops on its own turn dial back to regular steam settings wipe residue off of the plate with a towel adjust temp settings back to normal
Aug 14, 2009 | Euro-Pro Shark GI490 Iron
Euro Pro Shark Iron
Thank you for taking the time to warn us and others about the euro pro shark iron. I will help spread the word.
Aug 10, 2009 | Irons
It shuts itself off
Jul 31, 2009 | Euro-Pro Shark GI490 Iron
SHARK IRON WITH TANK.GREAT BUT SUDDENLY STOPPED.
these along with coffeemakers have a thermal fuse for safety the fuse looks like a cilinder with one flat side and the other side pointed with a wire protruding on both sides. it is located inline with the heating element under the cover "Appliance Parts" on the internet sells the part
Apr 21, 2009 | Euro-Pro Shark GI490 Iron
Shark euro pro G 1400z
how do you replace the light bulb on a shark euro-pro iron?
Oct 27, 2008 | Euro-Pro Shark GI475 Iron
Euro-Pro Shark GI490 Iron Logo
129 people viewed this question
Top Euro-Pro Irons Experts
Henry  Thomas
Henry Thomas
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
