Question about Scorpion Toys
Installers Manual for Scorpion Expert Car Alarm
Alarm went off and dont know how to turn it off
Hi , not an expert on alarm/security systems so follow this link for some expert advice
Car Alarms 1997 Ford Thunderbird Factory Alarm
May 30, 2014 | 1997 Ford Thunderbird LX
My car alarm is stuck on and we cannot turn it off so the car won't start. We went and bought a new battery for the keychain sensor thing that you are suppose to use to turn off the alarm and it will...
Is the vehicle stock or is it a aftermarket alarm system.If it stock then just start the car and it should turn off.If it has a aftermarket system disconnect the alarm system.Installers will sometimes have a toggle switch located under the dash to turn it off.if not you may want to completely remove the system by unpluggin it for now until you have time to have it checked out.
Dec 02, 2010 | 1998 Pontiac Grand Prix
Hello my key turns but wheni try to start my car nothing its completly dead then a security flashes because all the lights come on if i left it sit for like 4 hours it starts agian. i thought i was my...
? Who said it wasn't? The alarm installers? That I wouldn't doubt. It sounds like the starter kill switch is causing the problem and that is part of the alarm. Locate the alarm then on the alarm locate the power wire, this is most likely mounted on the firewall. The mail power wire to the alarm should have a fuse on it between the power source and the alarm itself that you can remove. Removing that fuse will deactivate the kill switch. Never trust the Alarm installers answer since they make money by not having to repair their work it is always going to be something else causing the problem according to them. Especially if they think it may end up being a warranty issue.
Nov 05, 2010 | 2002 Saturn Sl
I brought a car that has a clifford matrix 10.5 remote start alarm and the owner lost the original keypad so i order one and i want to know how do i reset the alarm because the receiver thats in the...
the reset button is under the dash somewhere. Different installers like to hide them in different spots look in the kick panels or just get in there with a flashlight I've had installers put them pretty far up there. just make sure you don't pull on any wires.
I have also seen an installer put the switch in the glove box so give that a shot as well.
Jan 24, 2010 | Remote Start System
Toad car alarm - text alert texts when arming and disarming alarm
yes this is aknownprobplem to Scorpion (Toad), you will need to use relays on the trigger wires
Jul 16, 2009 | Vehicle Parts & Accessories
Need the wiring diagram for avh-p6400cd
owners manual
installers guide
i believe you will find what you need in the installers guide , and a manual just in case you need it .
J5
Jan 18, 2009 | Pioneer AVH-P6400CD Car DVD Player
Car alarm will not go off and the car will no longer start. 2002 Hyundai elantra gt Key chain damaged
If the car has a kill switch, this is causing your car not start because its connected to the ignition or starter. Sounds like the alarm system is defective. If it's aftermarket, you might want to take it back to installers. If it's factory, take it to the dealer. The remote ties into several features that require a trained technician to handle.
Aug 18, 2008 | Hyundai Motor 1998 Accent
Toys Logo
89 people viewed this question
Top Scorpion Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Scorpion Toy Expert? Answer questions, earn points and help others
