Paper holder arm for TI-5155 calculator
I need a paper holder arm for TI-5155 calculator. Can you please help me locate one.
  • cronin_dave Apr 09, 2009
    I NEED THE Paper holder arms for TI-5155 calculator
5 Suggested Answers
  • 106 Answers
SOURCE: Trouble Feeding Tape into Calculator
use a thin plastic card and put it on the load,maybe you have a paper on printer ,press feed and you vill clear all paper path
Posted on Feb 01, 2008
  • 168 Answers
SOURCE: Paper tape in my TI 5045, please.
Feed the paper in the back press the paper advance button while pushing the paper in the rear slot, and it should feed the paper through.
Hope this helps.
Good luck.
Mac
Posted on Feb 10, 2008
SOURCE: BOUGHT A HR-8TE CALCULATOR AND CANNOT INSTALL THE PAPER ROLL
First feed it through the back, then cut the paper to form a V then feed this from the bottom and finally when you push feed it grabs the paper! Why they never put this in the instructions is beyond me!
Posted on Oct 27, 2008
The V tip worked...but cut it not fold it like I first tried to do...and it worked perfectly
Posted on Oct 31, 2008
SOURCE: Loading paper
5/14/09-
Okay...It took me forever to figure it out but I finally got it. On the back of the calculator there is a slot (back meaning where the black cord is connected to the calculator). fold the paper to make a perfect straight line. feed the paper through there and press thee upward arrow. it should work.
hope I helped...=)
Posted on May 14, 2009
How do i load roll paper on TI-5033II
1. Turn on the calculator.
2. Open the printer compartment cover by pressing down on its front edge and sliding back in the direction of the arrow.
3. Fit the roll of paper on the holder so that it unrolls from the bottom, with the loose end toward the calculator.
4. Cut the end of the paper squarely and insert it firmly into the printer slot on the back of the calculator. Press the paper feed button until the paper is in the printing position.
A PDF version of the manual is available at:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0CCcQFjAB&url=http%3A%2F%2Feducation.ti.com%2Fmedia%2FE152CF808E0C46759750698A1FCC970F%2F5033sv&ei=tA9EVLWbIMKcigLO-4CABQ&usg=AFQjCNF6zdaotZAIlF-6DajAVKg0UMh54w&bvm=bv.77648437,d.cGE&cad=rja
Oct 19, 2014 | Office Equipment & Supplies
How do i load my printer paper ti-5045sv
To load paper into a ti-5054 sv calculator.
  • Turn Calculator on.
  • Press down on the front edge and slide in the direction of the arrow.
  • Insert paper on the roller so that the paper rolls out toward the bottom, and the loose end is closest to the calculator.
  • Cut of the end of the paper.
  • Insert the end of the paper into the printer slot in the back of the calculator.
  • Press the paper feed button ( karmahm_0.png) until the paper is in position.
Mar 17, 2011 | Texas Instruments TI-5045 SVC Calculator
Have a texas instrument paper printing calculator used can't figure out how to load the paper
To avoid paper jams, use quality bond paper. A 2ΒΌ-inch roll of quality bond paper is included with your calculator.
1. Set POWER=ON.
2. Cut the end of the paper squarely.
3. Holding the paper so it unrolls from the bottom, insert the end of the paper firmly into the slot on the back of the calculator.
4. While feeding the paper into the slot, press up until the paper is in position.
5. Lift the blue metal paper holder so it extends behind the printer compartment.
6. Place the paper roll on the paper holder.
7. To print, set POWER=PRT or IC.
Note: To prevent damage to the printer (which may void the warranty), set POWER=ON rather than PRT or IC when operating the calculator without paper.
Feb 05, 2011 | Texas Instruments TI-5032 SVC Calculator
We can't get the paper to go into the machine?
Installing the Paper Roll
1. Lift the paper holder so that it extends behind the calculator.
2. Make sure the calculator is plugged into an easily accessible
electrical outlet near the calculator.
3. Move the POWER switch to ON.
4. Insert the end of the paper into the paper slot on the back of the
calculator as shown. To avoid paper jams, use quality bond paper.
5.While feeding the paper into the slot, press and hold up arrow.
Note: To prevent damaging the printer (which may void the warranty),
move the POWER switch to ON when operating the calculator without
paper.
Nov 27, 2010 | Texas Instruments TI-5045 SVC Calculator
The paper roll holder is broken on one side. Can
For most models, the holders can be replaced. You can try Universal Paper Arm Holders if you can't find one for your specific model.
Mar 25, 2010 | Office Equipment & Supplies
Can't load paper in a TI-5032 SVC
I found the manual that explained how to load the paper. I do not need any future assistance. Delete my request for help! Thanks -
Nov 30, 2009 | Texas Instruments TI-5032 SVC Calculator
I have an Olivetti HD 9100 calculator. The paper
My texas instruments TI-83 has a dark scrren i can barley see the numbers what is wrong with it?
Aug 06, 2009 | Olivetti Office Equipment & Supplies
Cannot load new paper roll into the calculator so it catches
Replacing the paper roll involves feeding the evenly cut, uniform end of the roll through the fine slot located under the paper arm at the back of the calculator. (Even if the paper is only slightly wrinkled or cut unevenly, it will not feed through the teeth in the loading area.)
When getting ready to feed the paper into the calculator, envision your printout feeding out of the machine away from you and back toward the paper roll. Don't insert it upside down.
To get the paper feeding through once you have partially fed it into the teeth, gently tap the paper feed button. Once or twice should do it. (The button is located on the far top left of the control panel, indicated by an arrow jagged saw mark icon).
Then, slide the paper roll onto the feeder arm and you're in business.
Apr 09, 2009 | Sharp EL-1801C Calculator
Sharp EL-2196BL
Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
1. Lift the paper holder up.
2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
3. Insert the paper roll from the left side of the paper holder and make sure the paper
roll is set in the proper direction (with the paper feeding from the bottom).
4. Insert the leading edge of the paper into the opening directly behind the print
mechanism.
5. Press the paper feed key and feed the paper under the edge of the paper cutter.
Dec 07, 2007 | Sharp EL-2196BL Calculator
90 people viewed this question
k24674
