Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
21.5 hp intek start fine runs fine but when you throttle it up goes from idle to wide open
What do i need to do to correct this problem
  • 376 Answers
SOURCE: Stratton Briggs Stratton Intek V - Twin Engine 21
The oil is contaminated with water. Change oil and filter, if it has one.
Posted on Jun 14, 2009
SOURCE: 24 hp briggs intek vtwin won't start
This same thing happens to me and I resolve it by taking the gas line off in front of the carb and blowing air through it.....then it will run fine. I realized I could do this when I took the air cleaner off and fed it gas manually and it ran fine....and I also had gas pumping through the fuel pump. I'm not sure of the problem....either the fuel pump is losing power or their is something blocking the carburator intermitantly
Posted on Jul 14, 2009
SOURCE: 20 hp intec runs wide open
24 hp briggs. replaced cam, exhaust lobe was unhardened. now it doesnt fire on that cylinder. plug is wet. spark tester shows spark,please help.
Posted on Apr 02, 2010
SOURCE: 20 hp b&s runs wide open
sounds like the gov. fell out in to the oil pan. if you remove the gov. springs and let the gov. arm move up. it will fall out. no book will till you that. if that happend you will have remove the motor and pull the oil sump pan. and put it back to gether make sure you keep the motor up side down. untill you reajust the gov.
Posted on Jun 19, 2010
SOURCE: Briggs and Stratton 20 hp intek runs great idles
Check the vent on the gas tank if it is blocked it will cause a vacuum in the tank thus starving it for fuel
Posted on Aug 02, 2010
Will not idle
Reconnect the governor rod back on to the carby throttle butterfly correctly. When stopped the lever will hold the throttle wide open and as it starts the lever pushes /pulls the throttle closed to the idle stop screw
May 31, 2013 | 5.5 HP GX160 Engine
Hit the throttle it quits running . it starts right up fast idle ok cuts good .wide open throttle runs fine. let it idle and hit the throttle it dies, starts right back up. has new carb kit, fuel, spark...
Conected to the rubber induction boot is the impulse hose, it is a short curled pipe, make sure this has not split and is conected to the two nipples on the carb flange.
Aug 21, 2011 | Husqvarna ChainSaw 18 in Bar 32 HP Model...
I have a 24HP V-Twin Briggs that i blew up. I found the parts i needed and rebuilt the beast. It starts and runs but i cant get it to throttle down. I split the case again and inspected the governor....
A big vavume leak and or the throttle blade doesn't close or it gone ( missing). the carb should close all the way ( you can't look thiugh it) with the linkage off you should be able to run it by hand with good results. if you can find out the correct way to put the springs on and just move things around or gat a look at one thats working right and you may see whats put together wrong on yours.
Sep 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Motor runs wide open when set @ slow speed
It could be that the governor spring has become disconnected or has broken on an end where it hooks onto the throttle linkage. If the spring is OK & throttle linkage is not binding it could mean the governor drive inside the engine has failed preventing the governor from operating correctly. You may need to take the engine to a mechanic to fix the problem.
Sep 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Mar 30, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Engin runs wide open and will not idal
Us+ally the air cleaner has been put on backwards or the spring has been snagged or over tightened. the throttle spring. needs only slight tension to open the throttle++
Aug 29, 2009 | Briggs & Stratton Briggs Stratton Intek V...
I have a 1994 Yamaha 40 HP 3 cylinder 2 stroke engine starts and runs fine in neutral try to accelerate under load and it only will pull about 2800-3000 RPMs and wont go any faster it will rev fine in...
Reving in neutral does not mean the same thing as under load. If you need to pull 4500rpm under load and for an instant the load was gone, you would probably overrev to 6500. With the cover off and motor not running move the throttle to full forward. Look at your carbs and see if the throttle plates are wide open. If they are not all wide open take it back to the dealer. The throttle adjustment is off. You need the full range of travel from idle to topend.
Jun 25, 2009 | Light Outboard Motor Boat Bass Fishing...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
55 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
