Question about Apple Hour Bluedio Black T9 Universal Bluetooth V2.0 Mono Bluetooth Headset
My bluedio t9 is flashing red and blue light while chargin.......but it is not working.mean it does not on..
I have a bluedio h9 set i tried to connect it to my ps3 but nothing appears on the screen,
I have the same unit. It does work PS3 just fine, but the instructions included with the Bluedio H9 are vague and poorly written.
First fully charge it. Then hold the mulit-function button down for 5 seconds or so. It will turn on (light will flash blue)...then keep holding the button down another 5 seconds or so and the light will go solid blue. Now you are in "discovery mode" if you don't get it into discovery mode, your PS3 can't find it.
Go to the "Settings" tab on the PS3's cross-media bar and select the "Accessory Settings" menu. From the new menu, select "Scan for Bluetooth Device."
After you have added the Headset, you can control the Mic pick-up level (1 to 5) under Accessory Settings -> Audio Device.
Good Luck
Oct 02, 2010 | Radio Communications
How to reset bluedio av890
Switch it off.
Press the on off switch for little long duration, till the Light glows steady/permanent (without blinking).
At this stage it can be connected to a device enabled with Blue tooth in "switched on" condition using the passcode "0000" (four times zero)
MUTHUPETCHI V (muthupetchi008@gmail.com)
Apr 15, 2010 | GE ON-SHLDR BLUTOOTH HDSET Wireless...
Bluedio T9 Bluetooth won't charge
Well... I've got the n65, and this is the third time I've gone to charge it. Solid red, won't turn on no matter how long its been plugged in, can't find the manual, this fixya page is the best result online...so my solution is to stop by the local cell-phone accessory shop to buy something new.*
*Results may vary. :^s
Jan 13, 2010 | Cell Phones
Blue light flashing light, red light on
The flashing means that the toner and/or the imaging drum is empty or missing (printing halts on these errors). Lights on steady means low toner.
Jun 24, 2009 | HP LaserJet 2550n Printer
Apple Hour Bluedio Black T9 Universal Bluetooth V2.0 Mono Bluetooth Headset Logo
210 people viewed this question
Top Apple Hour Radio Communications Experts
eradiostore
eradiostore
Are you an Apple Hour Radio Communication Expert? Answer questions, earn points and help others
