Question about Kenwood VR-505 Receiver
Kenwood vr 505 sub woofer
I can't get my kenwood vr 505 sub woofer to work.
  • 256 Answers
SOURCE: Wiring for VR-505
This is like buying a car without the power steering pump, which specially designed proprietary part. I am not familiar with that particular model, but if it requires special wires, then you may have problems obtaining them and may need to go to the Manufacturer. You would not have accepted a car that had no power steering pump, just because the salesman recommended it. Fortunately we are talking about a manufacturer with integrity and I am almost sure that you will get your cables, as long as you can prove ownership. Did you ever examine the sockets on the receiver, which could be simple RCA jacks. Do that before you go to the manufacturer. Then you can go to Radio Schack after you look in your junk pile to see what kinds of wires you have in that special wire box. CONSTANTIN (arzconst)
Posted on Jun 20, 2009
dunnbiker
  • 8546 Answers
SOURCE: Sub woofer output port does not seem to work on my
Is the 407 set up to drive the unknown sub. It's not just plug n play.
The manual will guide you, around page 15. Also refer to your subwoofer manual. Try retrevo.com for that one.
http://www.retrevo.com/support/Kenwood-VR-407-Receivers-manual/id/480ag200/t/2/
Posted on Dec 29, 2010
dunnbiker
  • 8546 Answers
SOURCE: type of cabel for a woofer for a Kenwood VR 505
That would depend a lot on the subwoofer, which you did not name. I'll assume it's a self-powered model of some sort.
A sngle RCA cable from the Subwoofer Preout wll get you started. The other end is unknown.
You'll aslo have to set up the recever to know it has a subwoofer and other parameters. Find the manual at retrevo.com.
dunnbiker
  • 8546 Answers
SOURCE: how can i connect my
I assume you mean you want TV-related sound to play through the Kenwood.
It's in the manual.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Kenwood-VR-505-Receivers-manual/id/480ag214/t/2/
I personally would recommend minimum TV involvement in sound and minimum receiver involvement in video, but that's just me.
You might want to ponder why you would need audio from a TV in the first place if it originates elsewhere like a Cable Box. The fewer hops and interconnects a given signal takes on the way from the source to your ears, the better (and cheaper, too, as optical or HDMI cable is expensive). You COULD skip the TV entirely. Many don't even HAVE audio (monitors, for example). The receiver only NEEDS a basic composite video output to the TV so you can use the TV for setup and control. You COULD run vanilla stereo audio to the TV from the Cable Box for watching Oprah.
I run all of my best DIGITAL audio directly from the sources to my VSX and the best DIGITAL video directly from the sources to the TV.
Posted on Mar 25, 2011
dunnbiker
  • 8546 Answers
SOURCE: I have a kenwood vr-407
Grab the free manual and start at the beginning. This IS a new install since the memories are probably back to defaults if it was unplugged for awhile.
Posted on Jul 14, 2011
I have no sound coming out of my sub woofer on my kenwood VR-407 everything else works great anyone have any ideas or solutions
yes it very much has everything to with it. your sub out is at a pre-amp lvl, so you can route that signal to another amp, then to your passive sub, or get a powered sub
Apr 19, 2013 | Kenwood VR-407 Receiver
How do i connect the sub woofer for kenwood-505
I inherited a Kenwood SW 505 Sub woofer. I don't know if it works I plug it in but no lights.
Oct 07, 2012 | Kenwood VR-505 Receiver
Type of cabel for a woofer for a Kenwood VR 505 receiver
Dec 29, 2010 | Kenwood VR-406 Receiver
Sub woofer output port does not seem to work on my kenwood VR 407, checked sub woofer on another system - works fine, any easy solutions?
Dec 29, 2010 | Kenwood VR-407 Receiver
Hooking up my sub woofer
Hi ..
According to the manual there's a pre-out (phono style RCA) connector for the sub but it needs to be a powered subwoofer..Has its' own internal amp
Jul 26, 2008 | Kenwood VR-305
Sub-woofer output not working
"Sub-woofer output not working" problem, and notify you when a new solution is offered.
Press the setup key on the front of the receiver
Select the subw setting
Move the multicontrol knob until the sub woofer is on
Turn off the receiver and turn back on- the subwoofer should be on
The operator manual can be downloaded on the web site--- free
http://www.retrevo.com/support/Kenwood-VR-507-Receivers-manual/id/480ag219/t/2/
Sep 22, 2007 | Kenwood VR-507 Receiver
Kenwood VR-505 Receiver Logo
188 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
