Question about RIM BlackBerry Curve 8520 Smartphone
What's my vectone sim MEP - RIM BlackBerry Curve 8520 Smartphone
My problem is, that when im typing mepd nothing happens? why? There is only standing sim id: and then a long number..
I think your chance to entering mep code has left 0 that's why you can't entering mep code in your phone. To solve this problem you can doing cable unlocked process at nearest mobile phone repair to reset blackberry to default factory reset also unlock blackberry curve 8520 network, so you can change your sim card with another sim card from other provider without any blackberry unlock code again. Good luck!
Aug 09, 2011 | RIM BlackBerry Curve 8520 Smartphone
Tip
Instructions for Unlocking BlackBerry phones ( All Models)
<span><span>Always the Best way to Unlock Your Phone is by using the MEP2 code or Unlock code. First you should<a href="http://unlockgenie.com/"> Purchase the Unlock code from a Trusted Vendor.</a><br /><br />After u got the code follow the instructions below......<br /><br />BlackBerry Unlock Instructions (9800)<br /></b><br />* Insert a foreign SIM Card<br />* Power on the phone<br />* When prompted, enter your unlock code<br /><br />BlackBerry Unlock Instructions (83xx/85xx/88xx/8900/9000/9300/96xx/97xx)<br /></b><br />* Ensure a SIM Card is inserted<br />* Go to 'Manage Connections'<br />* Click on 'Turn All Connections Off'<br />* Go to 'Options'<br />* Click on 'Advanced Options'<br />* Click on 'SIM Card'<br />* Type 'MEPD' (letters will not appear on-screen but a menu will pop up.)<br />* Type 'MEP2' (user will be prompted to enter MEP code)<br />* Enter the MEP2 code (CONFIRM you get "Code Accepted" message)<br />o *If you also have a MEP4 code, type 'MEP4' (you will be prompted to enter MEP code)<br />o Enter the MEP4 code (CONFIRM you get "Code Accepted" message)<br />* Reboot device<br />* Go to 'Manage Connections'<br />* Click on 'Restore Connections'<br />* Device is now unlocked<br /><br />BlackBerry Unlock Instructions (95xx)<br /></b><br />* Ensure a SIM Card is inserted<br />* Go to 'Manage Connections'<br />* Click on 'Turn All Connections Off'<br />* Go to 'Options'<br />* Click on 'Advanced Options'<br />* Click on 'SIM Card'<br />* Tilt the phone horizontally, click the BlackBerry button and Show keyboard<br />* Type 'MEPD' (letters will not appear on-screen but a menu will pop up.)<br />o *If MEPD doesn't work, try MEPPD<br />* Type 'MEP2' (user will be prompted to enter MEP code)<br />o *If MEP2 doesn't work, try MEPP2<br />* Enter the MEP2 code (CONFIRM you get "Code Accepted" message)<br />o *If you also have a MEP4 code, type 'MEP4' (you will be prompted to enter MEP code)<br />o Enter the MEP4 code (CONFIRM you get "Code Accepted" message)<br />* Reboot device<br />* Go to 'Manage Connections'<br />* Click on 'Restore Connections'<br />* Device is now unlocked<br /><br />Blackberry Instructions (81xx/82xx/9100)<br /></b><br />* Ensure a SIM Card is inserted<br />* Go to 'Manage Connections'<br />* Click on 'Turn All Connections Off'<br />* Go to 'Options'<br />* Click on 'Advanced Options'<br />* Click on 'SIM Card'<br />* Type 'MEPPD' (letters will not appear on-screen but a menu will pop up.)<br />* Type 'MEPP2' (*Note- for Telus, use MEPP4. You will be prompted to enter MEP code)<br />* Enter the unlock code (CONFIRM you get "Code Accepted" message)<br />* Reboot device<br />* Go to 'Manage Connections'<br />* Click on 'Restore Connections'<br />* Device is now unlocked<br /><br />Old School BlackBerry Instructions (87xx & Older)<br /></b><br />* Ensure a SIM Card is inserted<br />* Go to 'Manage Connections'<br />* Click on 'Turn All Connections Off'<br />* Go to 'Options'<br />* Click on 'Advanced Options'<br />* Click on 'SIM Card'<br />* Type 'MEPD' (letters will not appear on-screen but a menu will pop up.)<br />* Hold ALT key and type 'MEPE' (user will be prompted to enter MEP code)<br />* Enter the unlock code (CONFIRM you get "Code Accepted" message)<br />* Reboot device<br />* Go to 'Manage Connections'<br />* Click on 'Restore Connections'<br />* Device is now unlocked</span></span>
on May 05, 2011 | Cell Phones
I have a blackberry bold 9700, but the mep code says o. I can't use it. Please help me...
you can unlock your blackberry bold 9700 by cable method . after this process your blackberry 9700 will be unlock . and no need to unlock after this process.
Jun 30, 2011 | RIM BlackBerry Bold 9700 Smartphone
My MEP counter is 0
Don't panic, you can reset your mep counter with cable unlocking method and you only can do that in trusted mobile repair shop. This method not only can reset mep counter but also unlock blackberry bold 9700 network so you can change your sim card with other sim card without need to unlock it using blackberry unlock code. Good luck!
Apr 09, 2011 | RIM BlackBerry Bold 9700 Smartphone
I want to change my mobil sim usage from vodafone to vectone.
Contact vectone and they will tell you if it is possible. If it is they should help you change it.
Apr 08, 2011 | Cell Phones
I have an SciPhone i68 4G. It is a dual sim phone. I tried putting my T-Mobile sim card in with a Vectone sim card and I found that I was having trouble with the battery. It would turn off even when I was...
TO SEXYBABE008 -I HAD THE SAME PROBLEM YOU ARE HAVING. THERE ARE TWO SLOTS FOR THE SIMS CARD- THEY ARE ON TOP OF EACH OTHER- IF YOU ARE ONLY USING ONE SIMS CARD- PUT IT ON THE TOP SPOT WHEN INSERTING IT- THIS WORKED FOR ME- THE BATTERY HAD NIOTHING TO DO WITH.
Mar 01, 2011 | Cell Phones
I ave a htc smart fone i ave blocked my fone its asking for my puk number i dnt ave 1 ..ccan u help??
It is the sim card that got blocked not the phone. it is found in the Sim pack. It is the 8 digits code that you find on the Sim card carrier. Phones do not require PUK code, the Sim card does.
Check on the Sim cards pack, you will see the Sim card carrier where you broke the Sim card out of, there are some codes on it. You will see your number, the pin code and a 8 digit code, then you will see the bar code at the bottom of the card, it is the 8 digit code that is the PUK for your Vectone mobile.
If you do not have your pack anymore, what you have to do is to contact the Vectones customer care center, so they will be able to give you your PUK code, but the y will ask you for some security informations, which are easy to answer, after providing the answers, they will give you your PUK code.
Hope this helped.
Jan 07, 2011 | HTC Cell Phones
Want My Vectone Mobile PUC Code........07550216342
If you mean the PUK code of your phone, it is found in the Sim pack. It is the 8 digits code that you find on the Sim card carrier. Phones do not require PUK code, the Sim card does.
Hope this helped.
Jan 07, 2011 | Cell Phones
My vectone mobile sim card is lock i need puk code for 07574149168
my vectone mobile sim card is lock i need puk code for 07574594312
Oct 31, 2010 | Health & Beauty
RIM BlackBerry Curve 8520 Smartphone Logo
27 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
