Question about Pentax Cameras
Pentax k20 green mode malfunction
The rotary mode switch appears to be malfunctioning. When the mode switch is in the "green" position, the display indicates that it's in the "manual" shooting mode.
  • 196 Answers
SOURCE: istD shutter release problem
I've had similar problems with my Pentax Super-A on an intermittent basis. If you haven't replaced the batteries I suggest you try that first. Not sure why, but that has sorted my problem out quite a few times (even when the existing batteries still have a fair amount of juice left in them).
Posted on Feb 15, 2006
t00nz
  • 4738 Answers
SOURCE: Blank LCD Screen when in shoot mode
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Mar 23, 2008
StormStrikes
  • 104 Answers
SOURCE: Malfunction indicator lamp
The Malfunction Indicator Lamp or MIL (Also called the check engine light or service engine soon light) comes on when the on board computer detects an issue with the operation of the engine or transmission.
The best thing to do is to take the vehicle to an auto parts store like Autozone and have them hook up their scan tool to the vehicle and read the code. They can read it, tell you what it is and also tell you what the code means.
If it is pointing to a faulty component or sensor and you replace or repair the component the the light will go off on its own after the computer sees that the malfunction is no longer present.
You can have the code cleared, but if whatever caused the light to come on in the first place is not addressed then it will just come back on eventually.
Posted on Dec 31, 2008
SOURCE: Lacetti Chevrolet. Malfunction Indicator light is on.
It may be the same problem as my 56 plate Lacetti. The yellow malfunction light came on two weeks ago and two days ago, both times shortly after filling up with petrol to the brim, and I suspect it is the petrol sensor as I only clicked the petrol cap once after fitting it back - the handbook says click it several times. The yellow light also came on yesterday after taking the car a short journey so it is likely that the sensor is still picking up a small escape of petrol, but the car has been fine today with no light appearing now that the fuel level has dropped a bit. Like you, I have not noticed any drop in power with the light on.
Posted on Feb 10, 2009
  • 36 Answers
SOURCE: Exhaust gas component related malfunction light.
You will have to read the codes and see specifically what the problem is. Sometimes its more then one code. So its real simple to do. So just get a peice of wire maybe and inch long, bend it like a horse shoe. Then find the little jumper box,its usually on the fire wall. So in the manual find the the 2 plug in points. Thats in the emissions section. Then sit in the car and turn the key on do not start the car. and watch the blinking engine light. count the blinks and compare them in the manual. You now know the specific problem
Posted on May 03, 2009
I'm trying to set th time and date on my camera but when I hit the menu button the yellow lock appears how can I get rid of this so I can set time and date correctly please
Hi Keith, The link below is the user manual for the Pentax Optio E30 Digital Camera, On page 56 it says
• In Green Mode, you cannot change the information displayed on the LCD monitor by pressing the 4/W button.
• You cannot use the [A Rec. Mode] menu or Capture Mode Palette in Green Mode. If you try to display the [A Rec. Mode] menu or Capture Mode Palette, - (key lock icon) appears.
• If you switched to Q mode from Green Mode, you cannot display the [H Setting] menu by pressing the 3 button. If you try to display the [H Setting] menu, - (key lock icon) appears.
• When the camera is turned off in the Green Mode, it turns on in the Green Mode next time the power switch is pressed.
THIS IS YOUR CAMERAS USER MANUAL.....CHEERS..
http://www.camera-usermanual.com/manuals/pentax/Pentax_Optio_E30.pdf
Mar 27, 2016 | Pentax Optio E30 Digital Camera
No output
You should start with Rotary switch on "Maintenance Bypass" position and Qf1 open.
Turn Rotary Sw to "Test" position and wait for self test to execute and UPS to turn on.
Once you get the Yellow lamp lit, it is asking for QF1 to close
Once closng QF1, if green LED is lit, turn UPS off by pressing gray button until it ask for confirmation, select Yes and press Return.
Turn Rotary Sw to Normal position, press On button and the green LED will illuminate.
If, after closing QF1, the green LED didn`t lit, turn Rotary Sw to Normal, press On button and wait for green LED to lit.
Thats`it...
if anything is not working well.. please let me know.
Mar 25, 2014 | MGE UPS Galaxy 3000 UPS System
How to change language English
You can find the manual for the Jura IMPRESSA S9 One Touch at the link below. I have typed the Instructions from the Owner Manual Below. See: http://content.costco.com/images/Content/Misc/PDF/OwnerManual-671992.pdf
Program Language:
Example: To change the language from ENGLISH to DEUTSCH (example), proceed as follows.
Precondition: COFFEE READY is displayed
  1. Keep the Rotary Switch pressed until MAINTENANCE appears.
  2. Turn the Rotary Switch until LANGUAGE ENGLISH is displayed.
  3. Press the Rotary Switch to enter the programme item. LANGUAGE ENGLISH
  4. Turn the Rotary Switch until SPRACHE DEUTSCH (example) is displayed.
  5. Press the Rotary Switch to confirm the setting. GESPEICHERT (example) appears briefly on the display. SPRACHE DEUTSCH (example)
  6. Turn the Rotary Switch until EXIT is displayed.
  7. Press the Rotary Switch to exit programming mode. BITTE WAHLEN (example).
Best of Luck!
Jan 14, 2013 | Jura Impressa S9 One Touch
Nissan pulsar 1987 n13 the ECM light came one and the car cut out and won't start again and I need to know where the ECM is
Hi, the computer is under the passenger's seat. Code extraction procedure is pasted below.
READING CODES Modes will not switch while the engine is running. The ECM automatically switches to MODE I when the ignition is switchedOFF.
1984-90 Vehicles With Dual LED System
The self-diagnostic system has 5 modes. To switch modes, switch the ignition ON and use a screwdriver to turn the mode select switch through the access port on the ECM. The inspection lights will begin to flash. When the desired mode has been entered, turn the screwdriver fully counterclockwise. The red LED and green LED perform different functions in different modes.
Mode I-
This is the normal vehicle operating mode. The green LED will indicate loop status. If the green LED is not blinking when the engine is running, the vehicle is in open loop, or the HO 2 S, O 2 S, or sensor circuit has a malfunction. If the green LED is blinking, the vehicle is in closed loop. If a malfunction takes place, the red LED and the MIL will glow, indicating a malfunction has occurred.
Mode II-
Both the red LED and green LED are used to monitor mixture ratio feedback control. The green LED will function as described in MODE I. If vehicle is in open loop, the red LED and green LED will remain on or off. In order for results to be valid, vehicle must be in closed loop. In closed loop, the red LED remains off if the system is running rich, comes on if the system is running lean, and blinks at the same time with the green LED if system is within 5% of the exact air/fuel ratio.
Mode III
-When this mode is accessed, the codes stored in the ECM's memory will be flashed by the green LED and red LED on the side of the ECM. The red LED will light first. This is the first digit of the trouble code; the green LED will flash next, showing the second digit of the code. For example: 2 flashes of the red LED followed by 1 flash of the green LED corresponds to Code 21.
Mode IV-
This mode is used for checking the throttle plate (TP) switch, starter, and vehicle speed switch status. When the TP switch or starter switch is activated, the red LED will briefly flash as the status changes. For VSS status, the green LED will remain off when vehicle speed is less than 12 mph (19 km/h) and come on when vehicle speed is greater than 12 mph (19 km/h).
Mode V-
This mode represents a real-time diagnostic test of the crank angle sensor, ignition signal and the mass airflow signal. The malfunction code will be displayed only when the malfunction occurs and will not be stored in memory. The output code will appear as a single or short string of pulses. Count the number of pulses for the malfunction code.
1 pulse-CMP sensor signal lost or noise in signal 2 pulses-MAF Sensor signal abnormal 3 pulses-Fuel pump circuit shorted or open 4 pulses-Ignition signal lost
Apr 19, 2011 | 1987 Nissan Pulsar
How do i check my codes in a 86 nissan z24 pickup
The self-diagnostic system identifies malfunctions of signal systems such as sensors, actuators and wire harnesses based on the input signals received by the ECCS control unit. Various malfunctions are coded and displayed on the control unit by a series of blinking red and green lights. Results of the self-diagnosis are retained in the control unit's memory and are displayed when the mode selector, located on the rear of the control unit, Fig. 122, is switched to the On position. When displaying malfunction codes, the code number can be determined by counting the number of light pulses. The red light represents the first digit of the code, while the green light represents the second digit of the code. For example, a Code 32, would be displayed as three flashes of the red light, followed by two flashes of the green light. Malfunction codes can be translated as follows:
  1. Code 11 -- Crank angle sensor circuit malfunction.
  2. Code 12 -- Air flow meter malfunction.
  3. Code 13 -- Water temperature sensor circuit malfunction.
  4. Code 21 -- Ignition signal malfunction.
  5. Code 23 -- Idle switch circuit malfunction.
  6. Code 24 -- Transmission switch and clutch switch circuit malfunction.
  7. Code 32 -- Starter signal malfunction.
  8. Code 42 -- Throttle sensor circuit malfunction.
  9. Code 43 -- Injector circuit malfunction.
  10. Code 44 -- All monitored systems satisfactory.
May 10, 2010 | 1986 Nissan Pickup 4WD 1986
My Pentax *ist DL camera has started to give me problems. The rotary control dial on the top left of the body does not work. When I turn it, it does not display the setting as set on the dial. In addition...
it is best to be sent for repairs, since it appears that something is wrong inside of your camera. Software doesnt respond to the switches, it is best to be not turned on and sent to repairs.
Oct 19, 2009 | Pentax K20D Digital Camera
Pentax Optio M20 in Green Mode switches off after turning on
Try to press & hold down the Green button (the trash can button on the bottom right corner) & see if it gets u out of green mode.
Jul 27, 2009 | Pentax Optio M20 Digital Camera
My Lexicon Alex is malfunctioning, where can I find parts?
I don't think it's broken. I think you've cleared some registers (probably number 5 from your description, maybe more) and now you're "us[ing] cleared registers as loop points." This means that you're looping 1-2-3-4 then back to 1 again. This is actually a feature of the Alex and it's awesome as long as you're using it intentionally :) If you don't know you're "using" it the unit have symptoms similar to what you're describing. It's possible that it is broken, but it's more likely that you're in this mode.
I attached a pic of my user's manual.
Also here are the directions as printed in the manual to clear or restore a register (i.e. a number spot on the dial):
  1. Briefly press STORE/CLEAR until a minus sign (-) is displayed.
  2. Press and hold STORE/CLEAR. If you were in preset mode, the register LED will go on, indicating that Alex has automatically switched to register mode -- selecting whatever register is indicated by the position of the REGISTER/PRESET knob. The "-" symbol in the display will flash, indicating that the CLEAR function is armed.
  3. Releasing STORE/CLEAR will clear the displayed register. The display will flash briefly to indicate the clear was successful. (The ID number of any cleared register flashes when selected with the REGISTER/PRESET knob.)
To restore a cleared register, simply repeat the clear operation with the "+" displayed.
Mar 05, 2009 | Lexicon Omega Desktop Recording Studio...
1998 subaru legacy check engine ligt
i have the same problem the red check engine light :(
Jun 18, 2008 | 1998 Subaru Legacy
Minolta dialta di250
The C0048 error code not exist.Malfunction resetting procedure:
Turn OFF,then ON the power switch or open and close the side cover for all malfunctions except C05XX codes.
Use Trouble reset of the Initial screen to reset all malfunctions.
To right side the touch panel(screen display)near display contrast button exist a little hole (reset switch).Insert a hairpin to touch the switch.
Enter "3" from the 10-key pad when " * " appears at the center on the left side of the screen while the start up screen being displayed.Touch TROUBLE RESET,and EXIT to go back to the basic screen.
May 07, 2008 | Minolta DiALTA Di520 Laser Printer
Cameras Logo
18 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
