Bought this washer from individual they said it was leaking from the hoses, i bought new hoses, turned on washer, sounded like it was filling up the tub, instead water came pooring from underneith the washer, i need to get the back panel off but, I don't want to break anything, can someone help me to figure this one out.
thanks,
Milissa
Mine leaked and it was the "Coin catcher" its rubber and it had a whole in it from a bra underwire. This is located at the front in the right handcorner, remove two screws at the base of the front and pull off panel. I bought a replacement part for $15, its not a hard fix.
HTH~Melissa T.
Hi Milissa,
Getting to the back panel is fairly easy. You will see that you have the water inlet valves there and the electrical plug. All you need to do is take out the screws surrounding the edge of the machine. Also, first, you will want to remove the backing from the control panel where the timer is. Again just remove the screws. Once the screws are out the back should just come right off. Don't worry about breaking anything, you should be just fine. If you have any other questions let me know, also let me know if this was helpful. If you are having problems finding the leak let me know, I can help you with that too. Good luck and glad I could help.
