Question about Sony Handycam CCD-TR416 Camcorder
Very grainy playback
While recording and during playback of tapes on my Sony Handycam CCD-TR416 there are lines that resemble small "dashes" all across the picture. I'm not sure if the actual tape is recording grainy or if it's just showing up through the viewfinder and playing back grainy. At times, during playback, the screen also goes momentarily to a blue screen and then back to the grainy recording. I tried to use a friend's Sony Camcorder to determine if the tapes themselves were grainy or if they are just playing back that way because of a problem with the camcorder. Her camcorder won't play my tapes at all. I'm not sure why this is as it seems to me that any Sony Handycam that uses Hi8 tapes should be compatible with another. We tried cleaning the heads of my camcorder using a video head cleaner but that didn't help. I would like to dub my camcorded tapes to DVD's but at this point have no way to do so because of this problem. I'd like to know what might cause this graininess and also I'd like to know why my tapes won't play on another Sony Handycam. I hope someone can offer some advice. I hate to spend a fortune taking the camcorder to a repair shop if there is a simple fix, but I will if that is the only solution. Thank you in advance for any help. Debi D.
Same problem with my Sony CCD-TR416 recently. Know what finally worked? With camera playing a tape, I picked up the camera and tapped it sharply on a solid desktop. Had to do it 3 times. I held the camera with two hands, one on each side of the camera, raised it about 3 to 5 inches off the desktop and then quickly tapped it on the desk holding the camera parallel to the desktop so that it solidly hit with all of the lower surface of the camera body.
I know it sounds crazy. I swear it worked. I had tried cleaning the heads over and over. I examined them with a 20x loupe and they looked fine. I doubt that the problem was oxide and debris build-up on the heads.
I planned to order a new head/drum just to see if I could manage the replacement procedure by myself (I'm a chronic do-it-yourselfer/experimenter). I guess I don't need to do that now.
Why did the slam technique work? My guess: Inside the rotating head, there must be some sort of electronic track like the brushes of a motor or something similar.. Some sort of debris must have been involved in a corruption of the transfer of impulses from the heads. A few taps and it broke free.
If banging it on the desk didn't work, I was next planning to remove the drum to check for bad connections. I'm sorry I didn't have to do that.
Nevertheless, don't listen to everyone when they say that the "heads must be dirty." Nope. With the loupe, I could see mine were sparkling clean. But, I still had those multiple horizontal rows of short white streaks obliterating the video image. Tap. Tap. Tap. Now they're gone.
Try it. Couldn't hurt. Though chances are, you won't see this. I'm posting 6 months after your original post. I just happened upon your post as I researched the problem through Google. Neverthelss, someone might see my response someday and maybe they, too, will get luck with the tap, tap, tap procedure.
Posted on Jan 15, 2008
Wow banging three times worked for me too!
Posted on Nov 18, 2011
Amazing - I was looking for a head cleaner for my camera when I stumbled upon this site. Without even attempting to clean the heads I did as KentuckyDIY said and it worked like a charm!
Posted on Jan 04, 2010
    Scholar:
  • 125 Answers
This is typical symptom of a dirty video head. this ahappens especially if you play a tape with molds. Cleaning tapes may or may not work. the effectiveness is based on: 1. If the contamination is severe, sometimes the dirt really sticks to the head. You will not normally see this because the head is the tiny part on the head drum that spins. 2. If you use a non original head cleaner 3. If you re-use a tape cleaner. I had this problem on my Sony Hi8 camcorder, i had to mannually remove the dirt on the tape head. I will not recommend to do it as it may damage the head. What I would recommedn first is to buy a Sony head cleaner, and try to clean the head. You may try more than once, it will not damage the head right away. If this does not work, before you send it for repair, ask for estimate. Maybe it is cheaper to buy an analog Hi8 player on ebay rather that send it for repair. And BTW if you have a Hi8 camera, it can play both video8 and Hi8. If you have a video8 camera, it wont be able to play Hi8.
Posted on Jul 06, 2007
Can't believe it but it worked for me too! Not perfect but MUCH improved. Hit it three times and it cleared right up. Hit it one more time and the lines came back, then disappeared again... so I am not confident the fix will last but hopefully it will!
Posted on Feb 16, 2010
SOURCE:
Have tons of tapes, can't find the camera after a move!??? How do we view the tapes or burn them to DVD's now?
What we did was to buy a secondhand camera of the same type at little cost, transfer the old films with our DVD recorder (if the recorder has a hard drive it makes editing a cinch), and then sell the camera back to someone who wanted to do the same!
Dec 11, 2010 | Sony Handycam CCD-TR416 Camcorder
How can I transfer the video from a Sony Handycam CCD-TR416 to CD or DVD
How to Transfer video from Sony Handycam CCD-TR416 to DVD - You need a DVD Recorder / Player, connected to your TV. Then using the audio / video cables from your camcorder, connect them to the TV as well. Turn your TV on so that you can watch the video out from your camcorder and then select the record button on your DVD Recorder / Player. Then you have a DVD that can be watched in any DVD Player or Computer with out any compression. This is how I transfer my camcorder tapes to DVD.
Aug 10, 2010 | Sony Handycam CCD-TR416 Camcorder
Tape door wont close on my Sony CCD-TR416 camcorder
Try this for anyone having this issue:
HERE'S WHAT WORKED FOR ME PER SONY TECHS:
Take? OUT the battery or disconnect the AC cord.
Turn the camera ON (tape, memory, edit settings) for 15 seconds.
Turn camera to off setting.
Plug battery or AC cord back in.
VOILA!
Worked for me and I had the stupid C32:11 error code for weeks! Door would not close. Followed the SIMPLE and SAFE instructions and IT WORKED! Just like magic. I couldn't believe it! Save your money TRY THIS!
Sep 22, 2009 | Sony Handycam CCD-TR416 Camcorder
How do i transfer my sony handycam ccd tr416
Use the link below to transfer video to your Computer using A/V cable and the Video Capture software.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C428275
Aug 07, 2009 | Sony Handycam CCD-TR416 Camcorder
Sony CCD-TRV65. Blue screen during playback
Just bought the exact one from a yard sale for 20 bucks. Had the very same problem with the blue screen on playback. What i did is replace the battery in the small bay when you open the viewfinder. Try playing your tape again and it will work!
Feb 01, 2009 | Sony Handycam CCD-TRV65 Camcorder
Sony handycam ccdtr416 ntsc
Its an old model and user manual is available on charge basis.
Jul 26, 2008 | Sony Handycam CCD-TR416 Camcorder
Black lcd screeen on my sony handycam
first check the iris of the camera if it is opening,you will see this when you look inside the lens of the camera when you turn on and off the switch at camera mode if the iris is opening....if the iris is ok the second problem may occurs of your camera is the ccd image sensor....go to a sony service center for replacing that...i know it is free for replacing that sensor cause that is the recall product not only on sony but in other brand because the manufacturer of their sensor is only one company....
Oct 19, 2007 | Sony Handycam CCD-TRV328 Camcorder
Will not playback or record
I have a Sony handy cam ccd-trv108 Hi-8 and I can not get it to play or record, everytime I insert the tape and hit play the display screen flashes c:31.22 Please help me?
Aug 10, 2006 | Sony Handycam CCD-TRV108 Camcorder
Sony Handycam CCD-TR416 Camcorder Logo
561 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
