Question about Dryers
I bought a frigidaire dryer knob to replace the broken one. But how do I get the knob on without hammering it and cracking the knob and stem? the stem on my frigidaire dryer is broken - i have the knob but i need to replace the stem. how do i open the faceplace to get to the stem to have it replaced?
    Novelist:
  • 101 Answers
You will want to take out the screws on the back of the dryer behind the control panel. Once off you will see all the wires and such connecting to the timer and the knobs. Make sure you disconnect the power first before digging in in there. When you find the spot that your knob goes take that control part off and place your knob in. Once you have the back off you will see how it goes on. If you have any other questions feel free to ask me and please let me know if this was helpful to you. Good luck and glad I could help.
Posted on Jan 22, 2009
How to replace the knob and stem on a frigidaire range?
Stem is part of control switch need to replace control .....
Knob is probably fine, just pull out shaft from knob use old knob on new switch as long as plastic knob is not broken
Aug 12, 2014 | Frigidaire Kitchen Ranges
Door knob stem stuck
You may have to apply Liquid Wrench or equivalent to free up the spindle. Tap the end of the spindle gently with a hammer to break the rust or corrosion loose. You will then have to prevent the mechanism from turning as you work the old spindle free. Be careful to avoid damaging the lock mechanism in such a way that installation of the new spindle will be difficult
Jul 17, 2013 | Hardware & Accessories
How can I remove the timer knob from a Frigidaire Washer
Knob PN 131592001 Just looking at replacements it appears to just push on. If pulling on it does not get it off then rotate it CCW in an attempt to unscrew it. Just be VERY careful that the timer stem does not rotate if you turn the knob CCW or you will be buying a new timer. Open the top and hold the stem if you have too. (easier said than done) Worst case... if you have a bad knob and have a replacement knob in hand... break the defective knob. If your changing the timer look at the stem on the new timer. If it is threaded on the end the knob unscrews. If it is not threaded it pulls off.
Kelly
May 11, 2011 | Frigidaire FWS833A Top Load Washer
The knob on the right just turns (no clicking) so it does not seem to be selecting a time. now dryer wont start.
Check your timer knob. On these GE dryers I have found a lot of times the knob cracks where the stem of the timer goes in and the resistance of the timer will make ti slip internally rather than turning the knob. If the knob appears to be ok, then I would say you definitely have a bad timer on your hands.
Timer is part number WE4M271 and runs around $100 from marcone's
Knob is
WE1M654 and is around 18$
Good ;uck with this!!
Jul 05, 2010 | GE DBXR463GDWW Gas Dryer
The knob you use to turn the dryer on has broke off
have you been able to turn it with some pliers try it and then just get a replacement of ebay
Oct 25, 2009 | Frigidaire GLER341A Electric Dryer
Can't Remove Broken Electric Stove Burner Knob
Spray each of the screws with a little WD40, available at any autoparts store. This will dissolve any rust that may have formed. Leave it over night. Then loosen the screws and the knob will come off.
May 07, 2009 | Kitchen Ranges
Dryers Logo
120 people viewed this question
Top Dryers Experts
