Question about Hotpoint Refrigerators
Trying to reverse the doors on FUFL1810G, the screws wont catch the thread and don't seem long enough although they fit in the other side
Just want to reverse the doors but the bottom bracket wont fit as the screws that fit it in on the right hand side seem too small for the left side? tempted to get some larger screws?
jyackle5
  • 8197 Answers
SOURCE: Change door opening direction on whirlpool fridge door
Here is a setp by step manual to reverce the doors on ther fridge. Refer to page 5 through 8 will sho you how. good luck. jon please rate.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GB9SHDXPB_Use%20and%20Care.pdf
Posted on Dec 17, 2008
dragonsthatk
  • 547 Answers
SOURCE: Can the doors of both the refrigerator and freezer be reversed to open from the other side?
yes take off handles remove center hinge between doors then top and bottom now put all on other side replace doors and handles Thank you
Posted on Feb 11, 2009
  • 59 Answers
SOURCE: do i need special hinges to change this refrigerator from left hand door to right hand door?
NO YOU USE THE SAME HINGES
Posted on Apr 29, 2009
  • 323 Answers
SOURCE: Help . Change doors from right to left opening
first remove the door from the fridge, remove the hardware connected to the fridge, on the opposite side should be rubber or plastic caps covering some bolt holes. remove caps and install top of hinge transfer everything you see on the left to the right
Posted on Oct 24, 2009
  • 112 Answers
SOURCE: water leaking from door
your drain is clogged. if ice isbuilt up in the freezeer floor. when the freezer defrosts and the drain is clogged it has no where else to go other than ouot the front. pull everything out of the freezer and check twards the rear at the bottom. remove as much ice as possibile let set unplugged and door open for 3 hours. then take a cup of boiling water and pour it back there. if it dont drain repeat that process with the water-have a towel ready because if the water stays back there long enough it will get cold. you need to keep the water HOT. ice could be built up in the drain. hope this helps
Posted on Oct 29, 2009
Oven door wont close.
The thread plate needs to face the screw holes.
Dec 02, 2015 | Belling Country 100DFT Charcoal 1000mm...
How do I fit a door catch Electrolux dishwasher esl63010
Usually with door open there is 2 screws holding the locking assembly in place! Undo all screws and remove whole assembly! Refitting is reverse!
Oct 13, 2014 | Dishwashers
The bobbin thread wnt catch on my brothers sc6600 sewing machine
try changing the needle
rethread the machine top & bobbin
if these suggestions don't work I suggest taking the machine to a
sewing machine shop to be checked
Jul 29, 2012 | Sewing Machines
Makita bhp453 chuck screw wont loosen
The chuck screw on drills is put in with lok-tite and is reverse threaded. You need to get the screwdriver on it firmly and turn it clockwise, as you are, with strong, constant pressure until it breaks free. Don't let the screwdriver slide out of the screw slot, if you round off the screw head you'll have to cut the chuck off. If it still won't break free, try putting the drill in a vice or use a screwdriver with a hex nut molded into the driver shaft so you can use a wrench for some more torque.
Mar 11, 2012 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Do I need a new door henge to reverse door opening ? The existing one doesn't seem to fit on left side
no just reverse hinges to opposite side of door and find the slots on the other side of the door jamb
Sep 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
This dishwasher,was installed without being secured,so it slides in and out,with little or no effort. The instructions say to install screws in the top and bottom, or buy side mounts. My question is : How...
Need more info ! hard to answer w/o a photo or even knowing you cabnet or countertop material . If you have a bit of a recess,or can create one, you may be able to go to most any home improvement store and buy common corner or "L" shaped small metal brackets. Very common and in many sizes,Pre-drilled/holes or holes already in them, very inexpensive.
The gasket around the machine door that keeps the water in cannot be compromised by having anything across any part of it`s surface when door is open or closed. The door will hide the brackets when closed if placed properly. The trick is determining how much surface area you have to work with around the gasket/door seal , to the cabinet sides or countertop bottom .This distance determines what size "L" brackets to use.
Slide the machine to where you want it , if it goes to deep into /under the counter or towards the back wall, put pressure treated scrap lumber behind the machine legs on the floor till it`s out to where you like it and the door opens and closes easily. (proper recess) If the cabnets on each side are wood , measure from the gasket to the side of the cabnet.
Is it a tight fit or a little space between the cabnet sides and machine face behind door area? Buy "L" brackets that will screw to the cabnets , cover the gap, but wont touch the door gasket .while resting tightly on the machine face behind door area. The brakets can alway`s be trimmed with a hacksaw or cut off wheel . Get flat head self tapping screws to mount the brackets to the wood cabnet sides. If possible, you may be able to mount to the outside front of the machine, behind the machine door, but outside the door gasket area/ diameter as well . It would give you extra strength but not 100% needed.
You may need to drill small "starter" holes smaller than the self tap thread diameter that are on the screws you puchased , to start the screws in the wood , metal , plastic , ect. Before you drill or mount , do a bracket placement trial run by using tape to hold them where you think they fit/work best . Again make sure the door opens, closes and hides the brackets . The higher up from the floor (closest to the countertop) the brackets are used , the more secure the machine will be ! It won`t flop on it`s face when you open the door to load it or put weight on the opened door.
You can also bring a printed copy of this to your choice of local home improvement store. Matching brackets to the right screws , ect , ect, is easier for them If they understand what you are doing and you find the right employee.
Hope it helped you ! Good Luck !
Jul 06, 2011 | Frigidaire FDB520RH Builtin Dishwasher
We'd like to change the door from left opening to right opening on our refrigerator
Good day,
Before proceeding there are a lot of buttons and cover emblems that cover screw holes. Remove by prying off with a small screw driver as needed. As well, remove all food etc.
As well, keep track of all bushing and shims holding the door hinges in place.
1. With the top door closed, remove the top bracket. Open the door with both hands, open approx. 1 foot and lift off.
2. Remove the middle bracket, and remove bottom door as in step one.
3. Remove and reinstall handles on the opposite side of each door.
4. The bottom support bracket must be removed, and remounted on the opposite side, with the pin sticking up.
5. Reinstall in reverse order using bushing and shims as needed to assure correct alignment.
Dec 01, 2009 | Kenmore Refrigerators
How to change the doors on fridge freezer
Good day,
First. Save and mark all shims and bushings you remove in the process. As well remove all food from both doors.
1. Remove bracket from top of the refrigerator with the door closed.
Once removed, open top door with 2 hands about 1 foot.
Lift off.
2. Remove center bracket and remove as in step one.
3. The bottom bracket can be removed and mounted on the other side, reversing it's orientation. (pin sticking up).
4. remove both handles and remount on other side.
There are many plugs that must be removed, to uncover new screw holes. Some may be covered with emblems, but can be pried out with a small screw driver.
5. Reinstall in reverse order checking for alignment as you proceed.
6. Push in all removable plugs when complete.
Nov 30, 2009 | Refrigerators
Freezer handle has de-attached from door on right side - can it be repaired? I cannot see how you could get at the bracket from inside the freezer door.
I checked the owners manual - found that two small screws holding the bracket on came loose - reattached the screws, then de-attached the handel from left side so entire handle was off. Then slid handle on both brackets left to right until it clicked on.
Nov 26, 2009 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
158 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
