Question about Marantz PMD340 CD Recorder
Continuous play How do I set the Marantz pmd340 to coninuous play? It stops after each track. I would like it to advance from track to track automatically.
4 Suggested Answers
SOURCE: Marantz cd 63 player has
Cleaned laser lens carefully with a cotton bud dipped in isopropyl alcohol. Waited for it to dry before trying. Success!!
Posted on Aug 24, 2008
SOURCE: my Marantz CP430 only plays
I suspect the recording problem is that the wires have broken on the back of the recording head.  The heads move forward every time that a cassette is played and the wires have to bend a little.  A common fault on many cassette recorders is that these wires break with constant movement.  I have a machine with the same problem, but getting to the head wiring in a CP430 is far from easy. John.
Posted on Apr 14, 2009
  • 92 Answers
SOURCE: The CD will not advance to the next track. One
try when u turn it on. check all your bottons 2 make sure they r not stuck and than put a cd n and check 2 c if it will read the hole disc. or push play with a cd in there an try 2 skip songs 2 play
Posted on May 10, 2011
I have Marantz Sa7s1 cd player it plays cd for a couple of tracks & then it stops & distorted noise comes into player it skips sometimes
If it does all that stuff then, you need to take it back or exchange it. If you like the company just exchange it, if not buy from some other company.
Oct 27, 2016 | Marantz Audio Players & Recorders
Is there anything in particular I need to do to use the digital outputs of the Marantz pmd340? My ps audio dac works with a rotel cd player automatically but I can not get it to work with the marantz with...
You may have indicate on the CD player that you wish to use the Optical output and then even when that is correct there are different bit rates that may not be compatible with the input of the amp.
Dec 26, 2012 | Marantz PMD340 CD Recorder
No audio disc message
Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainement equipments.
Pull up older posts. You can get all details.
Site is listed in Google, and you can locate it either at the bottom part of first search page, or at the top of second page.
Click on associated ads too. Sometimes, it might help you.
May 29, 2012 | Marantz PMD340 CD Recorder
I just bougth a marantz cdr 300 cd recorder,everything seems to be working fine, but I'm not able to listen what I just recordered on any other cd player.Marantz cd 72 mr 2020.Thanks
It sounds like you haven't followed the last step to the burning procedure. All you need to do once you've completed burning your disc is to Finalize the disc. Read below why you need to finalize as well as the steps to follow in order to finalize the disc.
Hope this helps ;)
How to Finalize Finalizing is writing the TOC (table of contents) on a disc so a CD player can recognize the number of tracks, the total time for each track, and their location on the disc. A recorded disc must be finalized to playback on a standard CD player. Once finalized a CD-R disc can be played on CD players that support CD-R playback. CD-RW discs can only be played on CD players that support CD-RW playback. Consult your CD player owner's manual to confirm supported formats. Finalizing is necessary to: • be able to play a recorded CD-R or CD-RW disc on a CD player • prevent further recording on a disc • avoid erasing tracks on a CD-RW disc • record text information onto a disc you record Notes: • A finalized CD-R disc can never be recorded onto again. • A finalized CD-RW disc can be unfinalized for more recording. • The CDR300 can play back unfinalized CD-R or CD-RW discs. • SYNC REC+FINAL mode automatically finalizes.
Here are the steps in order to Finalize your disk
1 Push Stop. The display shows the number of tracks and their total playing time. 2 Push FINALIZE. FINALIZE is displayed for about 3 seconds.
Jul 27, 2011 | Audio Players & Recorders
My marantz is recording 5 minute tracks and then opening up a new track ... I want it to record onto one track until I have completed
There are two settings that are important to solve what might be perceived as "irregular" recording processes. The first is to reset "Auto Track" to OFF and the second is to set manual Track to Off. This will result in a more normal recording experience.
Jan 02, 2010 | Marantz PMD660
I have a Zebra Stripe 600. I am trying to print a
Ok, when you say you mean it is a roll of label material that does not have gaps in between? If it has is NOT a continuous label and you probably have the driver settings set as continuous feed and not gap as it should be....
Call - they will help you with any problems you have!
Aug 03, 2009 | Zebra Stripe Thermal Label Printer
This is sounding like corrupted firmware. I just checked the Insignia website for a firmware update to fix your issue, but there are no firmware releases as of yet. I believe there is a 1 year warranty on these units so take it back to Best Buy for a new one.
Apr 26, 2008 | Insignia Kix MP3 Player
Marantz PMD340 CD Recorder Logo
Top Marantz Audio Players & Recorders Experts
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
