Question about uk.com
How do I produce an x- report from the mercury 130w etr machine?
How can i clear error 24 in my etr mercury w130 machine?
This does not appear to be a camera. Please repost this query in a more appropriate forum
Jan 20, 2017 | Cameras
Mon ecran reste noir meme s'il est ouvert
Hello Nicole Savard,
Tres peu de choses peut etre determinee sur vos ennuis sans votre num?ro de serie et le modele !
Avez-vous essaye de brancher un moniteur externe... ?
Sinon, vous pouvez essayer d'avoir votre technique soutien, connectez-vous A distance... et verifier votre machine pour voir ce qui peut etre determine A partir d'un emplacement distant..
I think(?)
Good luck...
Computer Parts Laptops Electronics and More Newegg com
Apr 01, 2016 | Computers & Internet
How do i change the date of mercury 130w
When the machine starts up keep pressing the 'Delete' button, that should get you into the Motherboards BIOS setup - here you can change the current system date.
Feb 10, 2015 | Mercury Computers & Internet
I have a Gold Medal popcorn machine model 2085 that is producing a burning wire odor. Have other people reported this problem with their machine
All new popcorn machines will produce a industrial smell for a short while when first heated up. It is from the oils used in manufacturing and that will stop over time.
Burned wire smell is usually associated with cleaning of the kettle. Cleaning compounds that are stuck in the carbon will create a harsh smell.
Sep 25, 2014 | Kitchen Appliances - Others
How to set time and date for mercury 130w etr
Prodeuce a z report 1st.
-Press vdmode untill displays 4...........
BLACK MACHINE>Press total.Press sh button then total (displays date).Press - *minus button.Key in current date.eg 180515 ddmmyy.Press stl twice.Proceed with time,press + *plus button.key in current time.eg1610.Press stl.Switch off machine.
Aug 18, 2013 | Boating
HOW USE ETR MERCURY 130W
how i can connect to computer and i want report
Jun 29, 2011 | uk.com
Which 120 backs & lenses for my ETRSi do I buy?
All ETR backs work with all ETR cameras except the ETR-C, which only uses the inserts. The early backs have a single latch and a winding key. The middle ones have double latches and a winding thumb wheel. The Ei backs have double latches and a winding crank like a 35mm has. The Ei backs also have a locking dark slide to prevent accidental film exposure wnen the back is off the camera. All inserts work with all the back frames. I the used market you will find them in any combination (frame, insert & darkslide).
I am aware of three series of lenses: MC, EII and PE. They all work fine with any body.
Jun 14, 2009 | Bronica ETR-Si Medium Format Camera
Battery
dear choirboy,
the accepted battery models for the bronica etr-si are 4LR44 and/or 4SR44.
Sincerely,
Agent Allan
Go Ahead. Use Us.
Apr 09, 2008 | Bronica ETR-Si Medium Format Camera
Bronica ETR Power Winder instructions
Here is a link to an operations manual for your winder, 10$
http://www.photobooksonline.com/books/userbk39ETR.html
Jan 05, 2008 | Bronica ETR-Si Medium Format Camera
uk.com Logo
133 people viewed this question
Top uk.com Computers & Internet Experts
David Payne
David Payne
Are you an uk.com Computer and Internet Expert? Answer questions, earn points and help others
