Question about Proscan 19LA25Q 19 in. LCD Television
Proscan 20la11q not digital ready either?How bad this is.A new tv- miss informed
Yah you must be misinformed in revers i have the same tv and yes it is digital ready ! why else when you set it up to scan for channels the first time it looks for analog and then digital do you have you manual or what?
Posted on Feb 20, 2009
Need code for ProScan universal remote
Proscan HDTV Codes = 1000
Proscan TV Codes = 1000, 1008, 1068, 1094, 1108
Proscan DVD Codes = 2118, 2144, 2205, 2319
Proscan VCR Codes = 3000
ON MOST REMOTES:
1. Turn on the TV.
2. Press and hold the TV and SEL buttons simultaneously for 3 seconds. The button will light.
3. With the button lit, point the remote at the TV and enter the TV's 3, 4, or 5 digit code.
4. Verify by pressing the VOLUME + button. This should turn the TV VOLUME up.
5. Press the TV button to store the 3, 4, or 5 digit code. The button will blink twice to confirm the code is stored.
Your ProscanTV can be controlled with a universal remote and work with Comcast, Dish Network, Direct TV, RCA, etc...
Nov 22, 2016 | Proscan Televison & Video
I hooked up my new Proscan TV to the antenna but it can't find any channels
You need to check the connection is tight from the antenna and also on the back of the tv. You may need to try another coaxial cable. Is your antenna powered, meaning does it have a power plug that needs to be plugged in? Is your tv an old crt television? You may need a converter box to be able to view digital channels. A signal booster may help you get more channels.
Your tv or antenna may be defective. You could try your antenna on another tv. If your other tv gets a signal, your tv's tuner could be bad. If the other tv goes not get a signal either your antenna could be bad. I hope this helps narrow down your problem.
Oct 22, 2016 | Proscan Televison & Video
What is Proscan 15LA12Q power supply output voltage and amps?
UpBright NEW AC Adapter For Proscan 19LA25Q 20LA11Q 15LA12Q LCD HD TV DC...
Price:$18.54 + $5.89 shipping
First check it or have the power supply check out with a meter. If you have 0 volts or it is dead then replace it. The main thing is the polarity of the tip, positive tip or negative tip IT MUST BE THE SAME or you will FRY YOUR TV. Good Luck.
Jun 04, 2015 | Proscan Televison & Video
Trouble setting up sony soundbar surround sound, is tv arc compatable?
Arc ready is when there is electricity plugged into the TV,There is only one HDMI cable and that is the one you have. Cause all new TV's come with these cables.If you are using Av cables for the sound it will not work ,you must only use HDMI cable's.Cause some or most new TV's with HDMI dont like to use Av cables with HDMI,so if you havw something else that uses Av cables plug it out and sound will work.
Dec 28, 2013 | Proscan 47LC55S240V87 47 LCD TV
I bought a Proscan 26LB30Q TV. After connecting to the indoor digital antenna, no signal showed up on the screen. What could be wrong? Thanks.
MAKE SURE WHERE YOU HOOKED UP THE ANTENNA SAYS DIGITAL,,IF ITS NOT IT WANT WORK ON TOUR TV,, POEPLE THINK JUST CAUSE ITS A NEW FLAT SCREEN THAT IT DIGITAL,,, BUT A LOT OF THEM STILL ARE JUST ANALOG ANTENNA READY,,,,,THE ANTENNA JACK SHUOLD SAY EITHER ANALOG OR DIGITAL,,
May 15, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
New proscan 32 lcd tv. Won't work with sony wireless headphone
Try using the PROSCAN website customer support, to find the answer to you questions.www.oncorpus.com. You will need some type of adaptor from th coax output to the input of you system. For the wireless problem you may need two adapators one from the tv to you receivers and a sound output to wireless adapator. You can call them at their customer support telephone number 1-888-977-6722. I hope this information helps you with your problems.
Mar 31, 2009 | Proscan 32LA30Q Television
I have proscan tv model 32LA25Q we are on a antenna is this TV digital? As the US is going digital in June I would like to know
No, you are going to need a digital to analog converter box. You can find these boxes at local electronic stores like Fry's and the Micro Center. You can also buy them on line at e-bay.com. Just go to the website and use the search engine to find a digital to analog convert box for televisions. I hope this information helps you with your problem.
Mar 19, 2009 | Proscan 32LA30Q Television
Digital broadcast
While this TV is HD ready, it only contains an NTSC tuner. If you have an antenna or rabbit ears for reception, you will require a converter.
This unit IS NOT digital broadcast ready.
Dan
Jan 21, 2009 | Proscan 19LA25Q 19 in. LCD Television
Who makes proscan tv?
Proscan is produced by ON Corp. They are a leading producer for most LCD screens used by a large group of TV makers. Proscan used to be a high end RCA product. The CEO of On Corp was the head of the Proscan division of RCA. After Leaving RCA and Beginning On Corp he purchased the right to the Proscan trade mark. Thus a new beginning for a old name. Many people still belive it to be an RCA TV but it is not. It has good ratings in most reviews for TV's in it price range. It is now a sears brand much like Dynex is a Best But brand.
Dec 25, 2008 | Proscan 42LA30H 42 in. LCD Television
Digital hook up
No, you will need an ATSC tuner box that will receive digital signals from the antenna and convert them to channel 3 or 4, and put the video and audio out on RCA plugs - yellow, red, and white.
tom
Apr 12, 2008 | Proscan PS27108 TV
Proscan 19LA25Q 19 in. LCD Television Logo
131 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
