Question about Kenwood Kitchen Appliances - Others
Kenwood jkp280 kettle shortly after switching on it switches itself off
Switches itself off
  • 287 Answers
SOURCE: Switches off before full boil
Look under the kettle at the round circular connector in the bottom. Inside there is a small button that is depressed when the kettle is put on the base. If this is not pushed in far enough it will have problems.
The cause is that after some use the connector in the base plate collapses into the base by 1-2 mm This means the switch is not pushed in far enough.
My kettle had similar issues... I pulled the base plate apart (3 screws I think) and cut a round disk of plastic to lift the connector up by about 1-2mm and then reassembled the base.. No more issues
Posted on Jul 08, 2008
  • 134 Answers
SOURCE: Siemens porsche kettle on/off switch problem
Hi
Make sure that the lid is securely on. Otherwise its the replacement of the auto bi metalic strip which turns the kettle off
Posted on Feb 14, 2009
SOURCE: How do I clean the contact points between kettle and platform?
PROBLEM:
My problem was similar for the Cuisinart KUA-17.  I clicked down the on switch and it stayed down.  However, the light and power together seemed finicky.  That is, the light came on if I positioned the kettle in the base correctly, but then it sometimes went off without triggering the switch to pop up.  When the light went off while the switch remained down the water never boiled, but when I was lucky to position it such that the light remained on, the water did boil and the switch popped up ... as it should have.  It seemed to be getting more and more finicky and difficult to position correctly ... so I took it apart.
SOLUTION:
First of all, the base has screws that take a triangle screwdriver which I don't have.  So I found a small flat-headed screwdriver (like one you'd use for glasses) that just fit along one side of the triangle.  I was able to get three base screws out this way and since I expected to need to do this again in the future, I used my dremel to grind a larger flat-headed screwdriver slot in each.  It's been about a year and a half since I fixed it last time and this time I was glad I had the slots.
Once you get the plastic base off, you'll see the mechanics of the switch.  There are two wires that both turn on the light and power the heater element.  Where the wires connect to the switch mechanism, there are two metal tabs that stick out in opposite directions from the center.  When the switch is pushed down, you can see these two tabs move.  They are each moving to touch a contact and complete the electrical circuit.  My problem was they were not making a good contact.  The contacts are hidden behind the tabs.  All I had to do was bend the contacts one millimeter closer (i.e. as little as possible) so that they would make a good contact.  The only other trick was I had to remove the switch mechanism from the bottom of the kettle to do this.  Then I just used the same small flat-headed screwdriver to bend the contact as in the picture below.
Posted on Mar 11, 2009
co7196
  • 3433 Answers
SOURCE: Kettle will not stay on
Sounds like the switch is weight sensitive. A safety feature to prevent overheat as contents run low? The baseplate is probably not moving freely enough to move accordingly.
Posted on Sep 13, 2009
SOURCE: Breville kettle blew fuse (trip switch) now won't switch on
If the 'neon' light is on, the power is getting to the kettle, so if its not heating up then the element must have broken.
This kettle has a little white trip switch inside the 'socket' of the kettle (not the base unit). If its not heating, light is not on and the plug fuse is OK, then poke the white trip until it clicks.
Posted on May 09, 2010
The kettle switches off before it is boiled
Yes you got it . Try cleaning the pin if not its done .
Jan 07, 2018 | Morphy Richards Kitchen Appliances -...
How to fix a kettle when the power switch switches off before boiling point?
There can be several causes. In many cases the power switch is thermo or current tripped, It is like a thermo circuit breaker.
The power switch itself may have to be changed.
The element is pulling too much current.
The thermostat may be defective.
Contact the manufacture to find out where you can buy spare parts to try. You will require the proper connectors, and crimp tools to work inside of these. Also, you will require a sound knowledge of how these appliances work, and the safe way of servicing them.
Because of the way you asked the question, I would think you are not familiar with how to service these devices. I would suggest to give the kettle to a service rep, or to purchase a new one. There are safety issues when servicing appliances.
Jerry G.
Jun 24, 2012 | Prestige Appliances Prestige Pf Enamel...
Monitor switches on ok, but; after a short period; switches off.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 17, 2010 | Samsung SyncMaster 913N 19" LCD Monitor
I have a relatively new kenwood kettle and yesterday it just stopped working. There is power to the kettle as the red light comes on just nothing else. Can you help?
suspect kettle heating element is defective. if the light did not come on then it could also be the thermal switch which may be sticking. if the product is relatively new you should still have warrenty, recommend contacting your vendor about this problem. Kenwood have a very good customer service network.
Nov 16, 2009 | Kitchen Appliances - Others
Hi
Feb 14, 2009 | Breville SK500-XL Stainless Steel Cordless...
Nov 23, 2007 | Russell Hobbs RHOK3123 Cordless Electric...
Car Stereo Volume Goes Up and Down Erratically
prolly buy a truck and a amp from this century
Oct 05, 2007 | Car Audio & Video
Kitchen Appliances - Others Logo
251 people viewed this question
Top Kenwood Kitchen Appliances - Others Experts
ka4iup
ka4iup
ray gallant
Irene Tulloch
Are you a Kenwood Kitchen Appliances - Other Expert? Answer questions, earn points and help others
