Question about Freezers
Ignis AFE 275
Manual
How does the Ignis afe550/ig Upright Freezer defrost?
I couldn't find any info on your freezer but there are 2 main ways units defrost. The first is manual defrost where you have to unplug the unit to defrost it yourself. These unit are typically chest freezers and upright freezers that have no fan and the refrigerant runs through the shelves. You can tell because frost will mainly build up on the shelves themselves. The second is self defrost. These units will have a fan in the freezer and a evaporator coil behind a wall inside the freezer. This wall is usually inside the freezer on the back wall. These units have a heater that is activated by a timer and comes on every 8 hours or so and will heat the coil for 20 to 30 minutes. This removes all the frost build up on the coil and you should never have to do anything. I hope this helps.
Feb 22, 2015 | Freezers
I changed clicks and relays but wires at the compressor burned,only fan runs but compressor still cant start,whats wrong and where is the thermostat?
Hello;
My name is Peter. I am a retired field service refrigeration technician.
Your problem is not your thermostat. In some models the compressor knocks out the overload relay. They relay could last a few seconds or a few weeks before the compressor knocks it out again. This is especially turn with the LG units.
You will need a multi-meter to check your compressor.
1.) Unplug your unit. Remove the bottom back cover.
2.) Remove the overload components to expose the 3 pins on the compressor.
3.) Inspect the pins on the compressor. Are they clean or are they damaged from heat (Steel melting).
4.) With your multi-meter, set the meter on the lowest Ohms. Read the Ohms between each of the pins. You will have 3 readings. One reading will be high and the other 2 readings will be lower. Add the 2 lower readings together. This value must equal the high reading within a few tenths.
I hope I am wrong. A new compressor depending on the model is $275-$450.00. Include a system filter for $40.00, plus new refrigerant $45.00 and the cost od an experienced technician $300.00.
Dec 04, 2014 | Samsung Freezers
How to find a manual for Frigidaire Freezers
If you have a PC try going up to the Frigidaire Website. If not call them on the phone and ask if they have a manual available for your model refrigerator. So you'll need the model # for the right manual. There are also other websites that sell (some may be free so look around online) manuals. Manuals.com has manuals but most of them are not free. Always check the manufacturer first as those manusal should be free.
Sep 02, 2014 | Freezers
404A suction side-5 high side 275 whats wrong
TRY TO ACID WASH CONDENSER. AND CHECK IF YOUR YOUR EVAPORATOR MOTORS ARE RUNNING.
Mar 10, 2014 | True 49 cu. ft. / 1388 liter Commercial...
My ignis chest freezer isn't freezing anymore even
your cooling system matchine facced this problem.
Mar 20, 2013 | Freezers
Hi. I have just aquired an "IGNIS" chest freezer, model AFE 460/IG, class T. On the bottom right hand side of the freezer ther is a dial (from 0 to 3) which can be altered using a screwdriver...
Pretty sure that the slide is for winter and summer operation, you are rite, the 3 position is the cold level and the 3 lights (Yellow, Red, Green). the Yellow indicates a caution,"" not at temp or faulty""the Red indicates the unit is active and the Green indicates at temp and operating correct. This unit is old and not much information is available however I hope from my experience, that will help you, any further problems call Russ on 08 95230552.
DONT FORGET TO VOTE, I SUPPLY MY TIME FOR FREE TO HELP. RUSS
Mar 02, 2011 | Freezers
J6SFF-61B Manual
Try this number and ask for an owner manual (800-314-4477)
May 27, 2008 | Coldtech 61 cu. ft. / 1727 liter...
Low suction pressure high head pressure
That system has a restriction. Most common at TXV valve or capillary tube. Will need to be replaced by Refrigeration company. In this video I replaced TXV valve and filter drier due to the same issue You have. Its Ice Machine, Low side was at 5 PSI, High at 250PSI : 404A; should be around 55-65 Low; 250 -275 High. Replaced drier and TXV, machine works proper.
May 19, 2008 | Hussmann Freezer 12 Facing Straight Glass...
Sub-Zero Under Counter Ice Maker not making Ice
ice stat defective
hot gas solenoid vavle defective
pls post make /model.
if ignis / whirlpool then above points should the trick.
lastly reclaim gas replace both driers recharge with fresh gas to spec( liquid by weight).
Feb 20, 2008 | Freezers
Freezers Logo
52 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
