Question about Dell 0Y3740 Keyboard
Dell Laptop - Keyboard "Fn" is causing problems!
I can't sign in to use my Dell Laptop. It seems that the blue "Fn" is activated. When I sign in I get the blue numbers vs. letters. How do I inactivate the "Fn". Help?
  • Anonymous May 23, 2008
    cant ty*e *r6*er3y
  • qabrenda Sep 10, 2008
    cann6t 4se 0y 2eys 6n the 3eft 6f 0y c60*4ter
    Scholar:
  • 125 Answers
I think it is not the Fn key but the NumLock that is activated. Look for the key labeled NumLk , this is the number lock. Also check if the light on the notbook with a number (usually number 1) is on. If it is on, yo must deactivate the numlock by pressing it again. It works in toggle mode. Sometimes the numlock is activated together with the shift key, sometimes with the function key.
Posted on Jul 06, 2007
On my Dell, I have to press Shift and Num Lock, that solved it for me!
Posted on May 25, 2009
How i change front .my com isn't have pause break
Posted on Feb 28, 2011
What worked for me was to press and hold the Num Lk key FIRST and while holding it down, press the blue Function key. This allowed me repeatedly to switch back and forth. Doing the reverse did not work for me.
Posted on Oct 31, 2008
MY FN BUTTON IS REMOVED..HOW DO I PUT IT BACK!!
Posted on Oct 13, 2008
Hold down fn and press num lock represented on your keyboard as Num Lk it worked for me
Posted on Jun 29, 2008
I can't turn the fn key off
The Fn key (also known as the Function key) is a feature found on most laptop computers. The Fn key allows keys on a laptop computer's keyboard to serve more than one function, a clever way of increasing the utility of the keyboard when space is limited. Dell laptops make good use of the Fn key, and if you own a Dell laptop, you should be aware of where the key is and how to use it.
Open your laptop and turn it on. Then locate the Fn key. It is located on the lower left side of the keyboard, next to the Ctrl key. Press and release the Fn key. Now examine the keyboard carefully. You'll notice that many of the keys have icons or letters and numbers printed in blue upon them. These keys and functions are operated when the Fn key is enabled, as you've just done. Test it out by looking at the lower right side of the keyboard. You'll see two keys with small blue "sun" icons. These control the brightness of the screen. Press the lower one several times and you'll see the screen darken. Press the upper one. The screen brightens. Press and release the Fn key again. Now try using the brightness keys. The screen brightness will not change. You've turned off the Fn key.
Feb 06, 2013 | Dell Inspiron 1501 Notebook
HOW TO DEACTIVATE TEH Fn KEY IN DELL LAPTOP
Hi names Rui, to turn Fn in you dell you need to:
1. Open your laptop and turn it on. Then locate the Fn key. It is located on the lower left side of the keyboard, next to the Ctrl key.
2. Press and release the Fn key. Now examine the keyboard carefully. You'll notice that many of the keys have icons or letters and numbers printed in blue upon them. These keys and functions are operated when the Fn key is enabled, as you've just done. Test it out by looking at the lower right side of the keyboard. You'll see two keys with small blue "sun" icons. These control the brightness of the screen. Press the lower one several times and you'll see the screen darken. Press the upper one. The screen brightens.
3. Press and release the Fn key again. Now try using the brightness keys. The screen brightness will not change. You've turned off the Fn key.
The Fn key (also known as the Function key) is a feature found on most laptop computers. The Fn key allows keys on a laptop computer's keyboard to serve more than one function, a clever way of increasing the utility of the keyboard when space is limited. Dell laptops make good use of the Fn key, and if you own a Dell laptop, you should be aware of where the key is and how to use it. So i hope this will help you.
Jul 20, 2011 | Dell Vostro 1510 Laptop
Laptop types numbers instead of letters
Hi!
You have enabled NUM LOCK. Press button "fn" and find another button with blue tag "Num Lock". Pres both buttons at once.
Hope it helps
Jul 10, 2011 | Dell Inspiron Mini 10 Notebook
There is a lock 9 symbol above my f4 button on my latitude e4300 laptop and i would like to know what this means?
The lock 9 is for num lock.
Usually there is a 'Fn' button on the keyboard of a laptop. It has to be somewhere near the 'ctrl' 'windows' or 'alt' button on the left.
If you press and hold the 'Fn' key and then the numlock 9, you will toggle numlock on and off.
The 'Fn' of the key is normally written in another color. There are several buttons on the keyboard thet has a same color number or sign. To enable this signs and numbers, you have to press and hold the 'Fn' key and then the key with the desired number or sign.
Sep 13, 2010 | Dell 0Y3740 Keyboard
How to turn off blue keys for an Compaq mini cq10??
if you are refering to the blue letters or alphabets which are present on the keyboard. HP designs keyboard with a billingual layout in some Notebook models.
The HP "Blue" keys are indeed the "French" input keys or other language keys.
How to use the Blue Symbols or keys on a HP Notebook:
We can activate them by pressing Ctrl+fn+right Shift.To deactivate, press Ctrl+fn+right Shift twice, i.e. Ctrl+fn+right Shift then let go off Shift while still holding Ctrl and fn, then press Shift again.
When you press Ctrl+Fn+Right Shift it will switch to the the billigual layout. That means the blue characters become prioritie.
For example, if you are in the billingual layout, when you press shift+6 you will get a '?' but not the '^' sign.
Mar 19, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
My dell laptop types numbers instead of letters on some keys without pressing fn key
HI,
If you Are writing numbers instead of letters when you press the keyboard of your laptop and you must hold down the Function key (Fn) to write normally.
This is due to the fact that the digital lock is activated. To solve this, simply press the Fn+Numlk or depending of the model, press the button or Fn + Shift +Numlk
Hope This Helps
THANK YOU
Feb 27, 2010 | Dell Vostro 1510 Laptop
Keyboard key not typing primary character, shift/fn strokes work
this is to do with your FN key....it is activated to be on all the time...
googlesearch this ...
Sep 15, 2009 | Dell Inspiron 1521 Notebook
Key board does not work[only blue marked key is workig]
I have a dell laptop and had this happen to me. It's a simple solution, your "Fn lock" is swithed on. Hold down the Fn button and hit Num lock. Now your other keys should be working rather than the blue keys. Hope it helps
Jul 05, 2009 | Dell Inspiron 1501 Notebook
The keyboard on laptop is locked.
Are any of the keys stuck down?
Does it do this when you reboot the machine e.g. can you press F2 or Del to go into setup?
Also are you familiar with the 2nd function keys onthe laptop (usually defined in blue on the key) to access these you usually press a "Fn" button to activate the blue part. Maybe you activated a keyboard lock by accident. If you have the manual maybe check this or call dell support as previously mentioned.
Mar 15, 2009 | Dell Inspiron 1100 Notebook
Fn key on keyboard seemed stuck
hit shift and "Num Lk" at the same time. Num Lk is abov the F11 button on some Dell keyboards.
Tony Nguyen From Pasadena, CA
www.connectionzpcrepair.com
Aug 06, 2008 | Dell Latitude CPX Notebook
Dell 0Y3740 Keyboard Logo
3,671 people viewed this question
Alun Cox
